Old 10-11-2007, 09:34 AM   #1
kenz
BOSS Pilot
kenz's Avatar
Question reversing noise issues
Hey guys my ute is making a a strange noise when I put it in reverse and start to move it makes a continuous clunk/grinding sort of noise. If I keep my foot on the clutch a bit more it doesnt really do it but if Im nearly released all the clutch it sounds pretty bad. I had it lowered a few months back and now have to reverse into my driveway and ive scraped a few times and its only just started doing it a week or so ago. Car specs are in my sig for those playing at home
thanks
Luke
Black BAII XR8 Ute
Blue SY Territory Ghia
Originally Posted by CAT600
No matter how good the F6 is (and it is damn good), its missing two cylinders.
kenz is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2007, 10:14 PM   #2
kenz
BOSS Pilot
kenz's Avatar
anyone :
Black BAII XR8 Ute
Old 15-11-2007, 04:59 PM   #3
Jaeger
Getting There
Jaeger's Avatar
That sounds like the same problem I have in my car.
Its been doing for about a year, and the LSD still works fine. I've just gotten into the habit of taking it out of reverse when I'm rolling backwards.
I'm pretty sure its Diff or gearbox but would like to know for sure if anyone knows.
Bumping this up for answers.
1996 EF2 XR6 Manual
Jaeger is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2008, 03:57 PM   #4
kenz
BOSS Pilot
kenz's Avatar
Have narrowed this down to being the reverse gear grinding whilst on the go pedal. Goes in and out of gear fine just grinds whilst driving. Suggestions, ideas?
Luke
Black BAII XR8 Ute
Old 12-02-2008, 06:55 PM   #5
phibza_XR6
drive it like u stole it
phibza_XR6's Avatar
i have this same sort of problem in my ute, i found it was when the motor gets put under load and shakes alot like it does when u take off in reverse and hardly touch the throttle, the mufflers hit under the cab. my ute has been lowered alot and i also have a custom exhaust on it. Coz i no this is the problem i just live with it
www.aufalcon.com/phibza
phibza_XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2008, 06:59 PM   #6
kenz
BOSS Pilot
kenz's Avatar
I live with it aswell but time is nearing when I need to get a RWC to sell it. But mine grinds when its not even under load and I can kinda feel it through the gear stick
Black BAII XR8 Ute
Old 12-02-2008, 07:02 PM   #7
phibza_XR6
phibza_XR6's Avatar
yeh doesnt really sound like the same stuff my ute is doing, sorry mate, probably could be reverse gear in the box
Old 12-02-2008, 07:54 PM   #8
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
If you have LSD, it could be that. You just need to get a small tube of "Stink" (LSD Lube Addative).
I had the same prob, and was fixed within two corners of driving away. Just open up your diff nut and squeeze it in - best, easiest, cheapest thing to try first...
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2008, 08:49 PM   #9
kenz
BOSS Pilot
kenz's Avatar
nah mate I dont have lsd
Black BAII XR8 Ute
Old 12-02-2008, 09:34 PM   #10
bodes-sh
normally that sort of grinding noise is synchros, but i'm not sure if au's have reverse synchros or not, some cars don't, but I'd say it's either that or a worn reverse gear...if it is that, the only way you can fix it is with new bearings/box rebuild
Old 23-02-2008, 01:39 PM   #11
kenz
BOSS Pilot
kenz's Avatar
Turned out to be the exhaust rubbing/ hitting against the gearbox mounting bracket. I cut the edge off it and it seems to be back to normal There was scrape marks on my cat which i think has pushed the exhaust up higher than it was
Black BAII XR8 Ute
