Old 05-11-2019, 10:49 AM   #1
jonny valentine
Angry HELP! au falcon ignition lock !!
hi to all-
first post- first aggro.
the ignition barrel fell apart on my au falcon- leaving the barrel switch in parts on the floor.. i looked at the wreckers and they spouted off some bs about 'changing the steering column."- i call bs on that.
who in here has the fix for it??
its like hyper urgent now- so cost effective, easy fixes will be required.
many thanks,
jonny v
jonny valentine is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2019, 11:05 AM   #2
Mechan1k
Mechan1k's Avatar
Default Re: HELP! au falcon ignition lock !!
With some of them ... the ignition barrel was integral to the steering column.
But I thought it was more a case of B-series that it was all integrated though.
Old 05-11-2019, 11:06 AM   #3
Mechan1k
Mechan1k's Avatar
Moving to the AU section where you will get more of an audience to assist here.
Old 05-11-2019, 11:11 AM   #4
Where are you located?
Old 05-11-2019, 01:00 PM   #5
Electrolyte Burns
If you are in Northern NWS look up Lismore Lock Shop.
Electrolyte Burns is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2019, 03:22 PM   #6
What year series AU?
You can buy new ignition barrels from Nice Products
e.g. https://niceproducts.com.au/feature/search-by-vehicle/ and https://niceproducts.com.au/feature/search-by-vehicle/
But it's usually the actual lock rather than the barrel the breaks and, if so, you will indeed need a complete new second-hand lock assembly which often does mean buying the whole column from a wrecker and they are getting harder to find.
You could try the people that do these https://fordignitionswitch.com.au/#buynow and https://www.frk1.com.au/ but I don't believe they have a kit for the series I AU and perhaps not the later series AU's either. In any event it sounds like your lock is broken in a different way (as the AU, EL and EF did) and a used lock assemble is required.
Old 05-11-2019, 07:01 PM   #7
Lee_123
The easiest way is to buy one on eBay. I bought one and found my problem was a spring broken in the ignition switch, behind the barrel. To remove the barrel I had to poke a small screwdriver in a hole beneath the metal casing. You have to remove the plastic shroud first.
The current price is $14.95 + $8 postage. You may be able to get express postage.
https://www.ebay.com.au/itm/NEW-IGNI...8AAOSwI8laMlam
Lee_123 is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2019, 07:15 PM   #8
Lee_123
If you also need to replace the ignition switch behind the barrel, you can get a kit for about $50 and replace it yourself. There is no need to remove the column unless your enjoy lots of unnecessary work. Here is a video on changing one on a Ford Territory, which is fairly similar.
https://youtu.be/XU8ft63hh24
Old 06-11-2019, 08:42 AM   #9
jonny valentine
gold coast
Old 06-11-2019, 08:50 AM   #10
OK, can’t offer suggestions of whom to see for parts/repairs but do you know the old school method of tapping the “anti-theft” bolt loose on the steering lock, with a centre punch?
It’s just a standard thread so when all is fixed you can use a standard bolt and Loctite to reassemble.
Tape the key head securely into the transponder ring around the ignition lock and you can then jump wire the ignition to operate.
Old 06-11-2019, 12:18 PM   #11
Per the second of the links I posted previously they only advertise for BA and BF ; I don't know they have an AU kit.
Old 06-11-2019, 12:29 PM   #12
Nice Products also sell new anti-theft shear bolts to fit e.g. https://niceproducts.com.au/product/nsb200-shear-bolts/
You can also cut a slot in the top of the broken off shear bolts with a dremel tool and cutting wheels and then unscrew them with impact screwdriver.
