Hey guys i have recently purchased 3x 15" Soundstreem Picasso series subs.... they are 400RMS each and trying to think of the best way to amp them..... if i should run them off 1 mono block or 3??? wat would you do???
this is a seriouse thread aswell.... its not bull shiz |
Are they dual voice coil? 4 ohm, 2 ohm?
DFDFDF
How many voice coils and wat impedance (ohm) are they???
Cheers, Nik
The Daily : 2012 Ford Territory The Restorer : 1994 Polynesian Green ED XR6 T5 - Completely stock, put away for a few years The Project : 1994 Velocity Blue ED Ford Futura - AU3 220kw XR8 5L V8 5-Speed in progress The Toys : 2003 GasGas EC250 & 2001 Yamaha DT230 |
Power Handling: 400W/800W (RMS/Max)
Sensitivity: 85 dB RMS Power Range : 400 Watts Impedance: Dual 4 Ohm Low Frequency response: 25 Hz High Frequency Response: 500 Hz FS - 28.7Hz Qes - .849 Qms - 4.328 Qts - .710 Vas - 114ltrs SPL - 87db Mounting depth - 6.9" Diameter: 15 Inch |
DFDFDF
I would run one of the below combos..
2 x 15's wired to 1 ohm off 1 big mutha funkin d class.. 2 x 15's wired to 2 ohm each off 2 d class mono blocks.. 3 x 15's wired to 2 ohm each off 3 d class mono blocks.. Do you really need 3 x 15" subs in a falcon??? LOL.. Cheers, Nik
BF F6, APV SR3900
3 is a ***** of a number of subs to run... I'd probably drop 1 or add another.. i dont think that you value boot space much.. with 4 then at least you can wire 2 in series and 2 in parallel and then get a nice 2 ohm final load on 1 massive mono..
what area you from? if i can help you with anything let me know..
Santo White APV SR3900 [WIZZRD] (Click Here) [/COLOR] Daily: 2006 Red BF F6 Typhoon Bluepower enhanced. |
thanks for the info guys.... i think i will run 3 mono blocks..... and yes i need 3 15" :P it need s to be big and unique..... plus dont worry they will fit :evil3:
DFDFDF
I know theyn will fit.. i did an install of 8 x 12" subs in a falcon and before that it was 4 x 15"..
3 will fit without even trying.. LOL.. Cheers, Nik
TICKFORD XR6
Well seeing that ppl are offering to help with instaling sound system anybody interested in helping me make a 15 inch sub box?? lol
The Ride:Ford EF XR6 S1 Plans: Slam it on its ***, Sports exhaust( upgrade), Rims, Cam, CAI, Extractors +...
The Drive Line: 4.0L MPI 4speed Auto TICKFORD ENHANCED How she Rides: 15inch XR6 MAGS Sound system:JVC head unit with AUX... 6 Inch in doors,rear with a Vnet 15inch & Infinity 12inch Subs In the Boot Running of a Coustic amp The Mods: Pod Filter, exhaust...... |
#10 | |||
DFDFDF
I would personally go with 4 of the 15's and run them off 2 of the 1500wrms response d class mono's..
If you do decide to go with 3 subs.. 3 of the 800wrms response d class would do the job.. Retail price on the 1500wrms amps is $700 each.. and retail on the 800wrms is $400.. Cheaper if ya get a few at a time.. Cheers, Nik
#12 | ||
its getting worked on!
or you can get 1200wrms clarion mono for $400
#13 | |||
no clarion stuff is going in my car..... not a fan |
#14 | ||
BF F6, APV SR3900
run 4 off 2 800wrms monos
#15 | |||
#16 | ||
what you think of the latest MTX thunder amps, i heard they blow
#17 | ||
well in my opinion subwoofers are for chiks to go "oh my god... subwoofer!" im sure u'll make the right decision [EDGHIA]
#18 | ||
DFDFDF
How loud the system is is going to come down to enclosure design more than the equipment you use.. the old mentality of 25% equipment, 75% Installion comes to mind..
The problem with running 3 dual voice coil subs off one amp is that you will be presenting the amp with ~.6 or .7 ohms.. I have done this in the past and doesn't really give more noise but just decreases the amps efficiency and makes it heat up.. If you are looking at getting some response amps PM me when ya ready and i can hook you up with some good pricing.. Cheers, Nik
#19 | |||
#20 | ||
BF F6, APV SR3900
stupid question.. why soundstream?
#21 | |||
#22 | ||
DFDFDF
I just did some research..
http://www.soundstream.com/subwoofers-picasso.htm Nice looking sub but it is missing some important specs.. did the subs come with a spec sheet.. Does it have the xmax listed??? Cheers, Nik
#23 | ||
DFDFDF
I dont know wat the pricing is like but might be worth looking at there amps.. they have a couple of decently specced d class mono blocks..
http://www.soundstream.com/amplifiers-picasso.htm Cheers, Nik
#24 | ||
yeah they do but ther about $700 each :togo: ... so i wanna get something a bit cheaper
#25 | ||
DFDFDF
The xmax is how much 'throw' the sub has.. that is how far it travels when pumping.. It is usually a critical factor in determining how well the sub will go and wat size enclosure to run it in..
Cheers, Nik
#26 | ||
umm.... i dont no the answer to that but the guys who will be doing the install work with soundstream alot so it should be sweet....
#27 | ||
BF F6, APV SR3900
whos doing all the work...
chrome spider grilles are cool.. lol roosta.. check out my subs mate.. www.jlaudio.com.. im running 2 x w3v3's... 12"... 3.0 cu.ft net vol.. facing into cabin.. kicker 750.1 pumping 465wrms into each.. i could prolly get a bit more out of them shifting the phase around 180 (eg into the boot), but i like the clarity and lack of boot rattle at the moment...
#28 | ||
DFDFDF
Nice..
They look like a fairly tidy sub.. Plus coupled with a decent enclosure would give great noise.. Cheers, Nik
#29 | ||
The one and only
Glenn, one quick question.
Why do you need to run 3 15" subs?
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
#30 | |||
OzEcruisers PRESIDENT
![]() Join Date: Mar 2005
Go Louder is alot safer and you wont loose your licence over it.......... ![]() ![]()
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan PROEF 13.46 @ 105.78mph Tuned by DYNOMOTIVE 200BUX - AFF Drag Nats 2019 EF Wagon
