Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 20-05-2016, 10:28 AM   #1
Octane_Flash
Default Brembo disc thickness
Could someone advise me what is the minimum wear thickness of a Brembo front disc before it needs replacing? I have 4/1 set up on my FGII XR6T.
Also, are these disc machineable?
Octane_Flash is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2016, 11:00 AM   #2
falconhell74
falconhell74's Avatar
Default Re: Brembo disc thickness
The min thickness will be stated on the top of the disk , yes they are machinable if within tolerance
XC GS OLD SCHOOL MUSCLE
Audi A4 S-line quttro
Xc falcon
Previous fords-
xc falcon 500 ,250 x flow 3 speed
xc gs worked 250 x flow 4 speed
xa Fairmont 302 auto wagon
xb falcon 250 log auto 4 door
xb falcon 200 log auto ute
xc gs project - had to sell :-(
xc gs 302 4 speed 4 door
xc gs 351 auto 4 door
zf fairlane 302 auto
zk fairlane 250 x flow carb auto
zl fairlane 250 x flow EFI auto
xg ute , BA falcon dedicated gas
xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5
falconhell74 is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2016, 11:22 AM   #3
Octane_Flash
Thanks for that.
I'll the calipers out and measure it this weekend.
Old 20-05-2016, 11:31 AM   #4
falconhell74
you will need a micrometer preferably or a vernia aslong as the lip isn't too big
standard vernier
disk brake vernier
Xc falcon
Previous fords-
Old 20-05-2016, 06:56 PM   #5
Blem
Or just use a washer etc on each side of the disc (not on the rotor lip).
Measure. Then subtract washers thickness
Blem is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2016, 03:10 PM   #6
Octane_Flash
I measured up the disc and I have 31.3mm left. I used Blem's idea of the two washers to avoid measuring the lip.
I also found out that I have a DBA rotor instead of the Brembo so the cops must have replaced the front set a while ago. The min thickness written on the disc was 30mm. There is still about 5mm of material on the pads.
So, is there enough meat on the disc for a light machine? There are only light grooves on the face
Old 21-05-2016, 08:16 PM   #7
JAJH
JAJH's Avatar
If they are 355mm rotors with either 4 or 6 pot Brembos, the rotors are 32mm with a minimum of 30mm. As long they are over 30mm, you can get them machined.
FROZEN WHITE XR5 TURBO & MOONDUST SILVER XR5 TURBO
PREVIOUS RIDES
AU3 VENOM RED XR8, 19" SILVER ARGENTS, REBEL BODY KIT & 6/4 BREMBOS
MARS RED FG MK2 XR6 ECOLPI, SILVER ARGENT 19" RIMS & TINT
BLOOD ORANGE BA GTP, QUAD EXHAUST, SUNROOF, CHIPPED, SS CAI, 320KW
NAROOMA BLUE AU3 HERROD XR8- SS CAI, TS RIMS, 6/4 BREMBOS, TWIN SPOILER, REBEL BODY KIT & TUNED BY ELITE
VENOM GTP, HERROD EXHAUST, DVD PLAYER, WINDOW TINT, SS CAI, STEALTH
VENOM AU11 TE50, HERROD LOWERED, HEADERS AND EXHAUST
[SIGPIC][/SIGPIC]
JAJH is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2016, 10:39 AM   #8
falconhell74
yes machineable as I assume there is no major shuddering or brake pedal pulsation indicating a warped disk.
Xc falcon
Previous fords-
Old 22-05-2016, 11:11 AM   #9
Octane_Flash
No shuddering. The car pulls up straight
Old 23-05-2016, 05:10 PM   #10
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Wait for the pads to be replaced before you machine them i mean you only have about 3mm before replacing them anyway and plus the pads will be worn they shape of the rotor which makes bedding into the machined surface a bit harder to do.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
FLOORED is offline   Reply With Quote Multi-Quote with this Post
