Old 24-06-2007, 01:02 PM   #1
private9
www.TUFFCARPARTS.com
private9's Avatar
Default Will this work on my AU I6? (Crane MSD ignition setup)
Hi All,
Pretty sure the answer's no here, but I have it lying around, so thought I should check.
I have a Crane Fireball Hi-6 Ignition system and I'm wondering if this will work in my AU. It was previously in an EL Falcon (single coil application).
I know that with the AU being a multi coil setup, obviously the LX92 coil pictured won't be of any use in the AU (multi-coil), but even after searching the Crane website, I can't quite establish if I can actually use the Hi-6 Ignition system.
I normally view such things as useless in a modern multi coil equipped car, but since I have it lying around, I thought I'd at least give it a try if it's able to be used.
Thanks,
Justin.
Old 24-06-2007, 01:21 PM   #2
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
I wouldn't think you'd notice much of a gain from just upgrading the ignition system. Usually these systems are reserved for big power/boosted applications?
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2007, 01:29 PM   #3
private9
private9's Avatar
Yeah, I'm not expecting any difference at all actually, but thought that since I have it, I may as well give it a go if it fits, and then I'll probably flog it off, or hide it in the shed for that old-school project that I have in my dreams!
When I saw this thing in my EL, I thought to myself, what kind of person spends hundreds and hundreds on a hipo ignition system for a basically stock EL 6.
Old 24-06-2007, 01:41 PM   #4
LUXO_8
windsor user
they were probably planning to turbo it.....
Old 24-06-2007, 02:20 PM   #5
private9
private9's Avatar
Actually, now that you mention it, that's exactly what he was planning. He already had the turbo kit too.
Old 24-06-2007, 04:36 PM   #6
Stav
Smile
Stav's Avatar
I dont think it is suited to the au six cylinder as we have multiple coil packs.
Old 24-06-2007, 04:51 PM   #7
LUXO_8
windsor user
good point..... it'll only work on cars with a single coil and a distributor....... so no it wont work on the AU
Old 24-06-2007, 04:55 PM   #8
private9
private9's Avatar
Thanks guys. Well I guess I won't be using it then!
Old 26-06-2007, 12:13 PM   #9
private9
private9's Avatar
Well, just had it confirmed 100% - won't work on the AU!
Old 26-06-2007, 02:11 PM   #10
FGII-XR6
FGII-XR6's Avatar
the AU with it's coil packs use 3 chanels for coil signal so if there was any chance it would work you would need 3 of them
Old 26-06-2007, 02:13 PM   #11
private9
private9's Avatar
Well at $600 odd new, I only have $1200 more to go!!!
Old 26-06-2007, 03:15 PM   #12
FGII-XR6
FGII-XR6's Avatar
if thats all thats stoping you go for it
Old 26-06-2007, 03:25 PM   #13
private9
private9's Avatar
he he! No thanks! Was only going to try it because I had it - I'm not THAT keen!
