Old 24-07-2007, 09:42 PM   #1
Fairlane
V8 Powaah
Fairlane's Avatar
Default Belt Tensioner
Got a bit of a query here, but what is the top belt tensioner (one circled)worth on the AU 6?
Im almost certain mine has just gone cactus, car sounded like it was supercharged (i wish) this morning with a whine which increases with revs, im almost certain it coming that that area on the motor. Serpentine belt is fine, so im almost 100% its that tensioner. Bit cheezed off to be honest, its a damn annoying thing car has only got 130k on it and i need the car 100% at the moment, i know its only noise, but im a obsessive nutter when it comes to these things.
FG G6E Turbo- Seduce & Cashmere - Sold
XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
Fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2007, 10:02 PM   #2
blackers10
blackers10's Avatar
are you sure the power steering fluid is full??
if it is low it sounds like a supercharger!!
Old 24-07-2007, 10:47 PM   #3
Fairlane
V8 Powaah
Fairlane's Avatar
Nah power steering fluid is good, its a new pump.
Old 25-07-2007, 06:06 AM   #4
au2sw
Blown 5L coming
au2sw's Avatar
best way to check which pully it is thats making the noise is to get a long screw driver, pointy end on the non moving area of the pully bolt. a slight hum will be heard on a good bearing, a real grinding noise will be heard on a bad one. and i believe the idle/tensioner pully combo are one unit your best off trawlling ebay or going to the wreckers for these rather then going to Ford who will charge you twice as much as anywhere else!!
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2007, 09:32 AM   #5
bodes-sh
when i got my car just over a year ago it was making that sort of noise, well more of a grinding sound, took it back to the dealer the next day, changed that pulley, all good ever since, so that's probably what your problem is....mind you then it only had 115k or so on it
Old 25-07-2007, 09:43 AM   #6
waggaclint
waggaclint's Avatar
you can replace the pulleys seperate upper and lower pulleys pretty common for them to get noisy as said early you can check em with a long screw driver i cant remember how much they are but ..i know you can get metal afta market ones that are alot better than the factory plastic ones Repco or someone like that will sell em....
waggaclint is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2007, 11:14 AM   #7
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
about $150 or so. I had the tensioner and belt changed for $200 a while back -- the belt started shredding cos the tensioner was warped or something
Old 25-07-2007, 12:53 PM   #8
ENVI XR6
ENVI XR6's Avatar
it could be the bearings in your alternator going dead, mines doing the same thing
Ford Forever!
Lowndes Is No.1
ENVI XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2007, 01:31 PM   #9
Hords
Treasure your balls?
Hords's Avatar
Wrong thread, sorry...
Meteorite T3 TS50 ESS
Hords is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2007, 06:10 PM   #10
Fairlane
V8 Powaah
Fairlane's Avatar
Got a new pulley today, it feels a lot better (and quieter_ to spin than the old one. Will swap it over on friday.
