Old 21-06-2007, 06:40 PM   #1
Auuteage
Default Urgent electrical problem
I have lost power to my cig lighter, which runs some important stuff for my job. I tried changing the fuse, but it still dosent work. All other electrics ok. Where else can I go from here? thanks!
Auuteage is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 06:50 PM   #2
private9
www.TUFFCARPARTS.com
private9's Avatar
Is the metal part of the cig lighter loose at all - ie can you turn it by hand?
Old 21-06-2007, 07:22 PM   #3
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
On the back of the actual socket there is a fusible link type thing that could be blown, resolder this if it is broken.
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 07:37 PM   #4
Auuteage
no, seems tight...?
Old 21-06-2007, 08:08 PM   #5
Auuteage
by the way, which fuse is the cig lighter? I replaced every fuse there, thats how I know its not the fuse. But Im thinking...how stupid is it that there isnt a legend on the back of the fuse box cover !!!!?
Anyone know which one it actually is?
Old 21-06-2007, 08:39 PM   #6
mik
mik's Avatar
i had a look in the work shop manual there is a pic of fuse box but no numbers i can see , anyway cig lighter is listed as number 5 at 15 amp blue....... best i can do cheers.
Old 23-06-2007, 10:23 AM   #7
Auuteage
After a search here, I have seen mentioned that there is actually a fuse behind the lighter itself, in line with the wiring it seems. This has to be my problem I reckon, or hope! Anyway, after taking the ashtray out, it seems mega hard to get too. There has to be a easier way. Anyone attempted this before ?? thanks.
Old 23-06-2007, 12:30 PM   #8
Auuteage
anyone??
Old 23-06-2007, 02:57 PM   #9
Auuteage
The lead that plugs to the back of the socket is showing 12V! Must be the actual socket, but that fusable link dosent seem broken. Man, it cant be that hard, can it?
Old 23-06-2007, 04:12 PM   #10
bodes-sh
to get to it you have to remove the dash panel, ie where the radio sits, heater controls, etc...it all has to come out, apparently it's just clipped in, there are a couple of screws at the bottom behind the ashtray
Old 23-06-2007, 04:27 PM   #11
Auuteage
I pulled the actual lighter assembly out without taking the dash apart. However super cheap dont have a replacement. back to the drawing board..
Old 23-06-2007, 09:11 PM   #12
Morgz88
You could always create a new wiring connection for the lighter assembly you have just removed.
You could connect the positive wire of the lighter housing (The middle lug) directly to the battery or switch it through the ignition, and just run a fuse through it somewhere. Just connect the nevative wire from the lighter housing (the outside casing) to the cars earth.
That would be a quick fix for now.
Morgz88 is offline   Reply With Quote Multi-Quote with this Post
