Old 13-02-2016, 06:27 PM   #1
Blue Shadow
R.I.P. Maggie
Blue Shadow's Avatar
Default AU2 XR8 Pollen filter
Hi
I have bought an au2 xr8 ute a couple of weeks ago, I in the middle of doing a few things to it. It smells awful inside the cab, my question is does it have a cabin air filter and if so where is it and how do I change it. I have looked at the workshop manual and cant find anything so I am assuming it does not have one
Thanks in advance
Blue Shadow is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2016, 09:51 PM   #2
BOTTLEDUP
Default Re: AU2 XR8 Pollen filter
No pollen filters in AUs.
It may have a blocked A/C drain tube, check that otherwise it could be mould & bacteria built up in the evaporator core.
BOTTLEDUP is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2016, 10:12 PM   #3
Blue Shadow
R.I.P. Maggie
Thanks, Im going to get new carpet next week as well. Do you still do the MSD leads?
Old 14-02-2016, 12:47 AM   #4
mik
mik's Avatar
i do think some one posted some time ago, (please correct me if im wrong) you can get rid of the mouldy smell by setting the air con to fresh air , put the fan on full bore and spray glen 20 down the windscreen grille (outside)on the passenger side intake for x amount of time, but if there is a problem with the water drain being blocked you would have to make sure this was fixed first .
Old 14-02-2016, 12:54 AM   #5
Blue Shadow
R.I.P. Maggie
Yeah im going to check for blockages in the morning then ill give that a crack, some vanila might be good after the glen 20 as well ill let you know thanks for the tip
Old 14-02-2016, 11:37 AM   #6
Silver'
T-Series Club Member Vic
Silver''s Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent write ups on AU technical issues.
There's specific products for this - I last used a Wurth product when the car was several years old. That was a few years ago and still the smell hasn't returned 👍🏼
TE2 #116
Build/Maintenance thread here.
www.fte.ford.com.au lives! 2001 2002
Add a T-series to the Registry HERE
Silver' is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2016, 11:41 AM   #7
11ford11
check drain tube is clear as mentioned -
is carpet wet underneath ?
check plenum has not got a build up of leaves...........
try leaving a small jar of coffee opened sitting in cabin
Old 14-02-2016, 11:42 AM   #8
Spurious
Ok, to decontaminate the air vent system there's 2 options...
1: take it to a specialist A/C tech & pay $$$ to have a foam based product sprayed through the vents/pipes.
2: remove the glove box (to access the fan intake), turn the system to "recycle" & turn the fan on full, then open ONE vent at a time & spray Glen 20 directly into the fan...in short bursts. This allows the fan to force Glen 20 at full pelt through that vent. Then one by one, open/close each vent as you spray.
ENSURE THERE ARE NO NAKED FLAMES ANYWHERE NEAR BY WHILST YOU ARE DOING THIS
I also spray some into the outlet of each vent before I spray into the fan.
The above process works a treat & your car will smell like a field of fresh flowers!
I repeat this procedure about once every 6 months 'cause I have in the past contracted a chest infection after inhaling mold spores whilst the A/C was on.
Spurious is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2016, 12:38 PM   #9
Blue Shadow
R.I.P. Maggie
No the carpet is not wet and i have cleared the plenum it was ok. I have got new carpet coming next week the old ones just smell like a cat gave birth on them. The coffee thing sounds good Ill do that and leave a couple of nights
Thanks bud
Old 14-02-2016, 12:42 PM   #10
olfella
Cranky old bastard
I got a product from Repco that left a nice smell for weeks after using it. To use it was like bombing the house. Switch everything off except A/C, place can under glove box and push the button. Wait 5-10 min and air the car out. Cost around $40 from memory but a common problem in air conditioning units.
"But really...what can possibly go wrong"
olfella is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2016, 12:44 PM   #11
Blue Shadow
R.I.P. Maggie
Got the glen 20 and the glove box is out, do i spray some down the vents as ?
Old 14-02-2016, 12:46 PM   #12
olfella
Cranky old bastard
Never hurts as spores will be all over the ducting as well as the core. But do that with th efan off atherwise it will blow it straight out without doing its job.
Old 14-02-2016, 02:09 PM   #13
Blue Shadow
R.I.P. Maggie
THANKS HEAPS GUYS
I have sprayed through the fan behind the glove box and down the vents and plenum, went through 3 cans of glen 20 and all i can smell is glen 20.
Im going to put a jar of Nescafe in the car this arvo and leave it in there a couple of nights as well.
I still have new carpet coming but my mrs has shampooed the old ones and disinfected them, the seats as well, they are good now too, still ill put in the new carpet.
Really appreciate all the advice thank you so much
Craig
Old 15-02-2016, 01:34 PM   #14
Spurious
The reason I said spray some into the outlet of each vent is simply to ensure you get as much into the ducts as possible (maximizing penetration basically). Just a matter of turning fan off, spray into each vent & let it evaporate.
Spraying into the fan will flush the spray through, but obviously the spray won't be as effective by the time it exits the vents.
Door cavities can often cause odours too if the drains are blocked (stale water remains)
