Old 11-02-2018, 06:23 PM   #1
Default Tyre Pressure Monitoring System
I have been thinking of fitting wireless transmitting tyre pressure monitor valve caps to my car.
I would be interested if anyone here has fitted them, how accurate they found them to be and what brand they recommend.
Also once fitted, does it make topping up with air a hassle?
Thanks
Old 11-02-2018, 08:03 PM   #2
Itsme
Itsme's Avatar
Default Re: Tyre Pressure Monitoring System
We have Safety T tyre monitors fitted to our forklifts at work, after experiencing these I would never use aftermarket valve fitting sensors as they are PIA, sometimes slow leaks if you don't fit them properly and the monitor needs re-calibration every time you check air pressures.
Old 11-02-2018, 10:06 PM   #3
SensationFG8
I have tpms on one of my cars, very useful, especially if you have a slow leak. Fantastic on the track and they seem pretty accurate, not sure on brand as factory fitted.
Previous Rides
Bionic BA MKII XR6T 245kW I6 Turbo, 6spd Manual
Grey (yuk what was I thinking) AH Astra CDX Coupe 93kW NA I4, 5spd Manual
Sensation FG XR8 290kW NA V8, 6spd Automatic
Current Rides
Octane GTF SC V8, 6spd Manual, Manta 3" X pipes and hotdogs
Starlight Lotus Evora S 258kW SC V6, 6spd Manual
SensationFG8 is offline   Reply With Quote Multi-Quote with this Post
