Old 13-04-2006, 09:07 PM   #1
EDXR6T
Default XF T5's and E-series box's
hi all
time to set some thing's strait
ok well i'v heard from some ppl that EB2 box's are stronger and have a longer first gear ther for less strain on the box
and EA T5's ante as strong due to they'r short first gear ther for more strain on the box (housing) and thay'r more prone to craking
but i was told that XF thru to EL are the same :P
beside's the EL shifter stork
i was deffending the point that it change'd EB2 onward's
but he was very reluctant and sure thay are the same:P
so some clarification would b great
cheer's fella's
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2006, 09:11 PM   #2
RavenLS1
a ea has a shorter first gear than eb onward
405rwhp LS1, FG XR6T Ute manual, VE series 2 Omega LPG.
RavenLS1 is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2006, 09:35 PM   #3
ilsautomotive
Former E-Series Member
I understand that EF onwards has synchro on reverse too. They are certainly not all the same from EA-EL.
ilsautomotive is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2006, 09:39 PM   #4
Damo
EB2 has a syncro reverse.
Damo is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2006, 11:45 PM   #5
old_mate
Smash the Boost
old_mate's Avatar
In the driveline tech section, WBT56 made a post outlining all the differences.
From the master himself
Posted by wbt56, talking about swapping of input shafts
Cannot be swapped. There are 22tooth 10 spline in XF-EF, 23 tooth 10 spline in EB-EF, 23 tooth high helix 10 spline in EF-AU, 23 tooth 23 spline high helix in BA, 24tooth 10 spline in EB-EL, 24 tooth 10 spline in AU, 24 tooth 23 spline in BA. There are also length variations. BA T5 will not fit in '97 model anyway. Ben.
Might not answer totally, but should be of some help
2023 Hyundai Palisade
1971 Fairmont Sedan
1974 SWB F100
Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
old_mate is offline   Reply With Quote Multi-Quote with this Post
