Old 25-10-2007, 10:38 AM   #1
xr8driver
Default Loosing Oil Pressure
Hi guys i have a AU 5.0L, and i am loosing oil pressure when my car gets to normal running temperature and idling at the lights, but then builds back up to normal once cruising. I also noticed this is made worse when the aircon is on.
I did the normal things, checked oil, its full! And theres no leaks anywhere.
Any suggestion?? Oil sender? Oil to thin? another earth?
thanks guys
xr8driver is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2007, 11:30 AM   #2
jeffb
jeffb's Avatar
Could be anyting from bad oil/sender to worn main bearings, first thing to try would be to change the oil, maybe use something a bit thicker, I run 20w in mine.
jeffb is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2007, 12:02 PM   #3
OzJavelin
OzJavelin's Avatar
Is the HOT oil pressure level lower than "normal" (when HOT) or are you just noticing the usual difference between COLD and HOT oil pressure?
I'd be getting the COLD and HOT pressure checked with a proper, external gauge before I'd be getting to worried ...
OzJavelin is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2007, 12:09 PM   #4
xr8driver
The HOT oil pressure in not lower than normal when driving but once stationary for a short period of time it slowly begins to drop sometimes to the point the warning light comes on.
Old 25-10-2007, 12:21 PM   #5
FGII-XR6
FGII-XR6's Avatar
test the oil pressure with a proper oil gague first
Old 25-10-2007, 12:40 PM   #6
TE50 027
Tickford Tough
TE50 027's Avatar
Is it series 1? Ford know about it, it's a faulty earth wire. The can replace it but will cost you for labour. My series 1 TE50 did the same thing.
Sparkling Burgundy T1 TE50 Build #027 - SOLD
TE50 027 is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2007, 12:49 PM   #7
xr8driver
yep series 1 mate
Old 25-10-2007, 01:11 PM   #8
TE50 027
Tickford Tough
TE50 027's Avatar
Cool, as I said it's almost certainly just the earth wire. When mine did it I had it tested and had the sender unit replaced only to find out that it was a 20c wire.
Old 25-10-2007, 02:48 PM   #9
kiwikid10
WHAP!!! POW!!! ZORK!!!
kiwikid10's Avatar
Same thing happened with my fairmont,
Faulty earth wire, replaced and bingo fixed!
If it doesn't work then move to testing other things.
CAR: 99 Fairmont,Silver
Engine: 5.0L,Tickford intake,extractors,exhaust.
Suspension: Koni adjustables lowered.
Bodykit: Havoc
Wheels:XR8 AUII 17's
Interior: upgraded to Ghia,rebolstered seats.
Have parts just need fitting: Territory front brakes, Police issue rear brakes,Full sound system,Alpine HU/Processors,Focal speakers,Xtant amps.
kiwikid10 is offline   Reply With Quote Multi-Quote with this Post
