Old 16-09-2007, 08:31 PM   #1
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
Default Brake fuse problem
Just recently, like last week the ute has been blowing the brake fuse just about everytime I drive it. And it's only ever that fuse.
I know about the brake switch on the pedal and it may need replacing, but would a stronger fuse (like 20-30 instead of 15) stop fuses continually blowing?
Carless
Old 16-09-2007, 08:59 PM   #2
EX-Y494
EX-Y494's Avatar
No, don't put bigger fuses in. The wires will burn and melt.
Proud member of the All Ford Club of QLD
_____________________________________________
98 AU FORTE-Congo Green
C2R body kit, 2 1/2 cat back Exhaust, Red Diamond 2800rpm stall converter
BA front brakes, BA air box with pod
http://www.aufalcon.com.au/cgi-bin/i...act=item&i=326
EX-Y494 is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2007, 09:27 PM   #3
TheSneakiness
Adapt or perish...
Fair call. I won't be doing that.
What though would cause the fuse to just keep blowing like it does?
Carless
Old 16-09-2007, 09:30 PM   #4
InfernoSR
Sales Representative
InfernoSR's Avatar
Have you thought of a low amp auto reset circuit breaker until you get the fuse sorted? saves on fuses :P
Check the power into the fuse and out... make you its not spiking.
Old 16-09-2007, 09:33 PM   #5
peterban
AULTD
peterban's Avatar
I would be guessing a short in the brake light switch.
Only other thing could be the brake light globes themselves. Sometimes ( rarely )if they blow they can cause a short.
peterban is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2007, 09:35 PM   #6
TheSneakiness
Adapt or perish...
I checked the brake lights out before I changed the fuse and they were fine, always have been.
I'm thinking I need to get the brake switch changed.
Carless
Old 16-09-2007, 09:41 PM   #7
TheSneakiness
Adapt or perish...
Unfortunately when it comes to auto electrics I have no freaking idea.
Carless
Old 16-09-2007, 10:31 PM   #8
Stav
Smile
Stav's Avatar
Have you got a tow bar and wiring harness?Sometimes the trailers wires short out.
Old 16-09-2007, 10:35 PM   #9
EX-Y494
EX-Y494's Avatar
You can do this to see if it is the brake light switch is the problem. unplug the plug from the switch get a paper clip straighten it out into u shape and push it into the plug the brake light should come on and if it blows the fuse then its not the switch.
Old 17-09-2007, 11:12 AM   #10
Mechan1k
Mechan1k's Avatar
I'd be checking this out as well ... it's usually the cause.
If you are not sure ... get a trusted auto sparky to check it out for you.
Old 17-09-2007, 03:23 PM   #11
TheSneakiness
Adapt or perish...
No towbar.
I'm going to try what EX-Y494 suggested.
Carless
