Old 28-06-2017, 08:27 PM   #1
chrisorm
Default 2012 ST disc and pad replacement costs?
Anybody had discs and pads replaced on their ST? Whats a good price? Recomended parts if not oem?
Ford wants $950 for oem. Pedders around $1100 but forget the brand.
For reference its done 105k km. Not sure if thats early for discs, but i was told they are worn just below minimum spec. Only on its second set of pads though.
chrisorm is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2017, 09:42 PM   #2
stefcio007
Default Re: 2012 ST disc and pad replacement costs?
Is this for front and back? Labor included?
For parts, Motorcraft front pads for an LW are only $48, Ford OEM are $99, I doubt ST pads would be hugely more expensive...try another dealer or go to a Ford Parts Superstore.
Old 29-06-2017, 07:41 AM   #3
chrisorm
Front and rear. Yeah pads are cheap. It's the discs I can't find part prices to compare to.
Old 29-06-2017, 09:31 AM   #4
ivorya
Mad Scientist!
ivorya's Avatar
Get in contact with site sponsor 'Race Brakes'
They will help you out
ivorya is offline   Reply With Quote Multi-Quote with this Post
Old 03-07-2017, 06:23 PM   #5
JC
Miami Pilot
JC's Avatar
Has it got the standard 278mm front rotors (DBA2118E), or 300mm (DBA2120) ones?
Rears will be DBA2145.
Ebay is your friend - I use ADB discs, but you could go for RDA or DBA
DBA front 2120 T2s for $280 a pair:
http://www.ebay.com.au/itm/DBA-T2-Sl...kAAOSwax5Yv7GF
Ford Performance Club ACT
Old 03-07-2017, 06:48 PM   #6
chrisorm
It's standard. Not sure if that is 280 or 300mm on the ST.
But thanks for the part numbers and I will check with race brakes too.
Old 04-07-2017, 06:23 AM   #7
russellw
russellw's Avatar
There were actually 3 rotor sizes available for the front: 278mm 300mm and 320mm.
Russ
Old 05-07-2017, 11:00 PM   #8
JC
Miami Pilot
JC's Avatar
From what I can work out, 320mm were on XR5, 300mm on ST, and 278mm on everything else.
Old 26-07-2017, 10:09 AM   #9
stefcio007
Interesting. My rear brake set has stamped on the box compatibility with he following:
Focus 2004/2008/2011/2014 (-) ST (-) RS
C-Max 2003/2007
Part number is
MEAV6J-2M008-AA
