#1 | |||
Looks like some in the industry are ready to have another go at brake-by-wire. Let's hope it is not another repeat of the 2005 Mercedes-Benz Sensotronic Brake Control (SBC) saga.
A brake calliper is a harsh environment for any electrical device. Lots of heat, vibration, and exposure to water, mud, dust, etc. It will be interesting to see what the as constructed components looks like. https://www.goauto.com.au/news/gener...-24/95937.html Quote:
3 users like this post: |
Arnt brakes meant to have a redundancy?
If you lose hydraulics you can still brake (dual circuit), if you lose vacuum you can also still brake. On an electric system if you lose electrics...?
2 users like this post: |
![]() Join Date: Jan 2005
Car in front is the backup system...
I love Holdens.... |
You can always pray!
The first thought in my head re weaknesses was not specifically electricity supply, but corrupt instruction of the system - whether by fault or hacking. |
#5 | |||
For example, in large electrical substations the "protection" schemes (i.e protection relays, wiring, circuit breaker trip coils) are all duplicated. There are two sets of substation batteries, independent wiring following separate paths, two sets of protection relays, and two independent trip coils. Just guessing here ... I imagine that in an electrical brake system for a car, it would possibly entail two sets of wiring out to the calliper, via two separate connectors. Considering the battery as one power source and the alternator as the other power source. Dual position sensors on the brake pedal. Maybe even having a primary and backup computer for the brake controller. The bit that intrigues me is how the calliper is built and how the wiring loom goes out to it. I suppose that ABS speed wheel sensors have a good reliable history by now (and they operate in a similar environment). It will be interesting engineering. Mass produce a cheap and reliable braking system. |
RR had a pretty comprehensive redundancy on their brakes for the Shadow and Spirit; two fully independent accumulator “powered” circuits fed each caliper and there might have been a regular (unboosted) master cylinder behind at least one of them as well. All they were missing was a RAT.
As the electric braking units are likely to be compact, I’d prefer to think there were equivalent allocations to a typical Brembo spec upgrade (4-6 motors per front caliper and 2-4 per rear), but on two parallel systems at least, and perhaps an hydraulic circuit with doseur valve plus accumulator for true emergencies. I’d feel pretty uncomfortable with it otherwise. |
Another vague article that doesn’t really go into specifics.
So each caliper has its own motor or actuator and control module? No power to individual brake actuator or thrown fault code = caliper locked on as failsafe. Have been told something like that is in the pipeline in Europe for heavy vehicles, if they have an active EBS/ABS fault the park brake won’t release.What a great idea. |
EMB brake system would be ideal to replace the horrible electric brakes used on caravans and trailers.
And that would include, ( I hope ) a brakes on fail-safe when the backing plate hits the disk , to prevent people driving past that point
Oh no , thinking about it,,,, that is a bad idea,,,, to stop people on a highway,,,, ,too dangerous Eg , the M7 , no stopping lane
Fords are cool ![]() Last edited by 123Cat; 28-03-2025 at 10:38 PM. |
IMO another solution to a non existent problem much like drive by wire as far as I'm concerned
