06-10-2006, 01:24 PM | #1 | ||
Hi,
Recently just repaired an AUS2 Tradesman ute, the fuse's were screwed and the front of the motor ******, so we put an AUS1 motor in, and changed it to an AU S1 Loom, keeping the S2 ECU. Now it wont start via the key, it will start if run a wire from the relay to positive but yeah. Any Ideas? |
06-10-2006, 01:31 PM | #2 | ||
You need to get the ECU coded to the new BEM. Only Ford can do this.
06-10-2006, 01:45 PM | #3 | ||
Is this even with the orginal ECU out of the car before the motor swap and the same key and BEM?
Basically we swapped motors and the loom, nothing else |
06-10-2006, 03:11 PM | #4 | ||
ok fixed, it was a wire under the dash had been cut, well a few, it must of had an aftermarket alarm in it, and they have ripped it out before it went to auctions, thanks for your help anyway JC
06-10-2006, 04:00 PM | #5 | ||
Was V6corp
But because of build dates etc...,
isn't it illegal to put an older motor, in a newer car?
Car: 99 AU I Forte Sedan Colour: Blue Engine Mods: K&N Pod in a XR8 Pod Box; Performace fuel pump; 2 1/2" Exhaust Planned Engine Mods: ; Extractors; Tickford CAI; Twin Mufflers; Shift Kit; Hi-Stall; Cam; ECU Flash Bling Mods: Tinted Windows; JVC CD/DVD HU Planned Bling Mods: TS50 Front; High Series bonnet; Rebel Skirts and Rear Bar; SL Springs; Clear Side Indicators; Rear Spolier; Mags |
06-10-2006, 05:07 PM | #6 | ||
everything is the same execpt engine number, it all works now,
06-10-2006, 06:13 PM | #7 | |||
06-10-2006, 07:31 PM | #8 | ||
Put it this way, everything is the same between AU1 and AU2 motor in the way of part numbers just the orginal one was stamped 00 this one is stamped 99 and it has a differnet number
If anythings going to stop it it will be the VIV |
