Old 07-04-2019, 02:38 PM   #1
GASWAGON
Default Tech Question....Adjusting Turbo Boost????
O.k now i'm a Diesel mechanic by trade so i know exactly how simply any turbo works on a truck engine.
But, My question is about the Good old Barra I6T engine.
How exactly is the boost 'adjusted' on say a stock engine from say 2-3 psi up to 10, 15, 20psi and so on to pump out all the power you guys have been getting out of them?
Is it just more fuel which equals bigger explosion/burn???
I also realise bigger and different designed turbo's also help with the power gains.
GASWAGON is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2019, 04:55 PM   #2
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
Default Re: Tech Question....Adjusting Turbo Boost????
The ecu sends a signal to the wastegate solenoid to bleed off reference boost to the actuator
Pit Lane Performance
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2019, 07:33 PM   #3
foxtrot3
foxtrot3's Avatar
Hi. And if you try to cheat by using a bleed valve to get more boost the ECU sees that as a fault and cracks the sads. To do it the right way involves more fuel (bigger fuel pump and injectors and adjustable pressure reg) More cold air Turn up the boost (by telling the ECU what you want and fitting a bigger intercooler) and Modding the wastegate flap and exhaust to get rid of backpressure and still be able to control your boost. Cheers MD
HI
I'M MICHAEL
Old 08-04-2019, 02:50 AM   #4
GASWAGON
Awesome stuff guys that all makes perfect sense now.
Now I know what they'll be doing when i get my new BAXR6T project car tuned soon that i got cheap this morning... (needs a full $4K respray but is otherwise in perfect low kay condition!!!).
Old 09-04-2019, 08:26 PM   #5
GASWAGON
Project BAXR6T..........Mint Condition........................Coming soon.
May try for at least 300KW with basic CAI + bigger exhaust and bigger Cat mods + tuning for 95.
If I like, may try for 350-400KW.
This is gunna be FUN!!!!!!!!
Old 09-04-2019, 08:59 PM   #6
ratter
ratter's Avatar
You will a different list of mods
Old 10-04-2019, 10:11 PM   #7
Bolly47
My Tubro territory 08 getting nearly 20 psi no adusting Boost
Bolly47 is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2019, 09:06 PM   #8
GASWAGON
Project BAXR6T is getting fully payed for and driven home this Saturday afternoon on an un registered vehicle permit.
The tyres are still great but damn I hope the brakes still work after i do a few little speed tests........... LOL!!!!!!
