Old 11-07-2007, 04:51 PM   #1
ayeyew
Teh Baest
ayeyew's Avatar
Default Brake Lights not working on AU Falcon Series 1
Just found out today my brake lights are not working (all 3 of them, left, right & spoiler)
So i kinda figure there must be a problem with the wiring or something, cuz i checked the fuse and it was fine..
What is this brake switch i hear so many people talking about and where abouts is it?
Also is there anything else i can check?
I am getting a mate to replace my rotors and pads tomorrow (not because of this, but because my rotors are severely warped) Just wondering, is there anything i can get him to check for while he is doing it?
My reverse lights and tail lights work fine
1999 Liquid Silver AU
Show: XR6 Kit, Low, RDA Slotted's F&B, Fully Tabouli Sound System, Altezza Tailights (Good ones!)
Go: K&N Pod w/ 3" intake, XR6T Snorkel, Pacie Comp 4480's, 2.5" Cat Back, CMS Stg2 Cam, Custom Tune, Tranny Cooler
Coming..CMS Stg2A Cam, 68mm TB
Later.. 4.5L w/ BOOOOOOOOOOST or XR6T or AUIII XR8 220
Currently:
151kW (165 on other dynos )
ayeyew is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2007, 05:12 PM   #2
stavros68
your brake switch is located on the pedal is stuffed,has got a clip and a plug going to it, go to autobahn about $15,ive changed 2 in 3 years
stavros68 is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2007, 05:30 PM   #3
walker
walker's Avatar
I tink 1 way to check if your brake switch is working is to (if you have cruise control) turn on cruise and see if it cuts out when you touch the brake.......Not sure if this will work it's just a suggestion
Its not peer presure..........Its just your turn!
XE project underway
walker is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2007, 05:38 PM   #4
JC
JC's Avatar
Actually, just unplug the brake switch at the pedal, and connect the wires in the plug - if the brakes light up, then the switch is dead.
Ford Performance Club ACT
Old 11-07-2007, 06:11 PM   #5
ayeyew
Teh Baest
ayeyew's Avatar
sweet as!
Thanks guys
Is the switch easy to get off? Will i need any tools or is it just a plug in type of thing?
Too cold to look at tonight I'll do it in the morn
Currently:
Old 12-07-2007, 04:10 PM   #6
ayeyew
Teh Baest
ayeyew's Avatar
Did what was said, then put the wires back in and it decided to work, lol
Must have just been loose!
It's so bright behind me now
Currently:
Old 12-07-2007, 10:31 PM   #7
rampage101
Probably wasn't loose, they just f%#@ up. Had mine stuff up, and my car is still covered by extra warranty, took it to ford for other warranty work, and they replaced it while they were going (not covered, then tried to charge me!)
rampage101 is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2007, 09:13 AM   #8
EvilChief
Boost Addict
warped rotors can be machined if plenty of meat is left. pads can be linished if plenty is left too.
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 14-07-2007, 10:11 AM   #9
waggaclint
waggaclint's Avatar
most of the time if ya just remove the little black plastic sleeve thing from the switch it will work fine....half the time its not the switch...i used to work for ford when the au ser was new hey and most of the time thats how we would fix em....
waggaclint is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2014, 09:15 PM   #10
VOGGA
Default Re: Brake Lights not working on AU Falcon Series 1
My falcon au series 2 has no brake lights when I hit the brakes. It lights up when I turn on the headlight switch. IT does not get brighter when I hit the brakes. Replaced the switch with a brand new switch. Checked fuse and is OK, Took it to a tyre and brake specialist and he said I have to go to auto electrician to get it checked out. Can anyone help me to see if there is anything else I could check?
VOGGA is offline   Reply With Quote Multi-Quote with this Post
