Old 24-09-2006, 05:12 PM   #1
poolkeeper
Its Resonating!
poolkeeper's Avatar
Default The biggest pod that will fit?
Anyone know the dimensions or product that would fit into the airbox, Ive done a search but cant really find anything thanks....
poolkeeper is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2006, 05:15 PM   #2
au^dude
au^dude's Avatar
Depends on which airbox you mean
au^dude is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2006, 05:18 PM   #3
Smoked
Burnin Rubber
Smoked's Avatar
Standard flat filters seem to flow relly well in AU's as it is, I would leave it as that.
2001 AUII Forte (LPG)
K&N Air Filter
Tickford Air Intake
***Coming Soon: Clear Side Repeaters***
Originally Posted by The-ShowStoPPa
...dont get me wrong this 3.8v6 is pretty special, it does come with the popular shake rattle and roll option and the auto compliments this with the ever popular snap crackle and pop feature
Smoked is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2006, 05:20 PM   #4
poolkeeper
Its Resonating!
poolkeeper's Avatar
Standard au airbox
Old 24-09-2006, 05:20 PM   #5
poolkeeper
Its Resonating!
poolkeeper's Avatar
I want the induction noise everyone is getting :thebirds:
Old 24-09-2006, 05:21 PM   #6
au^dude
au^dude's Avatar
I have put i think it was 11 inch in mine, just fit. Pain in the **** to do but. Better to just get 8 inch one. Fits better
Old 24-09-2006, 05:28 PM   #7
xr8ute
Back on the road
xr8ute's Avatar
Then use the flat panel, and cut an extra hole in the front of the airbox.
How is the air going to get into the "biggest pod filter that will fit" if there is no space left around it in the airbox... ;)
AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute
5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor.
Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash.
xr8ute is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2006, 05:31 PM   #8
au^dude
au^dude's Avatar
There is pleanty of room, its 11 inch long not wide so it has room. It also helps if you have a hole at the front of the airbox to get some more air from behind the headlight
Old 24-09-2006, 05:32 PM   #9
poolkeeper
Its Resonating!
poolkeeper's Avatar
Ive already cut the hole, want more, lol....
Being resonable about the size ofcourse, I know wat u mean though, no good blocking the flow with a huge pod :
Old 24-09-2006, 05:37 PM   #10
au^dude
au^dude's Avatar
So den go with the 8 inch one. Most people have those ones
Old 24-09-2006, 05:45 PM   #11
JC
JC's Avatar
Then. A den is where lions live.
Pod in a box is a waste. It's actually no different (on my car, anyway), to having a flat panel K&N. Ther BA Pod setup, on the other hand, is well worth it, and the ultimate is the G&D airbox or similar.
For an AU, you need the biggest filter you can fit - I believe G&D use a 4" opening, and the filter is around 10" long.
Ford Performance Club ACT
Old 24-09-2006, 05:48 PM   #12
poolkeeper
Its Resonating!
poolkeeper's Avatar
I was looking at getting one of these if I wasnt going to get a pod, they look awesome. But the price....
http://www.bmcairfilter.com/infoCDA.asp
Old 24-09-2006, 05:53 PM   #13
JC
JC's Avatar
How much would you like to pay for one? I have one in the garage taking up room - I don't have any piping for it though, but you can get 1m lengths from Autobarn etc for around $25.
The one I have is:
Code : CDA85-150
Price (US $): 258.35
D1 (mm) D2 (mm) L1 (mm)
85 150 200
CARBON DYNAMIC AIRBOX
SUGGESTED OVER 1.600 CC
Old 24-09-2006, 05:57 PM   #14
poolkeeper
Its Resonating!
poolkeeper's Avatar
Are they any good?, you have the ba airbox on your cars, spose they are quite the same?
Old 24-09-2006, 06:00 PM   #15
JC
JC's Avatar
They look great and sound awesome. I had the car dynoed with the BMC CDA on and it was roughly the same as running no filter, so they seem to be OK (though no filter was only 2rwkw difference to standard airbox).
Old 24-09-2006, 06:02 PM   #16
poolkeeper
Its Resonating!
poolkeeper's Avatar
Can I ask why your not using it?
Old 24-09-2006, 06:07 PM   #17
JC
JC's Avatar
I had it on the XR8, and when I went LPG, I was advised to go back to standard airbox due to the need to fit a balance pipe for the gas. I have since replaced that with the BA setup, as it allows proper fitment of the balance pipe, while retaining a Pod filter.
I did have the CDA on the Forte for a while as well, but replaced that with the standard airbox (and now BA pod) when I was chasing up an intermittent miss (set everything I could back to stock). Turns out the miss was coilpack, not air intake related, so the CDA has just been sitting around in the box. I keep meaning to throw it on ebay.
Old 24-09-2006, 09:47 PM   #18
Casper
Contributing Member
Casper's Avatar
As JC said, a pod in the standard box is a waste. Been there, done that, lost power. If you want to keep the std airbox then a flat panel filter is the way to go. If you feel you MUST get a pod and stick it in the box, get a foam filter (finerfilter make great ones). That will give you the best compromise (and probably a hp or 2 more).
Older, wiser, poorer.
Now in Euro-Trash. VW Coupe V6 4motion.
Casper is offline   Reply With Quote Multi-Quote with this Post
