Old 28-06-2006, 01:18 PM   #1
syktlr
stktlr
syktlr's Avatar
Default almost finished please help
nearly finished my mpfi convert but a few questions,there is a small rubber pipe coming from the bottom of the inlet manifold on the motor side, where does that go?, does it go to the purge canister maybe and if so is i on the top or bottom.next question is the fuel lines does the inlet one go on the rail and the other on the purge canister(top or bottom).there is also a rubber pipe coming from the inside of the manifold next to the red pipe that goes under the left wheel arch.it goes towards the front where does that go?thanks : :
syktlr is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2006, 01:34 PM   #2
syktlr
stktlr
syktlr's Avatar
ahh is the pipe near the red one go to the pcv valve on rocker cover
Old 29-06-2006, 11:41 AM   #3
syktlr
stktlr
syktlr's Avatar
Default help
help anyone :
Old 29-06-2006, 04:33 PM   #4
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
um if it is the one that is towards the back of the manifold under it on the engine side on top of the air temp sensor that goes to the map sensor. the inlet for the fuel rail is a pipe that runs underneath the rail and the connects to the rail at the front the out let is where the furl pressure reg goes on to.
pic's would be a good idea mate.
tristan
BLUEPOWER RACING DEVELOPMENTS
Strive for perfection in everything we do. Take the best that exists and make it better.
When it does not exist, design it. Accept nothing nearly right or good enough.
-[BLKPHN] (VIC) PLATES FOR SALE $495.00-
BLKPHN is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2006, 05:14 PM   #5
syktlr
stktlr
syktlr's Avatar
thanks mate lucky i asked, where does the breatherpipe from the back of the rocker cover go is it down onto the 3 piece white plastic on the manifold next to the firewall.
Old 29-06-2006, 06:05 PM   #6
John_LS1
no, it goes to the throttle body.
Old 29-06-2006, 06:35 PM   #7
syktlr
stktlr
syktlr's Avatar
thanks for the help
