so brought some k shock coil over fitted them front went in fine adjusted fine the rear is a spring and a shock seperate so not a true coil over system my problem is the rear bottoms out on the bump stop its not to low its set to same height as from the only thing i car think of is the dampening settings any ideas?
G’day,
What model and spec is it? |
fg falcon xr6 08
![]() Join Date: Jan 2005
what ride height have you set the car? I'd suggest not going lower than 350mm hub to guard.
My Ford Family... 2014 GT-F, Manual, Kinetic with Black Stripes 2021 Mustang Mach 1, Manual, Velocity Blue |
