Old 22-09-2007, 08:57 PM   #1
InfernoSR
Sales Representative
InfernoSR's Avatar
Default AU I6 Spark Plug Leads...
I have searched this... and keep only coming up with " Best spark plug leads???", and doesn't have the info i require..
What i need is pics/diagrams/instruction on the best way to replace the leads on the I6. The only way we can figure it to remove the top of the BBM to get a hand down to the Coil Pack... am I even close with this option or is there a more efficient/easier way to do this.
Old 22-09-2007, 09:14 PM   #2
phildee
phildee's Avatar
If you pull the airbox/intake piping out you can easily reach under the BBM to change them.
phildee is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2007, 09:42 PM   #3
InfernoSR
InfernoSR's Avatar
Been there and done that... with no luck... still not enough room.
Old 22-09-2007, 10:45 PM   #4
waggaclint
waggaclint's Avatar
keep trying they are easy as i just remove intake snorkel and thats it.... stick ya arm up in there no3 & no4 are the hardest or if ya havn to much trouble jack it up and take em of from underneath.....
waggaclint is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2007, 05:13 AM   #5
T-Pak Addict
Jim
T-Pak Addict's Avatar
I remove the whole airbox... takes about 15 minutes and I only do 1 lead at atime so I dont stuff up
The Daily. White 2017 ZG Escape TDCI AWD Wagon
The Wifes. Grey 2015 MD Mondeo TCDI Hatch
The Old Daily.......2003 Octane BA Taxi Pak Egas Falcon Build Thread
T-Pak Addict is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2007, 10:56 AM   #6
InfernoSR
InfernoSR's Avatar
Buggered if i know why mine is a right pain in the *** with the leads... I cannot gain easy access to the coilpack by simply removing the intake piping and airbox.
Old 23-09-2007, 11:35 AM   #7
T-Pak Addict
Jim
trick is to stand directly in front of the car (lots of bending) and just about put your whole right hand thu the maze of crap under there and feed the lead down thru the top with your left hand. its a pain but can be done alot easier than an EA-ED, now they are a pain in the butt.
Old 23-09-2007, 01:57 PM   #8
InfernoSR
InfernoSR's Avatar
I did the leads on my XG (same engine as an ED) alot easier than this... but we removed a few things and can now JUST get in there... thanks all the same guys.
Old 23-09-2007, 06:19 PM   #9
waggaclint
waggaclint's Avatar
au is heaps easier than a ed etc.....just remove the air intake and snorkel and ya can put ya whole arm in under the inlet manifold.....
Old 23-09-2007, 07:16 PM   #10
EF Futura 07
14.915 @ 151 KPH
EF Futura 07's Avatar
or if your small like me you remove the airbox and you can sit in the space where airbox is, and change the coil pack in 10 minutes : : : : leads are easy, the first time i did it i wasnt real sure and it took me over an hour, when i changed my pack,leads today took me about 20 minutes :
:evil3: 96 EF2 Futura I6 Auto :evil3:
EL XR Front, 16 inch Tickford's, Superlow's Front/Rear with Monroe GT Sport's : , XR6T Snorkle/Fram Filter, 4499's/Hi Flow Cat/2.5 inch Redback, 4.11's/LSD, 5% Tint, Sony Head Unit/ 6 1/2 Inch 190w Speaker's
: 14.915 @ 151 kph 60' 2.254 :
EF Futura 07 is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2007, 09:10 PM   #11
InfernoSR
InfernoSR's Avatar
lol... well unfortunatly when i stuck my hand up under the inlet manifold... it kinda got stuck getting it back out... not a pleasent feeling at all... My father had more luck though, as he has smaller hands. Well atleast with bigger hands i can grip things better with and i've never had a complaint from a girl ;) :
