Old 23-06-2007, 07:19 PM   #1
josh_hartman
Default Is This True
i heard that EA-AU Auto transmissions are all the same and just bolt straight up? i heard the only difference was the older ones had a dip stick. will i be able to by an older trans and just bolt it up no dramas?
josh_hartman is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2007, 09:54 PM   #2
No. The first EA had 3 speed Borg Warners the first 4 speed BTRs had a separate control module while later ones had the control module with the engine ECU and there were various models of and different ones for 6's and V8's. They may bolt in but the wiring and electronics May not be compatible. AU's , EL and EF's had 93LEs (6s) and 97LE (V8s) while 85/91/95LE were on EA to EDs.
aussiblue is online now   Reply With Quote Multi-Quote with this Post
Old 23-06-2007, 10:43 PM   #3
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Good Old Borg Warner Transmissions .. Had one in the Sigma , ' Bulletproof ' !
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2007, 11:25 AM   #4
JC
JC's Avatar
Yes, any 4 speed auto trannie will fit any car that came with one. So you can have an EB 4 speed in your AU. The main difference between them is the action of the valves and solenoids, and the way the electrics work (as pointed out above, some had separate ECUs etc), but the wiring at the trans is essentially the same. TurboTaxi has fitted an EB auto trans to his AU turbo, and it works fine.
Ford Performance Club ACT
Old 24-06-2007, 11:31 AM   #5
private9
www.TUFFCARPARTS.com
private9's Avatar
From what I've been told EB-AU will all fit. Some plugs and wiring though won't be compatible on the older trans and will need to be swapped for the AU stuff. Apparently any trans place or a mechanic who's done this before can do this though.
Old 24-06-2007, 11:47 AM   #6
Stav
Smile
Stav's Avatar
Guys .I have an ef box on the au wagon.The difference is that you need to bolt your existing bell housing to the non au gearbox.Also they do not have a variable pressure adjustable solenoid.They have a solenoid just non adjustable.My s5 solenoid died and an au one reinstalled since.
Old 24-06-2007, 12:06 PM   #7
private9
private9's Avatar
When my next box dies (which hopefully won't be for a while as it's just been rebuilt) this is the way I'll be going - ie EF gearbox with a disptick. Either that, or a manual conversion !
Old 24-06-2007, 07:28 PM   #8
blackers10
blackers10's Avatar
i have an EB? 4 speed auto in my car
i have an au fairlane
the only bad thing is the STIFF gear shifter
which i think is just how the boxes were??
the difference is 4 bolts
the AU bellhousing to gearbox has 8 the EB has 4
but other than that its a dip stick and thats about all i believe
