Old 17-06-2006, 04:10 PM   #1
mattp
mattp's Avatar
Default Tickford Cluster Issues
Hey all, I'm hoping someone will know the answer to this little problem that's come up. I've had a bad week with getting stuff to go right on my car! I picked up an AU1 XR Cluster yesterday and put it in the Fairmont today, and it works, but only to a certain extent. All the lights behind the odo rectangular display bit flashes continuously, unless I turn the parkers or lights on, in which case is stops flashing. PLUS, the trip computer unit seems to be not working, everything in it (km to empty, km/L etc) is just on zero, and doesn't change when I drive, and the overspeed alarm doesn't make any noise any more, it just flashes when I go over. I figure maybe the XR's didn't have a trip computer so this doesn't work, but how can I get it to work? This is really frustrating, cos the cluster looks awesome, but I don't want to give up my trip computer and the flashing is just not on. AND, I just remembered, when I open any of the doors, the unit tells me that they're ALL open. Could this be a Smartlock / Smartshield issue, with the differnt BEM? It still locks and unlocks as normal with my remote though (I've got an early one - Smartlock). Is there any fix or workaround for this? HELP ME PLEASE! I know some of you guys have done some pretty clever stuff with clusters, so hopefully someone knows a trick or two! Thanks in advance, Matt.
mattp is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2006, 04:14 PM   #2
FTGAutosalvage
Commercial Sponsor
FTGAutosalvage's Avatar
is your fairmont a series 1 or 2??
FTGAutosalvage is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2006, 04:17 PM   #3
mattp
mattp's Avatar
My car's a series one fairmont, and it's a series one cluster (black face, tickford wings). I was thinking (maybe somewhat hopefully!) that'd it'd plug in and all work perfectly.
Old 17-06-2006, 05:33 PM   #4
Duffman
Oh Yeah!
Im not sure about fairmont but I know with forte you need to change some wires. With the fairmont clusters it shows you which door is open when you open it but the xr cluster will juts light up and show all doors open which is normal. Clusters can be a pain to stuff around with but im sure yu will work it out
Oh no! Duffman can't breath! Oh, yeah!
Duffman is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2006, 05:59 PM   #5
mattp
mattp's Avatar
Yeah, I found a document with all the differences between Low Series, Sports (Mid) Series and High Series. The XR's didn't have the individual door sensors, or boot or fuel door sensors which the Fairmonts/Fairlanes did, so the door thing is understandable, anyone got any ideas on the flashing or the trip computer though?
Old 17-06-2006, 05:59 PM   #6
howesy
howesy's Avatar
I could be wrong but there are high series clusters and med and low series. Fairmont if you say showed individual doors open would more than likely be high series which would be the likes of Tickford TE50 cluster. If the Normal XR Tickford cluster only shows doors open in general it is more than likely a medium series and given that the TE series were based on Fairmont and XR based on Falcon I would lean toward this. There are some wiring changes that need to be made to get all the high series functions happening in a lower series car but I'm not sure with yours. if you have a lower series cluster in a higher series vehicle(fairmont) you may never get all functions due to the restrictions of the cluster. Do some research and you may find this is the case. good luck I hope you find a solution. See Info below from ford mods.
AU Mid Series (Sports XR) Cluster
PLEASE NOTE : The above cluster is an AU Series II - NOT an AU Series 1 XR Cluster ! The AUI Mid Series Cluster (XR Sports Cluster) on the AUI Models, is a combination of the High Series Instruments, and the Base Series LCD Panel
The AUII and AUIII Mid Series Instrument Cluster (XR Sports Cluster is the same as the High Series Cluster, with exception to the Door Ajar Warning, which will Illuminate all the Doors on the Display, if any door is opened.In addition to these features, the XR Cluster features a Unique Tickford emblem located on the Speedo, above the Needle.
The AU Mid Series Cluster has the following Features
White Illumination, with Orange Coloured Cluster Needles
Tickford Logo Located on the Speedo Dial, above the speedo Needle
240Km Electronic Speedo, with 20Km Speed Numeral Markings, and 5Km Line Markings
7000 RPM Tacho, with 1000RPM Numeral Markings, and 250RPM Line Markings
Fuel Guage with Electronic Dampening with Low Fuel Warning Lamp
Temperature Guage, with high Temperature warning Lamp
Battery Voltage Guage, Ranging from 10 to 16 Volts
Oil Pressure Guage
Seatbelt Warning Lamp
Smartlock(AUI Early Build) or Smartsheild (AUI Late Build and onwards) Warning Lamp
Park Brake Warning Lamp
Brake Fail Warning Lamp
ABS Warning Lamp
Turn Signal and High Beam Indicators
Lights on with Ignition off warning lamp (ON LCD Panel)
Low Oil Warning Lamp
Alternator Warning Lamp
Low Coolant Warning Lamp
Door Ajar Warning on LCD Panel (Non Door Specific)
Air Bag Fault indicator
Auto Transmission economy Mode Indicator
Transmission Gear Position Indicator on LCD Panel (AUII-AUIII Models)
Cruise Control Indicator (where fitted)
Speed Warning Indicator and Buzzer
Traction Control Indicator (Where Fitted)
Low Windscreen Washer Fluid Warning
Distance to Empty Calculation and Warning
AU (High Series) Cluster
The AUI High Series Cluster (Fairmont, Fairlane, LTD Cluster)
Uses the same shape Instrument Dials as the Mid Series Cluster, but has a unique LCD Panel, that includes a Door ajar, Boot open, and Fuel Flap Open Warning. This warning system utilises a Diagram of a sedan, and shows which door, (Driver's, Passenger, and Back Doors, indepentant of each other, much the same wasy as the EA-ED-EF-EL High Series Instrument Clusters Door Ajar Warning system works.
The AUII and AUIII High Series Instrument Cluster has the Automatic Gear Position located on the main LCD Panel, whereas the Series 1 Models had this display on the Speedo Instrument Guage.
The AU High Series Cluster has the following Features
White Illumination, with Red Coloured Cluster Needles
220Km Electronic Speedo, with 20Km Speed Numeral Markings, and 5Km Line Markings
Oil Pressure Guage
Smartlock(AUI Early Build) or Smartsheild (AUILate Build and ownards) Warning Lamp
ABS Warning Lamp
Door Ajar Warning on LCD Panel (Door Specific)
Boot Open Warning (Sedan Only)
Transmission Gear Position Indicator on seperate LCD Panel under speedo (AUI Models)
Upgrading and swapping Instrument Clusters
With exception to the Low Series Instrument cluster, it is possible to change between different Cluster models rather painlessly.
All AU Series 1 Instrument Clusters use the same Electrical Connectors, (2 Connectors), but for the Low Series Cluster, some wires need to be moved around for the Left Hand Side Connector, In order for the Mid/High Series Cluster to function correctly.
The Mid, Police and High Series Clusters all use the same connectors, same Bulb holders, same needles, and Depending on the Cluster Series, very similar/Same circuit boards.
The AU Series I Mid and High Series Clusters use a different LCD Panel, but the wiring (With Exception to the extra Door Outline Wiring) is 100% Compatible.
That is, if swapping a Mid Series Cluster for a High Series Cluster, you will need to run new wiring from all 4 Doors, to the Instrument Cluster Wiring Harness
Some important steps to watch out for when doing an Instrument Cluster conversion will include,
1. The Odometer Reading will need to be changed. (Remember your Pinkslip will have this reading on it from your previous years Registration - There is a $10,000 fine for Fraudulantly Winding Back your Odometer Reading.)
2. If Upgrading from a Base Instrument Cluster, The Oil Pressure Switch will need to be replaced with an Oil Pressure sensor.
4. If adding the Low Windscreen Washer Level Warning Lamp, a new Washer Bottle, with Level sensor, and an extra line will need to be added for the Warning to work.
Some Common misconceptions with the Ford Falcon series Clusters include
1. The Odometer Readings can be swapped, changed or kept. The Odometer Reading is held within the Instrument Cluster, not within the EEC-V Engine Management, nor does the Instrument Cluster have a Backup Memory, or a Tamper-proof mechanism to deter Odometer Fraud !
2. There is no Electrical, or Calibration Difference within the speedo sections of the cluster, in terms of different Factory fitted Diffs, wheel, and Tyre Ratios. Changing Clusters will not alter the Factory speedo readings.
3. It is not possible to use an XR Series II Face, on a Low or High Series Cluster ! This is due to the Maximum speed on the cluster face, which means that the speed increments are slightly compressed.
The XR Series Cluster circuit board takes this compression in consideration when moving the speedo needle, and as such, you would need to swap the complete cluster over to use the XR Face.
Wiring changes required when fitting a Mid/High Series Cluster to a Forte/Futura Model Falcon.
Although the Mid and High Series Clusters will simply plug in, and A L M O S T function, there a re a few changes you will need to make, in order to get the Cluster to function correctly.
These changes are needed in order for the following to function,
Dial Illumination with Park Lamps On
The ABS Warning Lamp to Illuminate correctly
The Right Hand Side Indicator Lamp to function Correctly
The following wires need to be moved around, in order for the Mid/High Cluster to function correctly,
1. The Park Lamp Dial (+ Positive) Illumination needs to be moved from Pin 13 to Pin 2.
2. The Dial Negative Dimmer Illumination needs to be moved from Pin 21 to Pin 3.
3. The ABS Warning Lamp Wire needs to be moved from Pin 8 to Pin 23
4. The R.H. Side Indicator wire needs to be moved from Pin 19 to Pin 26
Please Note : In addition to these changes, you will need to also change the Oil Warning Switch, to an Oil Pressure sender unit, and also swap the Odo Reading.
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2006, 06:10 PM   #7
mattp
mattp's Avatar
Thanks Howesy, are you still selling the TE50 cluster?
Old 17-06-2006, 06:21 PM   #8
howesy
howesy's Avatar
I P.M ed you.
by the way go to the link I showed and keep scrolling down and it shows all the pis and wires on the clusters and what they are for to make things easier. hope you get some useful stuff.
Old 17-06-2006, 06:40 PM   #9
JC
Miami Pilot
JC's Avatar
Series 2/3 TE was XR based cluster. TS was fairmont based.
Ford Performance Club ACT
Old 17-06-2006, 06:59 PM   #10
howesy
howesy's Avatar
matt has series one. Exctract from above taken from technical documents.-:
Old 17-06-2006, 07:10 PM   #11
howesy
howesy's Avatar
Check your PM's again matt
Old 17-06-2006, 11:20 PM   #12
12
Silhouette AU1 TS50.
12's Avatar
JC, series 2 TE50 was Fairmont based, same as series 1 TE50. Only the series 3 TE50 was XR8 based.
"People can have the Model T in any colour.. so long as it's black." HENRY FORD (30/07/1863 - 07/04/1947)
PIC'S OF MY
T1 TS50.
12 is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2006, 11:30 PM   #13
12
12's Avatar
mattp, to stop the LCD flashing you need to adjust the brightnes of the cluster. The XR's had a 2 position illumination switch, and your Fairmont is probably set on a too low of a voltage for the XR cluster. Move the brightness switch up a little and the flashing will stop.
PIC'S OF MY
T1 TS50.
Old 18-06-2006, 02:26 AM   #14
mattp
mattp's Avatar
Thanks so much, this forum is a goldmine of information! Cheers, Matt.
Old 18-06-2006, 10:35 AM   #15
GK
Walking with God
GK's Avatar
PM Sent.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 19-06-2006, 06:46 PM   #16
mattp
mattp's Avatar
I got the flashing to stop, as suggested it was just a matter of turning up the brightness! Anyway, the cluster is now for sale, I like my trip computer too much, so if any low series owners want to buy it, see the sales section. Cheers, thanks again for all your help, Matt.
Old 20-06-2006, 11:43 AM   #17
janek
Ripping it up
Default cluster
Originally Posted by howesy
I P.M ed you.
Hey mate, i was wondering if that te cluster was S1 or S2?
janek is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2006, 05:53 PM   #18
mattp
mattp's Avatar
Series 1
