04-10-2006, 09:10 AM | #1 | ||
Hey All,
Im looking to replace the 5 speed on the ea when i get my AU Engine. I was just wonderig in ur opinions which would be the best to bolt on.. in recent threads ive heard the ea 5 spd is crap :P cheers nicko |
04-10-2006, 10:12 AM | #2 | ||
TWiZTiD EA
Why not go a au box or dont they fit ??
OR 6 Speed
10/89 EA 11 Spac5 Speed, Mpfi, EL XR6 Cam, EF/EL Thermo Fans, EL BBM Intake, Sports Exhurst, ED Bonnet, ED XR6 Boot, Boot Lip, Garnish and Lights, ED Electric Mirrors, Trip Computer, Clear Indicators, EB XR6 Steering Wheel, King Superlows, Monroe GT Shocks and EL GT copy Rims. 15.3 @ 90 mph |
04-10-2006, 10:14 AM | #3 | ||
V8 Ute V8 Boat
i put a ea box in mine for the 1st gear but now i wish i didnt i would go a T5 out of a EF or EL XR6
VE SS Ute manual 09 AU XR8 UTE 200KW manual 02 Challanger Ski boat V8 01 125 Thumpster 2010 Swag All set for the weekend |
04-10-2006, 10:40 AM | #4 | ||
I'd say the EB2 box and up be the best, witht he best being the EF/EL boxes.
They are stronger, and the ratios are better suited to the shorter ratio diffs. Better internals, stronger bearings and syncros, as well as a brake and syncro on reverse gear for that no crunch shift into reverse. If anyone is interested, I know where there is an T5 conversion from an EF/EL. And I know the box, and can say that its in excellent nick. |
04-10-2006, 11:05 AM | #5 | ||
Smash the Boost
the TR3650 as fitted to EA AIT turbos hahahahahahahahahahahahaha..........
2023 Hyundai Palisade 1971 Fairmont Sedan 1974 SWB F100 Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
04-10-2006, 11:14 AM | #6 | ||
Yeah those boxes are nice and strong
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
04-10-2006, 12:05 PM | #7 | ||
whats involved in changing boxes?? new tailshaft? flywheel? bellhousing?
04-10-2006, 12:13 PM | #8 | |||
Aspiring mr efxr
EF Wagon Project: Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA |
04-10-2006, 12:18 PM | #9 | ||
Ute Forum Moderator
I'd say the best one would be the strengthened ones with Mustang gear clusters they used in the ED Sprints, but outside of those few the EF/EL. Re AU gearboxes, I think they changed the gear lever position so they are not a straight swap.
Tailshaft is the same between the manual & auto, the bellhousing should come with the gearbox. |
04-10-2006, 12:40 PM | #10 | ||
I build your wish list...
But a AU dose not just bolt up the gearbox is longer so you will have to cut another hole in your trans tunnal about 4inchers back
that allso means that your shifter will not fit the console and a console from a AU dose not look like it will just be a straight drop in fitment to your dash . and then you have your tail shaft problem you could use ether the AU or the EF/EL tail shaft but you will still have to get it shortend. and the gearbox X member dose not fit straight up. Save all the hard work and find a EF/EL manual.. AND if you find a good one let me know as Im after a conversion.. If anyone wants a AU 5sp with everything even computer for 1,000 let me know and I will see if it is still there..
If it weren’t for physics and the law enforcement, I’d be unstoppable.
04-10-2006, 12:41 PM | #11 | ||
Last warning
I've heard people say the XH boxes are the best.
due them being built to take a heavy load (1 tonner etc)
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
04-10-2006, 03:33 PM | #12 | ||
Oops, I slipped....
I've heard that as well, apparently they're the same as the AU XR8 200kw boxes.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
06-10-2006, 07:17 PM | #13 | ||
damn
i gotta get myself a manual gear box... the auto makin me lazy lol |
06-10-2006, 09:14 PM | #14 | |||
Tuned @ Pitlane Frankston
06-10-2006, 10:30 PM | #15 | |||
AU II XR8
06-10-2006, 10:34 PM | #16 | |||
Last warning
everything is simply speculation.
06-10-2006, 10:35 PM | #17 | ||
yeah i would also like to know if this is a fact about the xh boxes being stronger
