What sort of weights a people towing with there auto EL'? I need to tow about 1900kg, and what type of mods have you done to tow heavy loads[car has 2300kg tow bar].
Make sure it has a decent transmission cooler. The factory ones are pretty marginal for towing.
EF Falcon Sedan 5.0 auto with IRS "the man that crashs AFF" |
windsor user
decent rear shocks, the biggest trans cooler that you can fit if you plan on towing with the car a lot, load distributing hitch / load leveling bars to keep the trailer and car level.....
and make sure the trailer has decent brakes!
So it can be done, the trailer has the double axle [4 wheels] just drive safely I guess. Anyone else offer there advise or experiance on towing? I guess towing a car trailer with a car on it adds to about the same load.
Thanks for the replys. |
windsor user
allow WAAAAY more brakeing distance.... WAAAY more room if you HAVE to overtake .(try not to if you dont really need to.....)
just take your time and you'll get there...dont overstress your car.... you'll get a feel for what speed you car likes to do (usually somewhere between 80 - 100kph is a nice sweet spot)...... dont push it or you'll use heaps more fuel |
#7 | |||
Over here in SA we have to put brakes on our boat trailers by 30 december 2006.
went and got a price from a trailer manufacturer they quoted 800 dollars. no pensioner can afford that. |
#9 | |||
windsor user
maybe they're just making it "compylsory" now.... it might be more cost effective for you to sell your trailer and buy a seccond hand trailer with brakes fitted..... Last edited by LUXO_8; 25-04-2006 at 05:50 PM. |
The 'Stihl' Man
![]() Join Date: Jan 2005
well bugger me..I never knew trailers had brakes....lol
#11 | |||
likes falcon's
nah, it works on weight, wen u slow down the trailer pushes against the car, thus engaging the brake.
i wouldnt advise towing to much with later model cars, thiner body designs= more stretching, ie, look at the rear doors after u do plenty towing and see yourself.
www.carhubsales.com.au |
#13 | ||||
windsor user
A dont stuff up as much with water and B dont engage as you reverse the trailer.... Quote:
#14 | |||
#15 | ||
likes falcon's
i was refering to old xa-xc, what a towing shell they have :P
#16 | ||
Maybe if falcons were FWD they might!
#17 | ||
Gunna girlie-man
i would reccomend getting a v8. towing 1900 kg often, will kill the 6 cyl engine quick
WADE CAMS-- UNLEASH THE POWER!! <INSERT WITTY SIGNATURE HERE> Daily- 05' BA futura... work done. Cruiser- 85' VK berlina... more work done ![]() ![]() |
#18 | ||
likes falcon's
how does it kill the engine, i reckon the transmission takes more of the blow..?
#19 | |||
windsor user
#20 | ||
likes falcon's
trannies are differently geared to tho?
#21 | ||
in SA if what you are towing is over 750kgs then brakes must be fitted.
#22 | |||
windsor user
#23 | ||
Thanks for all the advice, tomorrow I will be picking up my ship so I hope all goes well. I have spent a few $$$$ on the car to get it ready, new Bridgestone b530, PWR trans cooler 280x255x19mm, trans service [that was a rort] Rees towbar, [its about 30kg on its own] 4 x cross drilled and slotted disks + pads, new HD radiator 3 core. Total towing weight is about 1720 kg so not as much as first thought anyway I will let you know how it feels to drive.
#24 | ||
windsor user
excelent....good to see someone with a little bit of sense, actually getting their car set up to tow with...
no good trying to tow like this http://www.fordforums.com.au/showthr...ghlight=morons another little towing hint. please dont let your chains drag on the ground... actually, the chains should be crossed over, to form a cradle to catch the trailer incase it happens to come off the tow hitch....... this will stop the trailer from digging into the road surface and flipping / spearing off ino other traffic, etc... |
#25 | |||
#26 | ||
windsor user
it should sit just fine - especially if the weight has been well balanced throughout the boat and the trailer is propperly matched with the boat....... but if it doesnt, get yourself some levelride bars.... or better yet talk to the guys at pedders and see what shocks and springs they reccomend... it really comes down to what percentage of time the car will be towing or not as to weather you change your suspension to compensate for it
my aunty has had the rear of her NC set up for full time towing, (heavy duty shocks and springs) and it looks so funny compared to my car.... but she tows horses just about every day and i dont so.... http://img.photobucket.com/albums/v6...baltNC2005.jpg |
#27 | ||
Formerly XG-Panelvanman
just a thought, if u are towing a boat (going by what u said) and i u do intendto use this car to to it with, rember that if you intend to launch and retrive the boat from the water, there will be a lot more load put on the engine/trans when pulling up a steep ramp.
my old man reckons with the i6 boxes, to tow in 3rd so it cant go into overdrive, dunno if its true or not, but seems to work for his au3
My Ride: BA MK2 Wagon, dedicated LPG, white. modifications: cargo barriers, tow bar |
#28 | |||
trailers in qld only need brakes over 1000kg...an i tow about 800 every day |
#29 | |||
#30 | ||
In my wagon set up for heavy loads I have coil springs with airbags running inside my leaf springs as well as electronic trailer brakes. Tows like a dream even with 2+ tonnes.
cheers Scott |
