Old 14-06-2007, 09:02 PM   #1
pecker73
Falcon Addict
pecker73's Avatar
Question AU1 Brakes
Can anyone point me in the right direction ?
I have just picked up an AU1 Falcon Forte Sedan. It has the stock brakes on it.
I also have a set of BA XR8 Brakes (Calipers, Rotors, Pads).
I want to get these fitted to the AU. Does anyone know where I can go to get this done? Is it an easy process for the AU1? Any idea of cost if you have had it done?
I have had a read of the BA onto AU thread, everyone seems to do it themselves... I would, except I am mechanically challenged and want the car to stop when I use the brakes. :
:eclipsee_ :eclipsee_ sleep: sleep: :eclipsee_ :eclipsee_ :eclipsee_ :eclipsee_ :eclipsee_
DAILY-2006 BF Falcon XR6 Turbo Sedan. 6 Speed Auto.
1/4 Mile......13.84sec/103.38Mph BF XR6T with an official 211.0 rwkw :
pecker73 is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2007, 09:06 PM   #2
stiddy
stiddy's Avatar
My bad, didnt read your full post.
Umm pretty much any mechanic could do it, would be better off trying to find a brake and suspension place to have a look.
If you source the parts you need and pass it onto a mechanic they should have it done pretty smartly..
Old 14-06-2007, 09:08 PM   #3
Casper
Contributing Member
Casper's Avatar
Hoppers stoppers can do it, so can BOG, and G&D also have the knowledge.
Older, wiser, poorer.
Old 15-06-2007, 11:16 PM   #4
EvilChief
Boost Addict
its reasonably straight forward:
you will need:
- Uprights
- lower control arm
- S2 swaybar & mounting brackets
for ur brakes u will need the mounting brackets (bridges), calipers, pads and rotors and i am sure i forgot something somewhere lol
those conversions take me about one hour each side, that includes inspecting and regreasing slides, machinin rotors, linishing pads (if 2nd hand), fitting components, etc
sometimes we rebuild wheel bearings while we are at it as everything is apart anyway
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 16-06-2007, 01:42 AM   #5
JC
JC's Avatar
you will need:
- Uprights
- lower control arm
And it took me 11 hours! Worth doing though, and you need to use the AU2/BA brake lines, as the AU1 lines are too short.
Ford Performance Club ACT
Old 16-06-2007, 02:41 AM   #6
theboss290
FPV GT
theboss290's Avatar
is there anyone in S.A.that can do this?
theboss290 is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2007, 04:45 PM   #7
JC
JC's Avatar
You mean anyone on the forums? If you just mean anyone, pedders should do it, ot any other suspension place. Changing the lower control arms etc should be a snap for them - they'd just about have to do it when changing upper/lower ball joints anyway.
Old 16-06-2007, 09:29 PM   #8
ilucgte
Theres not much out Craigmore way to do this, but i would go to Stable Suspension, if thats what its still called, on Ween Rd Pooraka, decent blokes in there. I did the rotors, calipers and pads and some other stuff the other week on our AU and they are really easy cars to work on, i couldnt believe how quick i got it all done.
ilucgte is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2007, 11:18 PM   #9
blackers10
blackers10's Avatar
is anything funky required to do this conversion (presses etc)
or is it nice and straight forward spanner turning goodness??
probably going to have this on the cards when my current rotors die
here is a pic i got off here somewhere that has everything required layed out so you can see!
(switch the nice huge Brembo calipers and rotors to which ever AU2-BA rotors and calipers your using obviously)
Old 16-06-2007, 11:59 PM   #10
EvilChief
Boost Addict
hoist, air tools and a complete workshop make life easy
N12 Pulsar - sold
Old 17-06-2007, 09:47 AM   #11
AU1XLS
AU1XLS's Avatar
You will need these as well
AU1XLS is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2007, 09:49 AM   #12
AU1XLS
AU1XLS's Avatar
You only need press etc if you start changing bushes etc its otherwise a bolt up conversion
Old 17-06-2007, 10:06 AM   #13
blackers10
blackers10's Avatar
cheers mate
where do those brackets go??
Old 17-06-2007, 10:44 AM   #14
JC
JC's Avatar
Originally Posted by blackers10
cheers mate
They bolt to the chassis, then the sway bar D mounts bolt to them. There are 2 holes on the outside of the chassis to hold the large brackets (they are threaded to take a 6 or 8mm metric thread, IIRC), but nothing on the inside, so you need to use some self drilling bolts, or a 90mm bolt and nut to hold them in position on the inside.
Old 17-06-2007, 10:57 AM   #15
JC
JC's Avatar
I found this mob by googling carrum downs (I had no idea where it is, and was going to offer my help if you travelled from Sydney to Canberra, then found that you're in Vic). Anyway, sounds like a good business and they're local for you - might be worth a try.
http://www.carrumdownscarcentre.com.au/
Old 17-06-2007, 03:18 PM   #16
pecker73
Falcon Addict
pecker73's Avatar
Thanks for all the reply's...
Hopefully in the next couple of weeks the AU will have some new stoppers !
Old 17-06-2007, 08:23 PM   #17
EvilChief
Boost Addict
i knew i forgot something ... this was it
N12 Pulsar - sold
Old 17-06-2007, 09:54 PM   #18
GK
Walking with God
GK's Avatar
I just had the S1 wagon converted to S2 brakes, I highly recommend it.
My costs:
$400 = uprights, callipers, swaybar and mounts, lower wishbone.
$240 = rda slotted rotors and QFM K500 HP-R pads pads
$150 = labour (Dave my mate = top bloke).
$70 = extra gift for Dave.
$20 = swaybar bushes
$5 = castrol brake fluid
$885 all up, professionally installed.
I painted up the hub on the rotors with paint I already had and Dave painted up the callipers for me with another can I already had. We sprayed the pads with an anti squeal compound which I had left over from another job. I don't include these costs, but they'd be around $55 I'd reckon.
Brakes have heaps more feel, power and initial bite. I am very happy that I did the upgrade. The car pulls up so, so much quicker now.
Cheers,
GK
Now gone!
On LPG
Want a Full Life? John 10:10
