Old 28-05-2007, 03:18 PM   #1
RG
Back to Le Frenchy
RG's Avatar
Default AUII IRS Handbrake
I've done a search and had a read but for the life of me I still can't figure it out. I've removed the rubber grommet from the rear disc and I've found what looks like it is an adjuster, the inspection hole is at 3 o'clock on the pass side / 9 o'clock on the drivers when I can see the adjuster. Now which way do I turn it? I reckon I could almost get a small flat blade screwdriver in there but I just need to know whether I turn the screw clockwise or anti clockwise on each wheel.
Old 28-05-2007, 05:11 PM   #2
JC
JC's Avatar
Turning it clockwise lengthens the adjuster. It's hard to do though. Easiest way is to follow the steps below. BUT, before you start, back off the 10mm adjusting nut at the handbrake lever inside the car, until it's all the way to the top of the threaded rod. This will enable you to do some adjustment from within the car once the handbrake starts to loosen off after 6 months or so, and means you won't need to repeat these steps for 12 or 18 months.:
1. Undo the little phillips head screw
2. Take the disc off
3. Do a 1/2 turn adjustment on the adjuster
4. Refit the disc - it should slide on easily
5. Repeat steps 2 to 4 until when trying to fit the disc, it's tight. When you get to this point, don't force the disc on - remove it
6. Back the adjuster off 1/2 turn.
7. Refit disc.
8. Refit screw
9. Repeat for other side
10. Test handbrake.
Your handbrake should be nice and tight.
Ford Performance Club ACT
Old 28-05-2007, 05:52 PM   #3
RG
Back to Le Frenchy
RG's Avatar
7. Refit disc.
8. Refit screw
10. Test handbrake.
Tried that but one of the little screws was on so tight I started to rip it a new one, funnily enough the other side was so loose it didn't need any force whatsoever. I've now cracked the sads and called a mobile brake guy to come and do it. Only costing me $25 for him to come out and do it for me too, I just have to have the car up with the wheels off first. I must also remember to back that nut at the lever all the way off to the top of the rod too.
Old 28-05-2007, 07:44 PM   #4
JC
JC's Avatar
$25 is not too bad. Those screws can be tight first time (takes you back a few years, doesn't it??) - I generally use a screwdriver drill bit, and use it in a 1/4" socket to undo it. That way you can press it in while undoing the screw.
Old 28-05-2007, 08:17 PM   #5
347 mont
347 mont's Avatar
I had a bugger of a time too but managed to get done after a couple of attempts.
I had trouble seeing the adjuster as its on a awequid angle. I ended up taking the rotor off which was a mission in its self so I could see what was going on and which way to turn the adjuster, had to use a puller, loads of CRC and a few heavy taps with the hammer to get the rotor off the adjusted and measured the hadbrake shoes to get the right adjustment, I got the distance from the Ellory's manual. Hope it makes sence and it helps you out.
Losing my patients with unfinished threads
Did the ideas people helped you with work or not!
347 mont is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2007, 08:38 PM   #6
TCK-098
TCK-098's Avatar
Ill have to try that this weekend as mine aint grabbing much right now.
cheers guys
18 T6 Multivan
03 Ba Xr turbo 300rwkw
TCK-098 is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2007, 08:54 PM   #7
ronwest
All Bran = Regular Member
You guys oughta invest in an impact driver for those tight phillips/slot heads.
Had mine around 30 years and have used it many, many times. I can't recall ever being caught out since I've had it.
From memory it was around $20 way back then so probably somewhere around $500 now, lol.
edit: there ya go... the only one on ebay
http://tinyurl.com/yphxnw
Old 28-05-2007, 09:55 PM   #8
347 mont
347 mont's Avatar
The screw was a piece of cake to undo it was the actual rotor that was a bugger as corrosion was bonding it to the hub. A puller, CRC and a fer moderate but firm taps with a ball peen hammer did the trick
Old 28-05-2007, 11:13 PM   #9
JC
JC's Avatar
If you leave the car out of gear, and leave the handbrake off, then a couple of hits with a rubber mallet while rotating the disc is the easiest way to get it off. You just hit it from the back of the disc, at the spot where the dust shiled behind it is missing - sort of the bit of the disc facing the front, if that makes sense.
