21-05-2005, 04:27 PM | #1 | ||
Shoot.
Hey,
Just wondering whether someone can tell me whether this looks like typical head gasket symptoms. I know the pictures probably don't help much, but I just want to make sure as I am not too familiar with them. I am pretty sure the welsch plugs have been replaced in the past year or so. BTW, how do you replace them? Are they hard? There is no water/cloudy substance in the oil. The coolant seems to have disappeared out of nowhere, so that's why I initially suspected a blown head gasket (not to mention that the oil is realllllly low). And no, it's not my car Cheers fellas
20V Turbo |
21-05-2005, 04:42 PM | #2 | ||
About the welch plugs you can just get a screw driver, poke a hole through it, then try and get it out with the screw driver just fiddle around with it then it should come out, sometimes they can be hard as to get out though, when you put the new ones in, give them a real light sand then put some of that sealer stuff on the the out side edge part, and chuck em back in.
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
21-05-2005, 04:56 PM | #3 | ||
same symptoms as the Van so i would say head gasket time.
21-05-2005, 07:07 PM | #4 | ||
Two > One
Doesnt look tooooo bad, but yes it could be gone.
Thats a pic of a common blown head gasket.....and yes, it is mine
21-05-2005, 08:38 PM | #5 | ||
thats not a sight i want to see... nice extractors though dan
1998 Ford Fairlane - 4.0L
18x8 RJR rims - Tinted - King Suspension - 2.5" D&T Cat Back Exhaust |
21-05-2005, 09:57 PM | #6 | ||
You can't just "punch a hole" in the welch plug, they're made out brass lol. You can only do that if they're the factory rusted shit ones and they're ****ed up. If that one's leaking you'll either need to drill it and then poke something in and pull it, otherwise try and punch it out.
More than likely it's your head gasket though. Time to upgrade Lukas! Sundeep |
21-05-2005, 10:00 PM | #7 | |||
22-05-2005, 02:17 AM | #8 | ||
3.2 3 speed auto.
i have a similar problem with my mighty 3.2....but i'm not losing oil just coolant. have to top it up about once a fortnight. funny thing is it had a new head gasket installed last year......oh well...drive it til it drops then off to the wreckers
22-05-2005, 03:30 AM | #9 | ||
Last warning
ur extractors are still blue dan!
mine are crap :P
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
22-05-2005, 07:52 AM | #10 | ||
Not your average EF Wagon
The symptons clearly look like the time for a new head gasket. On my previous motor, dead on 150,000 I had the same problem. Losing coolant on the side of the block between cylinder 2-3 and 4-5. Still ran fine for bout 2 months though.
Power by HeadTech Performance Williamstown The recently SOLD 95 EF Wagon 5spd NA SLEEPER The Daily cruisers now *95 R33 Skyline GTS-T RB25DET *93 Lexus GS300 2JZ-GTE Car enthusiasts visit Unique Cars and Parts
22-05-2005, 07:54 AM | #11 | ||
Put an AU head gasket in or another high performance one in after you have recod the head.
While your at it, port and polish and throw in a cam.
22-05-2005, 11:30 AM | #12 | ||
eec tweaker
dan, is your gasket leaking on EVERY cylinder???
looks like gasket to me, my bro's EB just did one too. ****ing fords!! |
22-05-2005, 12:42 PM | #13 | |||
Custom User Title
