Old 25-03-2006, 05:02 PM   #1
chich
chich's Avatar
Default Suspension Price Check
Hi guys,
Just wanted to compare what people have paid for their EF suspension systems. My car is going in for new suspension after easter and I just wanted to confirm that i'm not getting reamed too much. The package includes the following:
- Koni Yellow shocks (rebound adjustable)
- Reset my current sportsryder springs (5mm lower in the front, 20mm lower in the back, both springs are linear rate) Not too sure what reseting involves as yet but its not cutting..
- 30mm Whiteline front sway bar
- New bushes all round
Total cost including alignment, labour etc etc is $2K even (bear in mind the struts alone are $1,200). I understand that its relatively easy to fit struts/springs but i can't be bothered doing it myself and like most EF/ELs its chewing the front tyres so i want a decent workshop to go over it and rectify any problems.
Cheers,
Anth
chich is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2006, 05:21 PM   #2
1TUFFUTE
1TUFFUTE's Avatar
hey bud.
Cost me about 1200 and i got lowridershocks and springs (down 50mm) and all the bushes done in nolathene
1TUFFUTE is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2006, 05:43 PM   #3
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Sounds like a pretty reasonable price chich, the bush kit is around $500 as well.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2006, 06:19 PM   #4
chich
chich's Avatar
Originally Posted by 1TUFFUTE
hey bud.
What shocks are they? You say lowrider shocks - i'm assuming these are the shortend pedders struts??
Old 25-03-2006, 06:35 PM   #5
need psi
slow & low EA Ghia
need psi's Avatar
well worth it and a pretty good price. if there doing the all the bushes for that much its verygood.
Ehab
Ea Fairmont Ghia 1988
need psi is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2006, 06:42 PM   #6
chich
chich's Avatar
Ehab
They said they'll change the upper cambers bushes, lower/inner pivots and watts link bushes... is this all there is? Havn't had a chance to check the workshop manual as yet.
Old 25-03-2006, 06:44 PM   #7
1TUFFUTE
1TUFFUTE's Avatar
yeah ИИИ they are pedders shortend springs,sory dont know the proper name
No springs in the back of course its a ute with leaf springs but got 2inch lowering blocks an the lowrider shocks in the back.
I think u got a good price seeing as its getting installed by pros,my choice too :
Old 25-03-2006, 09:36 PM   #8
vegabass
BASS ON BOARD!
vegabass's Avatar
I got quoted $2200 for new pedders/koni shocks, some bushes in the front and upper rear trailing arms. inc labour and that comes with a new steering rack.
fitted by Pedders. (ill only get pro's to fit stuff now, otherewise it costs you later down the track)
hmmm this car game is expensive.
Nothing interesting to put here.
vegabass is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2006, 01:13 AM   #9
FPVWEPN
Team Urinal Cake Racing
FPVWEPN's Avatar
are you inadequate mechanically??? how does it cost you later on down the track???
FPVWEPN is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2006, 12:27 PM   #10
chich
chich's Avatar
I suppose it costs you when you fix something yourself and then have to go back and get the pros to fix it again. There's only so much you can do yourself with limited tools and facilities..
Old 26-03-2006, 12:55 PM   #11
xxxc
tuff
xxxc's Avatar
2k fvck......
.......................FG XR6 UTE...........................
......................xc fairmont gxl.........................
...................GQ coil cab UTE ..........................
xxxc is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2006, 01:25 PM   #12
vegabass
BASS ON BOARD!
vegabass's Avatar
I went on tour with my band for 3 weeks and when I came back I had new King Springs, Monroe Shocks and Nolathane bush's through 90% of the car. It wasn’t a professional suspension shop who did it. They are great with mechanical but not suspension. So 8 months later I’m faced with another 2k bill to get what I wanted the first time.
I’m happy to pay the coin as long as I know I’m getting Quality products with the professional installation.
Old 27-03-2006, 05:16 PM   #13
chich
chich's Avatar
Nothing worse than doing the same thing twice... p*sses me off. Like my old man says - if you're going to do something do it properly otherwise don't do it at all.
Old 27-03-2006, 05:48 PM   #14
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
I think it would be worse to pay for someone to do something, then have to pay them again to do the same job they stuffed up....
Having worked in a tyre store where we did alignments, suspension work etc, I would much rather learn about something and fix it myself than pay for someone else to do it, although it sucks if you don't have a shed to work in.
