Old 02-06-2007, 07:19 PM   #1
ILLaViTaR
ILLaViTaR's Avatar
Default Car blowing whit smoke
Car is blowing a faint white smoke and smells a lot like petrol.
Does this mean it's running rich?
ILLaViTaR is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2007, 08:18 PM   #2
ratter
ratter's Avatar
Black smoke is too rich
Blue smoke is oil being burned
White smoke is water in the combustion chamber
Pit Lane Performance
Old 02-06-2007, 11:07 PM   #3
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
id be getting a compression guage or a leak down test guage onto it soon. could be looking at a headgasket here mate.
EF Wagon Project:
Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required
Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB
Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's
the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA
CaRtZ is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2007, 11:46 PM   #4
frd_crzer
:D:D
frd_crzer's Avatar
sounds like your head gasket is about or starting to go on ya mate. my opinion is just do the head gasket now before it gets worse
Cheers Grant
frd_crzer is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2007, 11:57 PM   #5
efgiar
rofl copter
efgiar's Avatar
HG gone, put an au one on
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2007, 12:45 AM   #6
sexr6tasy
Its also possible it might be blowing faint white smoke because you havent started it in a while if in doubt look for leaks around your head gasket.
sexr6tasy is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2007, 10:59 AM   #7
ILLaViTaR
ILLaViTaR's Avatar
I done a cylinder compression test yesterday, all cylinders were around 200psi.
Old 03-06-2007, 11:37 AM   #8
frd_crzer
:D:D
frd_crzer's Avatar
like efgiar said hg gone put AU one on
Cheers Grant
Old 03-06-2007, 11:42 AM   #9
wodahs
wodahs's Avatar
it is possible to be sucking brake fluid in to the engine throu the boster even thou rare
and this will also cause white smoke
yes still (as money n time permit) doing the
rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually
just remember don't be afraid to try something new.
Remember, amateurs built the Ark...Professionals built the Titanic!
I have taken up meditation... at least it's better than sitting around doing nothing !!
wodahs is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2007, 12:42 PM   #10
ratter
ratter's Avatar
There should be no brake fluid in the booster to be sucked into the motor, it can not get in there.
Old 03-06-2007, 12:55 PM   #11
FDG 220
Confused lil guy
FDG 220's Avatar
Not so true but the odds of your master cylinder and brake booster leaking in same spot would have to be million to one
FDG 220 is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2007, 03:26 PM   #12
ILLaViTaR
ILLaViTaR's Avatar
The head gasket was only replaced 70 000km's ago and the white smoke is almost clear.
I thought it was something that cars did when the engine was cold.
I ran it for 10 minutes, I'll take it for a drive and see if it's still doing it after the drive.
If so I'll replace it asap.
I never done a head gasket and aint paying $800 for a mechanic to do it.
Are they easy to do yaself?
I just don my rocker cover gasket 2hrs ago.
Old 03-06-2007, 04:47 PM   #13
ratter
ratter's Avatar
Ok, put up your hands who has this happen to them.
A leaking booster would have the owner complaining about the pedal effort they have to use to stop the car and also how rough or high the motor is revving at idle. and if the master cylinder was leaking at that exact spot (if that could happen) the engine vacuum would suck tha master cylinder dry, so then the owner would be complaining about how the padal goes to the floor.
Old 03-06-2007, 04:55 PM   #14
LiL_Macka
("(O.o)") Fear the EL!!!
Blue is oil, black is to much fuel, white can mean lean, and rich. but if it smells like fuel its running rich. Also... Head gaskets arn't hard to change, you just have to have the right tools.
Secret is to keep it clean and tension the bolts in the right order and in stages so you dont warp the head.
04 Silver BA XR6 Turbo, Now with 241RWKW thanks to CV Performance! :
LiL_Macka is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2007, 05:17 PM   #15
ratter
ratter's Avatar
Originally Posted by LiL_Macka
Blue is oil, black is to much fuel, white can mean lean, and rich. .
So black is too much fuel, white is lean or rich ???????
Old 03-06-2007, 08:37 PM   #16
wodahs
wodahs's Avatar
* hand waves high *
my first car an xy wagon
master was leaking down the plundger vacume booster had a leek in the spindle and was getting sucked in to the engine blowing white smoke , too a fair bit to locate after we had done all the useual stuff and not meny had heard of this and when was mentioned every one said it cant so we didnt check and repaired stuff that people thought it could be
Old 04-06-2007, 10:33 AM   #17
ratter
ratter's Avatar
Originally Posted by wodahs
* hand waves high *
27 years in the trade and first time I have heard of both problems happening at the same time, You learn something new everyday, the rough idle should have given you a bit of a clue which way to head to rectify the problem.
Old 05-06-2007, 08:29 PM   #18
EBIIXR6
EBIIXR6's Avatar
we put brake fluid in the windscreen wiper bottle of an old laser and the line into a vacuum line. White Smoke? Oh s***t Yes! - good trick :hihi:
93' EB II XR6 factory manual
Everglade Green 3" Mandrel Exhaust, High Flow everything, GT61 garrett @ 6PSI :voldar02:
EBIIXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2007, 11:03 PM   #19
JC
JC's Avatar
You have to be kidding. Of course when you first start a car in winter it will blow white "smoke". It's the same as when on a freezing cold day you breathe out "smoke" without needing a cigarette - it's because the air you are breathing out is warmer than the surrounding air. Same with a cold car. You don't notice it in summer as the ambient temp is that much higher. So now you have everyone (else) thinking you have blown a HG all because you don't put enough info into your posts.
Ford Performance Club ACT
Old 05-06-2007, 11:04 PM   #20
JC
JC's Avatar
Did you know that pond water on your dash will turn it green over time? Of course, this ever happening is rare, but it can happen.
Old 05-06-2007, 11:06 PM   #21
ILLaViTaR
ILLaViTaR's Avatar
If I didn't put enough effort in on my posts then how did you pickup on this?
Old 05-06-2007, 11:09 PM   #22
JC
JC's Avatar
Because at about your 10th post you said you started the car and let it idle for 10 minutes. I was with the HG brigade until then.
Old 05-06-2007, 11:10 PM   #23
sexr6tasy
Lol i suggested it might well be a cold exhaust or not started for a while but nobody listens to meeeeeeeeeeeeeeee. lmao
Old 05-06-2007, 11:15 PM   #24
atec77
black is rich , white might be head problems but I doubt it
you may have a bad injector or the auto vaccum modulator is about to die and is sucking some fluid from the auto into the induction
Old 05-06-2007, 11:17 PM   #25
JC
JC's Avatar
Yes, I did, and I reckon you're right.
Old 05-06-2007, 11:17 PM   #26
JC
JC's Avatar
Read the whole thread. It's because the car was cold!
Old 07-06-2007, 10:09 PM   #27
falcon351
HANK
falcon351's Avatar
Sounds like it was cold to me...
What benefits will putting an AU HG on have?
Will i be able to put one on my EBII? (4LTR)
cheers
1992 EBII Fairmont
Lowered 30mm on kings springs and monroe struts/shocks
Performance catback exhaust with stainless 3 in tip!
Shift kit!
Tinted windows n tail lights.
Pioneer 200w flip face head unit
600w pioneer sub backed by my nu 640W kenwood 4 way amp
Eclipse 6x9s and 6's
Clear front and side indicators
115 rwkw on regular, not bad for pod, catbak!
Back on the rd! nothing can stop us, not a defect or even a stoby pole!! BAHAHA NEVER SAY DIE!!!
falcon351 is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2007, 10:22 PM   #28
ILLaViTaR
ILLaViTaR's Avatar
cheers
Yeah it was just cold, usually takes around 10 minutes max to heat up but it took 1/2 an hour today.
AU gaskets are metal and basically fix the head gasket issues.
You get slightly higher compression with an AU gasket.
Make sure you get AU head bolts and the head machined smoother for the AU head gasket.
Yes it will fit the EB II.
Old 07-06-2007, 10:32 PM   #29
sexr6tasy
From what i heard its best to just get regular ef/el head bolts?
Old 07-06-2007, 10:52 PM   #30
ILLaViTaR
ILLaViTaR's Avatar
I heard AU bolts but I personally don't know.
They use different torque settings which I can't remember now.
