Old 29-06-2006, 02:23 PM   #1
cookie
BEER I NEED BEER
cookie's Avatar
Default changing au2 to manual
hey all just a couple of questions on this. i have just about all the stuff to do the job now just wondering with the wiring for it is it all there to plug in or what, on the pedal box i have there is a sencer on the clucth pedal where does that plug in? and with the wires on the actull box do they all plug into plug alredy there? i have also herd you need to wire in the reverse lights how do you go about this? and also does any one know anywhere in logan, brisbane or goldcoast that can redo my auto ecu to run the manual? has anyone actully done this change themselvs not by a workshop?
worked hard to get my new beast and i love it, it rocks. MYR16 the beast
cookie is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2006, 08:02 PM   #2
robbo_yobbo
Kick out tha Jams
robbo_yobbo's Avatar
mine was done at a workshop - and im glad it was, there was a stack of messin around with the electrical side of things and the number of times they had to call out the auto electrician ended up costing them more than I paid them!!!
having said that GOOD LUCK!
$416.80.......All that cash came from a new (used) car. Check your back seats!
robbo_yobbo is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2006, 09:27 PM   #3
cookie
BEER I NEED BEER
cookie's Avatar
thanks how much did it cost? i will alredy have all the stuff
Old 29-06-2006, 10:59 PM   #4
robbo_yobbo
Kick out tha Jams
its a bit hard to say as the price i paid included the gearbox + motor price which was $3000 all up installed, whereas on thier own they wanted $1850 for the gearbox and $1650 for the motor not including labour (bizzare pricing, cheaper to have it installed!).
Have a good phone around as prices varied HUUUUGELY from place to place. the next cheapest I found for a conversion if I provided the parts surprisingly enough was profix for $1000!!!
I would be surprised if you couldnt find somewhere to do it for under $500 in brizzy if you do the homework 1st.
Old 30-06-2006, 01:08 PM   #5
cookie
BEER I NEED BEER
cookie's Avatar
thanks heaps for that mate
Old 30-06-2006, 01:19 PM   #6
justa6
justa6
justa6's Avatar
there are 2 little flat plugs on the side of the manual for your reverse. the speedo is a 3 wire triangle looking plug.
justa6 is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2006, 05:36 PM   #7
chief
FTF Club Moderator
chief's Avatar
PM LG. He has done this conversion.
Albert Einstein:
Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom.
(It is more difficult to alter a preconception than split an atom)
Falcon Tickford FPV (FTF) Car Club of NSW
Fords in the Park 2010
I use and recommend Stingray Car Security.
http://www.stingraycar.com.au/
chief is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2006, 11:08 AM   #8
cookie
BEER I NEED BEER
cookie's Avatar
thanks guys you help is much appreciated
Old 01-07-2006, 01:03 PM   #9
EvilChief
Boost Addict
the speedo one is the only plug that will match straight up, reverse switch wiring is within the big plug which also includes all the solonoids. need to look for the neutral switch wires in order to hotwire it
before you put ur pedal box in, double check all ur welds, especially the one on the clutch pedal, as that one is very common to break. its much easier to reweld it while its out of the car
the sensor on the clutch pedal is for cruise control, if u do have CC, you can crosswire it to the sensor on the brake pedal or simply ignore it
as for ecu u do not need to change it if u lock it into neutral.
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build)
Ford BA XR6T Ute - daily driver
Ford FG XR6T Sedan - cruiser
do you see a general trend? I DO
Can't live with it, can't live without it!
EvilChief is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2006, 01:27 PM   #10
cookie
BEER I NEED BEER
cookie's Avatar
thanks for that evil and thanks for the pm too very helpfull
