26-01-2016, 05:05 PM | #1 | ||
Hi all,
My Forte is still hovering about 106,000kms so internally it's still good but the exterior I want to just clean up a little. Some things are small and I guess most people wouldn't bother with it, but it gives me some ocd lol 1- There's some clear coat peel on the boot and fade on the roof I want to clean up, and some dents around the rear left wheel arch I want sorted out, who should I see for this? ( or google ) 2- The boot is missing the gas struts that holds it up when opened, I bought a pair on ebay, are they straight forward to install? or should I bring them to a workshop. 3- The rear spoiler: the left side can't be screwed down, what should I do to hold it down? I thought about finding a spoiler at a wreckers or something and bolting that on but if there's a way I can hold it down I'll give it a try. 4- One thing I want improved are the brakes, they are not the worst but would anyone know an estimate on how much it would cost to upgrade them? ( Sydney area ) Thanks |
26-01-2016, 05:54 PM | #2 | |||
Next upgraded Mk1 Leopard
No 3 Take the whole spoiler off and check the connections No 4 Check the AU brake post, it has every thing you need. And Welcome UK
26-01-2016, 06:02 PM | #3 | ||
thanks, glad it's a simple install. As for the spoiler, the holes where the screws go in can't be used on the left side, it's pretty bad lol
I seen the AU 2 and 3 series brake thread, I'll look for one applicable to me |
26-01-2016, 06:05 PM | #4 | |||
UK
26-01-2016, 07:18 PM | #5 | ||
Blacktown? cheers not far from me, and it's (B5) Sparkling Burgundy
26-01-2016, 07:27 PM | #6 | ||
Before you head out there look them up on the interweb first as they have all there cars up and lists of removed parts. The $2 entry fee is nothing, but the drive out there with tools to find the part you are after has been taken already is an irritation
26-01-2016, 07:54 PM | #7 | ||
True that, you do need the gear to get what you need off. There are a few Burgundy AUs but U can't remember the nic of the paint. FordPro @ 94 Victoria St, Smithfield, Sydney have the items as well but will remove/get the bits you want.
UK
01-02-2016, 01:13 PM | #8 | ||
in regards to your spoiler screw problem, you could try filling up the dodgy hole/s with epoxy putty. Once dry you simply drill a small pilot hole and let the screw do the rest. Saves buying a whole new spoiler!
