Old 15-03-2006, 05:43 PM   #1
OZFORDAU
OZFORDAU's Avatar
Post Black side skirts!
I want to take off the black side skirts and paint them white so they colour code my car!
But...
1. How do them come off?
2. How do they go back on?
3. What paint do i use?
Simon
OZFORDAU is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2006, 05:46 PM   #2
Mechan1k
Mechan1k's Avatar
Or ... got to a wreckers and see if you can find a set of white ones already .... so you might not have to paint them.
Not sure how they are attached ... I haven't looked that closely ... but i presume very grippy adhesive ... I doubt it's a tape though ... most likely adhesive run along the strip and then stuck on.
Old 15-03-2006, 05:46 PM   #3
Mechan1k
Mechan1k's Avatar
I presume you are meaning the strip halfway up your doors?????
Old 15-03-2006, 05:51 PM   #4
OZFORDAU
OZFORDAU's Avatar
Default Ok
Yeah the strip hald way along the doors! Hmmm i think it's double sided tape! What paint would you use?
Old 15-03-2006, 06:07 PM   #5
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
you could carefully mask ( masking tape ) along the edges of the trips along with nespaper to to cover sorounding areas from overspray , saves taking them off ?? ..
u could use a pressure pack can if u like no worries , use enamel , if u want the paint to grip really well and not chip away - then give the strips a light sand / just lightly / enuff to take the old gloss coat off the old surface / but keep the sandpaper tame / like down to around a 800 grit max ( preff around 1200 but will take alot longer ) , u just want to lighty scuff the surface to give the paint something to grab to ( stops it chiping/flaking away later ... cant stress enuff though just a lightt sand or u will end up polishing the surface up nearlly again using such a fine grade sandpaper... basically u want it to look and feel smooth , but just be able to see light scratchmarks from the sandpaper in the old paint/ take the shine off the old surface . gl
:eclipsee_
Old 15-03-2006, 06:09 PM   #6
XR6-VCT-2000
Fantastic Plastic
dam spellin , sorry ..lol , typos .. i meant ..
you could carefully mask ( masking tape ) along the edges of the Strips along with neWspaper to to cover sorounding areas from overspray , saves taking them off ?? ..
:eclipsee_
Old 15-03-2006, 06:14 PM   #7
OZFORDAU
OZFORDAU's Avatar
Post Thanks
It's not painted it's just black plastic im pretty sure, so will i be able to just paint staight on top of them? It's an AU1 so they hadn't put the colour coded ones on yet...
Simon
Old 15-03-2006, 06:19 PM   #8
XR6Stu
They are held on with double sided tape. I suggest caution when pulling them off, warm them up to heat up the glue on the tape, eother wise its fairly easy to snap/bend the moulds, and also pull a high spot into your door where they are stuck to the door skin. Realistically you can use pretty much any paint you want, just as long as it is very similar to your car. Cheers!
XR6Stu is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2006, 06:19 PM   #9
Mechan1k
Mechan1k's Avatar
I'd sand them anyway ... it takes that bit of shine off them and allows to paint to stick a bit better ... not sure if you can get primer in a pressure pack though ... but if you can ... do that first.
Old 15-03-2006, 06:20 PM   #10
XR6-VCT-2000
Fantastic Plastic
ahhhhh , mine are allready maointed , but i know what ya mean , still wouldnt hurt to give them a light sand first m then maybe undercoat too before final paint, Use a light color undercoat ( light grey at the least ) , apply enuff so u cant see the black through it anymore , otherwise u will have really dull spots in the final white if u dont , no undercoat at all and ull find ull have to do heaps and heaps of coats to get it pur white like the rest - cos of the dark black undernearh makes the white dull out bad.
:eclipsee_
Old 15-03-2006, 06:21 PM   #11
XR6-VCT-2000
Fantastic Plastic
mine are allready painted i meant.. typos errors again sorry , time to change my keyboard batterys i think ! ..lol
:eclipsee_
Old 15-03-2006, 06:33 PM   #12
XR6-VCT-2000
Fantastic Plastic
oh , plenty of light undercoat dust coats allowing about 10-15 mins in between each before applying next dust coat (stops any runs), when happy its sealed , apply final undercoat keeping the speed on the can moving about the adverage of covering about 6" in 3 seconds max (if u get a few runs at this stage don't stress as u will sand again in the morning anyways and u can sand the runs out ), let that final thicker undercoat dry overnight , lightly sand back that coat in the morning to give that glossy smooth undercoat finish a bit of a surface for the paint to grab too ( dont sand it totally off ! ) .. it will be glossy a bit because of the last thicker layer that was applied......
repeat the same for the final coat except don't sand anything after the final coat !! ..lol , if u like u can repeat all the above again with a clear laquer enamel too to give it a nice thick sorta unchipable surface ( the gloss will chip before the paint making the chip unvisable ) , it gives the final coat that extra bit of shine plus also protects the paintwork from chips to a degree ..dont sand the final paint either if u wish to apply gloss enamel too, so make sure u dont get any runs in th final color paintwork.
:eclipsee_
Old 15-03-2006, 07:50 PM   #13
OZFORDAU
OZFORDAU's Avatar
Talking Thanks
Thanks everyone for your help!
Simon :
Old 15-03-2006, 09:06 PM   #14
stock au
Need go fast bit's
stock au's Avatar
if you do take them off you could allways put them back on with some sikaflex.
stock au is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2006, 09:44 PM   #15
GUTLES
Adam.
GUTLES's Avatar
Why not just take them off & leave them off?
2004 BA XR8, Winter White, Manual, 20's, Bluepower Custom Tune, Difilippo Extractors, etc - 241.4rwkw
2007 BF Mk2 Winter White E-Gas Wagon, 6 Seater.
2002 AU3 XR6, Liquid Silver, Manual, Sunroof, LPG, Rebel Kit, BA GTP's, Momo Steering Wheel & Gear Knob.
GUTLES is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2006, 09:47 PM   #16
cArSiK
:nutsycuck this is not very constructive to your thread but they are not "side skirts" they are side protection mouldings :
cArSiK is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2006, 09:50 PM   #17
XR6-VCT-2000
Fantastic Plastic
Actually simon , even a can or 2 of the epoxy white in a can would do it np , would stick to plastic better than normal paint too without any sanding or anything , just heaps of coats of epoxy white , durable strong stuff too ;) .
:eclipsee_
Old 16-03-2006, 08:56 PM   #18
OZFORDAU
OZFORDAU's Avatar
Post Holes
Cause there are holes were the "side protection mouldings" go!
Simon
Old 16-03-2006, 08:56 PM   #19
OZFORDAU
OZFORDAU's Avatar
Talking
Sounds good!
Simon :sm_headba
Old 16-03-2006, 09:19 PM   #20
cArSiK
Simon
lol , thats better :
Old 17-03-2006, 03:23 AM   #21
chief
FTF Club Moderator
chief's Avatar
The door mouldings are one use only. I asked around and that is what I was told. You can use them again but just be a pain. I painted mine on the car. Just masked up everything and did it. Spent more time masking than painting.
Since you are going to paint the mouldings why not paint the back of the mirror caps. They pop right off. There is 3 clips behind the mirror. 2 on the outside, 1 on the inside near the glass.
Albert Einstein:
Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom.
(It is more difficult to alter a preconception than split an atom)
Falcon Tickford FPV (FTF) Car Club of NSW
Fords in the Park 2010
I use and recommend Stingray Car Security.
http://www.stingraycar.com.au/
chief is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2006, 04:05 PM   #22
XR6Stu
We pull moulds off and put them back on every day of the week at work. I garuntee it is easier to pull them off to paint than mask up on the car and do it.
Old 19-03-2006, 04:14 PM   #23
sfr rob
sfr rob's Avatar
did you get them off?
they were a pain to do on my au, the double sided tape from factory is a ***** to actualy remove off the door afterwards.
GOOOD LUUUUCCCKK
sfr rob is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2006, 02:32 AM   #24
OZFORDAU
OZFORDAU's Avatar
Talking Thanks
Nahh haven't tried yet...Hmmm yeh i saw the double sided tape when i pulled some of it back! It's friggin strong as!
Simon :nutsycuck
PS: Thanks for the good luck, i'll need it!
Old 20-03-2006, 10:14 AM   #25
XR6-VCT-2000
Fantastic Plastic
Run over the whole strip with the missus hairdryer really close until you get the strip nice and warm/hot , the tape just lets go then np , Dont use a heatgun or u'll probably fry the lot in seconds ! ..lol
:eclipsee_
Old 20-03-2006, 10:42 AM   #26
OZFORDAU
OZFORDAU's Avatar
Talking And to put it back on?
How do i put it back on then?
Simon
Old 20-03-2006, 05:47 PM   #27
XR6Stu
Make sure you have every single little bit of the old double sided tape off (or they wont stick back on) Give it a rub with a bit of steel wool or scourer where you are going to lay the tape. Lay the tape down back in the exact same spot where the old stuff was. Then stick them on, using the locators as a guide!
