Old 25-07-2007, 03:39 PM   #1
V8falcons
V8falcons's Avatar
Default VCT head to intech block
Gday
Just surfing ebay ,and found a VCT head complete,It got me thinking how hard would it be to fit and wire up with the VCT solinoid and is it absolutly neccesary to connect,will it work with out the VCT triggered?
I dont have the intension to do this just wondering if it could be done as Im sure someone else would try it !
CLICKY:http://cgi.ebay.com.au/ws/eBayISAPI....77#description
Id go for a HP cam and XR6 ecu fuel pressure reg,if I was to go for more performance with the intech
T2 TE50 no:154 Narooma blue
AU2 XR8 ute
XR4 fiesta
V8falcons is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2007, 03:54 PM   #2
FGII-XR6
FGII-XR6's Avatar
if you don't connect the VCT whats the point? to get this head running you need the cam gear the oil line and sender adaptor the ECU and you need to run an extra wire from the ECu to the VCT acctuator which is pin 72 on the ECU
Old 25-07-2007, 04:41 PM   #3
V8falcons
V8falcons's Avatar
There is no point it was a question!!!!!
Is the cam profile better than an Intech or hp cam,before the VCT solinoid come in.
AU2 XR8 ute
XR4 fiesta
Old 25-07-2007, 04:53 PM   #4
FGII-XR6
FGII-XR6's Avatar
the HP cam is better than the VCT cam if you are just going to use it as a static cam you get the added advantage by using the VCT
Old 25-07-2007, 06:10 PM   #5
b2tf
not here much anymore
b2tf's Avatar
Bit of a pointless exercise unless you intend to turn your engine into a VCT. If you want to do a head swap, track down an XR6HP head and whack a decent cam in while you have it apart.
2024 F150 XLT
Old 25-07-2007, 08:09 PM   #6
FS5
i've been thinking about trying a vct cam in a standard head for a while now.from the price you pay for a vct cam (around $220 )and theres no need for the extra cost of valve springs or shims its pretty cheap.compared to a stock au you should pick up an extra 11kw on paper.but going buy how these vcts pull some good numbers on the dyno's i'd expect a little bit more or a lot more if you have a piggy back chip or edit and usual zorst/intake mods..
from what i gather the vct only advances the cam ,this will only effect your low down torque.you will still get the same topend power curve of a vct,but it would be a bit slugish down low.
for outright power i reckon a vct cam would produce more topend power than a hp cam ,not buy much though .
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17.
FS5 is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2007, 12:12 AM   #7
b2tf
b2tf's Avatar
Dont know if it's only the V8 school of thought but I was under the impression that if you do a cam change you basically have to do valve springs as a bit of insurance.
2024 F150 XLT
Old 26-07-2007, 12:21 AM   #8
flathead 276
I would have thought the same. Valve springs are cheap, a rebuild isn't.
flathead 276 is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2007, 03:42 PM   #9
FS5
its a factory cam that runs on the same standard au i6 valve springs
Old 26-07-2007, 05:10 PM   #10
FGII-XR6
FGII-XR6's Avatar
don't put the vct cam in put the HP cam it has a better profile and is only $170 new from ford (trade price) you don't need to change the springs but it is a good idea to do the seals. with the higher lift the tend to leak and you blow smoke it happened to me. this can be done without pulling the head off with the right tools
