Old 11-04-2006, 08:02 PM   #1
Sebastien
Default Fuel Gauge Problems
Hi All,
I know that this has been covered a bit, however no one seems to have metioned this.
My fuel gauge sometimes does the thing of jumping to full then to empty, or it just stays empty. If you drive long enough it will slowly work itself up to the correct level of whats in the tank. I have entered the diag mode on the cluster and I get strange results. When I did this I had a bit under half a tank of fuel, the 1 mode gave me 73L to start off with, with 176 as resistance, then when driving it was going crazy jumping all over the place, the resistance stayed mostly at 176 but changed occasionally.
The mode 7 started at 73L then after a bit of driving as the fuel gauge slowly started to come up from empty it slowly decreased in value.
So, does this all mean a sender fault or a gauge problem?
thanks
Sebastien
Sebastien is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2006, 08:16 PM   #2
Baboon_AU
Baboon_AU's Avatar
sticky float???
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2006, 08:34 PM   #3
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
Sender, sender, sender. Or at least replace it and see! Good Luck
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2006, 08:50 PM   #4
Baboon_AU
Baboon_AU's Avatar
or sender??
Old 12-04-2006, 12:00 AM   #5
Smoked
Burnin Rubber
Smoked's Avatar
got to agree, sender.
2001 AUII Forte (LPG)
K&N Air Filter
Tickford Air Intake
***Coming Soon: Clear Side Repeaters***
Originally Posted by The-ShowStoPPa
...dont get me wrong this 3.8v6 is pretty special, it does come with the popular shake rattle and roll option and the auto compliments this with the ever popular snap crackle and pop feature
Smoked is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2006, 07:42 AM   #6
Mechan1k
Mechan1k's Avatar
I replaced my senders and my floats ... and I still have the same issue.
Now it's tim to check the wiring harness for bad earthing ... then maybe time to test the gauge in the cluster.
Both my gauges on the LPG tanks are reporting the correct level ALL OF THE TIME.
It's really annoying me .... I just make sure i don't go over 500km per fill and I am right.
It's hard trying to troubleshoot this problem.
Seeing as the gauges (on the LPG tanks) are reading correctly ... the floats are fine.
Most of the time mine sits on empty with the fuel light on ... then it creeps up to full ... then when i start the car it sits at the correct level ... thne it starts dropping after about 10km of driving.
Meh ... I'll sort it out one day.
For me though ... I am looking toward more of a Instrumentation cluster issue.
Old 12-04-2006, 08:07 PM   #7
smally289
growing up is optional
smally289's Avatar
See if this helps .......
smally289 is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2006, 08:16 PM   #8
GK
Walking with God
GK's Avatar
I don't think that helps myself and mechanik1 as were running on gas!
Sebastien though, may just be running on petrol. It could be of great use to him!
I appreciate the post though, and have added it to my ever growing AU Info files!
Cheers,
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 13-04-2006, 09:18 PM   #9
Sebastien
thanks all.
Looks like I'm up for a new sender!
Sebastien
