Old 14-02-2006, 08:54 AM   #1
GK
Walking with God
GK's Avatar
Default Diff Matters!
Hi Guys,
I have an Au2 sedan and I want to change the diff oil. At what intervals should it be changed? What happens if you don't etc, etc.
Will undoing the bolt drain the contents of the diff out, or do I need to syphon it out somehow?
Also, what diff oil should go back in, and how much?
I'm reasonably handy and expect that I could do this job myself! Am I correct in this assumption, or am I deluded?
There doesn't appear to be any leaks as far as I can see.
Many thanks,
GK
Old 14-02-2006, 01:45 PM   #2
Whoosha
AU DIE HARD
Whoosha's Avatar
Well the little blue book says conventional 6cyl axle SAE90 Hypiod ford spec ESW.M2C108.A orWSP.M2C197.A or lsd 6cyl..SAE90EP ford spec ESW.FM2C1006.B
or v8 xr ext..Mobil lubeSHCID withadditive friction modifier STuraco7098 should take 1.65 lts + be good for 100000 ks pending on your driving habits (I change mine at 500000 ) also easyer to remove back off diff to drain completly , if your carefull gasket should be rite to reuse with a good sealant......... hope this helps cheers Whoosha
Originally Posted by Riksta
Old 14-02-2006, 06:12 PM   #3
JC
JC's Avatar
The drain hole is the bottom bolt. The big middle bolt is the fill hole. Easy to do yourself except the IRS LSD version (fill bolt is high and hard to get to). A hand pump will make it easier to get the oil into the diff. I did both mine (Live axle, easy, and IRS, hard) about 3 months ago. Don't spill any on the ground - the old stuff stinks!
Ford Performance Club ACT
Old 14-02-2006, 08:45 PM   #4
GK
Walking with God
GK's Avatar
Thanks for the info guys.
JC, will opening the bottom drain bolt see the entire contents emptied? If so I reckon a simple oil pan underneath would do the trick. If it won't, would I have to take the whole back off?
Also, if I don't have a hand pump, how would I go about getting the new oil in? A 2 litre coke bottle with some old garden hose perhaps? Maybe a 1 litre oil container half filled, being held on its side, emptied into a spout, again with garden hose attached?
GK
Old 14-02-2006, 08:52 PM   #5
svo347
AFF's 1st DM.......
svo347's Avatar
go for a drive, warm the oil up and just undo the bottom bolt.
The hole isnt blind and will drain the oil out...
just make sure you undo the filler cap to aid you.
the coke bottle idea will work with a small piece of garden hose attatched to it.
some containers come with a short spout that you can squeeze the contents into.
FORD GIVING POWER TO THE PEOPLE
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
I know what lengths they go to to ensure it's more than just a Ford sticker on the part. Ford doesn't throw it's name on anything for a quick buck.
06 Turbo Terri AWD 6 sp in Neo with stuff i didnt even need, side steps,15.2 inch roof mounted DVD,Pioneer $tezza,Selby 30/18mm swaybars,debunged,100 cpsi Ballistic cat,Plazmaman under battery Cai injectors 14/lb boost,ZF tuned,Xtreme's magic. :
svo347 is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2006, 09:01 PM   #6
Baboon_AU
Baboon_AU's Avatar
yes the containers come with a spout and you fill your diff up as full as u can before it overflows out of the fill hole.. much like the tranny
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2006, 04:16 AM   #7
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
Remember to put in the LSD lube if you have an LSD (aka Stink)
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2006, 06:56 AM   #8
GK
Walking with God
GK's Avatar
Thumbs up
Many thanks everyone, will do it this weekend!
GK
Old 15-02-2006, 08:28 PM   #9
SVR73
Mr Polish
Got 85W250 in mine but don't think you will need to go to that level, maybe 85w140
I won't need to change it for donkeys years, 200,000-300,000 life according to red line
Will be 15- 20 years before I get to that.
Detailology colour fx detail studio and R&D Lab
SA's leader in auto detailing and paint treatments
SVR73 is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2006, 08:31 PM   #10
svo347
AFF's 1st DM.......
svo347's Avatar
Yep redline in my diff/g.box... Will start with the engine next.
13.21 @107.7mph
Old 15-02-2006, 08:46 PM   #11
GK
Walking with God
GK's Avatar
Got the info from the forum - aaaahhhh sweet dependable forum! LOL!
Checked the diff, no tag so standard oil for me.
Got the oil tonight, off to my brother in laws for the trolley jack Saturday morning, will get it done then.
By the way, the trolley jack under the diff ok? Or should I leave the car level? How do others do it?
GK
Old 16-02-2006, 12:44 AM   #12
xr8ute
Back on the road
xr8ute's Avatar
I change diff and gearbox oil every 50,000km...most cabbies seem to do the same.
I use Castrol SAF-XA in the diff and next time ill be looking at Transmax Z in the auto instead of TQ95. Not 100% sure yet that Transmax Z is ok in our BTR auto's??
Anyway, change oils regularly if you can do it yourself. Very cheap insurance IMO
AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute
5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor.
Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash.
xr8ute is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2006, 10:10 PM   #13
GK
Walking with God
GK's Avatar
Did it tonight, Couldn't wait until the weekend, have way too much on.
You were dead right Baboon_AU, I got about 1.6 litres in and it started coming back out the fill hole. I reckon theres at least a litre and a half. The book says 1.65 but I hope I'm ok.
GK
Old 17-02-2006, 12:59 AM   #14
Baboon_AU
Baboon_AU's Avatar
should be fine. as long as it is as full as you can get it then its all good
