#61 | ||
Trev
Well let's hope it doesn't have the same firing order as the Commonwhore V6. God those things are horrible.
http://en.wikipedia.org/wiki/V6
Trev (FPV FG II GT-E thus the fully loaded burger with the lot as standard +Alpine/Dynamat fitout - 2 of only 4 ever made GT-E factory 9" rear rims - Michelin Pilot Supersports - Shockworks Suspension) |
#62 | ||
AU3 ute EL futura
Well I studied engineering 20 years ago so I can't remember off the top of my head, but I do recall that regardless of firing order if you take 2 engines of the same capacity, piston/rod weight and matched/balanced to the same extent a V6 will always vibrate more. I should clarify when I say balanced I don't mean balanced the same way. The factors for a V6 are different than an I6. Hence "all else being equal".
While the ford i6 isn't perfect it doesn't suck and it's pecularities are well known and easily addressed. I'd also like to say, when I post to these threads I'm just trying to be helpful. I am not however prepared to spend hours re reading my text books and writing a proper cited essay on the topic. Your quite right to pull me up, because my wording is sometimes less than perfect, but my idea is I give you a clue and if you really care you go read up on it. If that's not good enough I'll just keep quiet. Also note I'm not cranky or anything, just making the point. Edit: Should also point out vibration is a complex area. Waay too much to know for this forum. Last edited by guzzis3; 13-11-2008 at 01:36 PM. Reason: added last bit |
#63 | |||
lots of reading there as to why in a RAW form the V6 is not as well balanced as the I6. But to make a fun comparison Compare similar sized V6 from Merc against I6 from BMW. |
#64 | |||
335 S/C GT: The new KING of Australian made performance cars.. ![]() |
#65 | ||
AU3 ute EL futura
Those articles are a good start. Unfortunately they are just a start. You need to look at for example losses and cost due to balance shafts and other secondary mechanisms.
I should also mention that a flat 6 is a nice thing, but I think of them as something else to the V6. I would be surprised if anyone had built a non 180 degree 4 liter V 6 that without the complication, expense and power losses of a balance shaft or complex crank had achieved a very smooth result. I am prepared to be proven wrong though. |
#66 | ||
Most V6's are under 4l..
Mercedes 3.5L engine: Cylinder arrangement/number V6 Displacement (3498cc) Rated output (224kW at 6500rpm) Ive driven a SLK350 and its velvet smooth... Drove a V6 Passat the other day too, surprising amount of go, and velvet smooth too...
335 S/C GT: The new KING of Australian made performance cars.. ![]() Last edited by 4Vman; 13-11-2008 at 02:25 PM. |
#67 | |||
But that is comparing a 3.5 litre capacity to 4 litre. The V6 actually produces more torque per cc than the I6. The point I was making was that technologically the V6 is not necessarily inferior to the I6. The issues of Australian made and suitability for the type of driving done in this country are a whole other issue. What if Ford did not import any engines for falcons and made them all here? Would that be a good idea? |
#68 | |||
Ich bin ein auslander
Yes there are some very smooth V6's, we test drove a Chrysler 300c V6 and that was way smoother than a commodore V6. The down side is due to the design limitations for the V6 in NVH properties, the manufacturer has to employ technologies such as hydraulic engine mounts and balance shafts. These crank driven balance shafts cause parasitic losses from the output of the motor, just think about why we all fit underdrives to illustrate the point, to decrease parasitic losses. I can not think of a V6 that is main stream production (discounting hipo sports and turbo etc) that compares to the Ford I6 for torque. The highest torque V6 I can think of is the Merc 3.5L which although to its credit achieves 350nm (ford 390nm) on half a litre less capacity, has to use DI and a host of other technologies to do it. Most of the mainstream V6's are 3.5L and achieve in the realm of 330nm, compare to the BMW I6 that achieves 315nm out of 3L. To me it is plain to see that for a 6, the I6 is the hands down winner for ouput and NVH characteristics. Its downfalls now are it is not freindly to low bonnet lines, short overhangs and FWD to name a few. The V configuration has never been due to power production or NVH characteristics, it has always been about fitting large numbers of cylinders in small spaces, this is true for 6,8,10,12 and 16 cylinders. All through history this has been the compromise of lots of cylinders and shorter cars (just think of the length of the bonnet on the old boys like some of the straight 8's).
Growing old is compulsory, growing up is optional! Last edited by geckoGT; 13-11-2008 at 03:23 PM. |
#69 | ||
V6's can be great: Alfa V6, 350z, etc etc
V6's can be bad: Ecotec/Alloytec, etc. aaaand on the flipside.... I6's can be great: BMW, Nissan RB, BA-onwards Ford etc I6's can be bad: 202, EA 3.2, etc etc
Current -2011 Nissan 370z Coupe (6M)- -2006 Husqvarna SMRR450-
#70 | |||
Interesting you mention the 202 as bad, one of the leaders of the 6 cylinder market between 1971 through to 1985, including some Bathurst wins. I see your point though, no set rule that applies to all and that is so true. Even in severely compromised configurations, you will find a diamond in the rough.
Growing old is compulsory, growing up is optional! |
#71 | ||
AU3 ute EL futura
A smaller engine will tend to get smoother all else being equal (there's that phrase again). If your considering the merits of one layout against another you should eliminate all other contributing factors. I took the question to be V6 vs I6, not mercedes vs ford or 3.5 vs 4.0. At the larger displacement the vibration issue becomes more noticable.
Specific HP is no mystery. The falcon engine is set up to deliver adequate power and torque with longevity. I would be surprised if an engine tuned to deliver maximum hp at 6500 rpm will last as long as one tuned to deliver it at lower rpm, again all else being equal. To make a higher revving engine last as long you need to go to better metals and that usually increases cost. It would be a trivial thing to slot a F1 engine into every production car, but who would pay the price ? Your wadeing into the sorts of decisions people like me have to make every day. I'm a design/research engineer. Every design decision no matter how trivial is a balance of many conflicting factors. Manufacturing cost, customer expectations, all sorts of priorities. Ford and Holden have some outstanding f*wits working for them who have produced some spectacular failures, but overall the Falcon is a good design that serves it's intended purpose well. Pity most people don't seem to realise it... By the way I don't wish to imply "I'm an engineer and I know everything". I know enough to know that I very much don't know everything.I'm prepared to believe I'm wrong, but you have to offer some proof. ![]() |
#72 | |||
Lets see what Ford do with the V6, it will certainly be interesting...
#73 | ||
T3/Sprint8
![]() Join Date: Jan 2005
Just a heads up I had just come back from the US after visiting one of our suppliers who earlier this year gained approval for their part on the FOA Duratec motor, Falcon and Terri.
No orders as yet they advise me.....I agree with 4Vman its premature condemming the V6 before she even turns a cog in a Ford here.
#74 | |||
IWCMOGTVM Club Supporter
With the doller in the toilet, this may be considered feasible.
Daniel |
#75 | |||
The big reason why people think the V6 design will be so crap is because they think the Holden V6 is. I think everyone needs to get the over it ![]() |
#76 | ||
V6 Fwd Ftl!
#77 | |||
They want a car that is reliable, quiet, and fuel efficient. The Duratec deserves a go. Whether we like the switch or not, it's necessary on a cost-basis, so rather than strangle the baby bird before it's hatched, let it fly. It will be better than the Alloytec, and that is something already to be thankful for.
Practicing - Sleeping with a guitar in your hand counts, as long as you don't drop it. Don't snap my undies. |
#78 | ||
People need to stop thinking this V6 will automatically drive like a commodore.
Also, just a thought. If Ford could make the I6 direct lpg injection, sip less than 12 ltrs per 100k would it not qualify as a "green" motor? What if Ford could produce an export plan for this motor? A low aussie dollar makes it an inticing offer. If you start making 120,000 motors a year and are sending half o'seas then surely that would make the fed government happy. An aussie manufacturer sending "green" motors to the rest of the world. Also keeps 600 (or more) people in a job. Can only be a good thing. By no means am I sharing "inside" information, just an optimistic punter really. Would kill to know what Uncle Kevin and Marin Brunela talked about.............. |
#79 | |||
Pity the fool
Interesting to know, however, that Detroit is still hell bent on making the V6 engine in the Falcon 'work' - seems there's a lot riding on it. Why would Dearborn be pushing it so much if the Falcon now has a (supposedly) limited lifespan? |
#80 | |||
335 - STILL THE BOSS ...
| [/url] |
'73 Landau - 10.82 @ 131mph '11 FG GT335 - 12.43 @ 116mph '95 XG ute - 3 minutes, 21.14 @ 64mph 101,436 MEMBERS ......... 101,436 OPINIONS ..... What could possibly go wrong! Clevo Mafia [SIGPIC][/SIGPIC] |
#81 | |||
Barra Turbo > V8
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+ -2022 Hyundai Tucson Highlander Diesel N Line |
#82 | |||
Don't really think the rumoured saving of the I6 would have much to do with expanding the engine to fit other vehicles, ultimately a Direct injection turbo'd 3.5-3.7 V6 and global 6 speed autos and manuals would be fitted to any new big One Ford Fords, Lincolns, Mercury. Saving the I6 would only be about Falcon and Territory, and minimising cost and investment outlay in this economic environment. It would also be about Ford maintaining good relations with this Country and supporting a local workforce through a hard period until Focus rolls out of Broadmeadows. Certain though, that with Aurion/Camry and Commodore already announcing future LLPG versions, this would be part of the Falcon plans. That should please Kev 'n Kim either way. Hopefully the Commodore export markets would be opened up to LHD versions of Falcon and update Territory with no real Crown Vic replacement on the horizon, and dodge recalling their Challenger cop cars. If Ford Aus play the right cards in the right order, then maybe Dearborn will give them the opportunities they needed 5 years ago. All looks a long long way away atm though. Ford needs to make the most of what they've already got IMHO, and the Falcon is a great product, hampered by previously forced isolation only. |
#83 | |||
#84 | |||||
#85 | |||
What....................? |
#86 | |||
Where to next??
#87 | ||
GT-P With An Ego
It's a daewoo donk.
1998 DL LTD in Sparkling Burgundy, daily, mild 5.0L, high end stereo, slow'n'thirsty - 138.8rwkw. 2006 BF GT-P in Ego, 5.8L all alloy, Kenne Bell 2.8HLC, Nizpro Stage 2 ZF - 440rwkw. 2008 SY F6X in Silhouette, custom billet parts, beginnings of a stereo, much more - 340awkw. Ford Performance Club of ACT |
#88 | |||
![]() I thought I was going mad for a minute - a bit of back to the future !! |
#89 | |||
Getting it done.....
When GM got out of Fiat (caus it was a basket case) they severed all ties except one or two platforms and kept supplying the block and ancilleries for the Alfa 3.2. This was when the alfa engineers basically came out and said that the alloytec was rubbish in many areas and there were shocked they had to do so much work to make it competitive given it was a GM global engine (big money spent). This was around the same time the alloytec was getting put in commodore and that was the first alert anyone got that maybe this new great engine was a dog. Having driven an alloytec i agree with the alfa engineers....smart blokes LOL!
Dynamic White 1995 EF XR6 Auto Now with: Pacemaker 4499s Lukey Catback Exhaust Chrome BA XR-style tip Airdam Mounted CAI with modified (bellmouth) airbox Trip Computer install KYB shocks Bridgestone Adrenalin tyres Coming Soon: Exhaust Overhaul..... |
#90 | |||
Cobblers!
Ego BFII Ghia Titanium Silver E53 X5 4.4i Gunmetal EF XR6. Now retired from active duty. Roses are red. Violets are blue. OS X rocks. Homage to you. |
