Old 08-12-2007, 11:00 PM   #1
OED666
OED666's Avatar
Default OED666, now with more Six Appeal
Can anyone spot the difference...
Exhibit A
Exhibit B
Well, if you havent guessed by now, the T5Z was replaced with a T56. :o
I went up to Mal Wood's on Thursday to do some work for a couple of days. Friday morning Ben (absolute gun with gearboxes) set to work on my car. Within an easy 40 mins, the tailshaft, gear box, clutch and flywheel, pedal and clutch cable was removed. Ben then set to work building a T56 from scratch. This is the scary part, as he just puts the damn thing together, all 11ty billion parts. They fitted an AU sandwich plate and then on with the old flywheel and clutch.
In goes a dummy box (just housings) to measure up for the tailshaft length. The front half of the tailshaft (i have a 2 piece) was made shorter for the extra length of the new gearbox. A small section of the trans-tunnel was cut as the shifter is positioned slightly further back.
BA Pedal Assembly...
Clutch feel is fantastic. They had to fit a new clutch as the fingers on my old pressure plate extended too far. I now have an ACE Option 2 clutch. Good for 240RWKW. Its essentially exactly the same as what I had, but the fingers of the pressure plate are suited for concentric slaves, instead of throw-out bearings. They also fitted braided lines, and a remote bleed line. Makes bleeding the clutch 11ty billion times easier, and no messy clutch fluid in the bellhousing.
The centre console fits perfectly is its original position. The shifter is a smigeon closer to the driver. I also had a nasty short shifter made up. The shifts are spasticly close.
I VERY EXCITE!!!
Big thanks to Mal Wood Automotive... Absolutely awesome work!!!
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2007, 11:15 PM   #2
EF Futura 07
14.915 @ 151 KPH
EF Futura 07's Avatar
looking good, so how does she go with the different ratios?
:evil3: 96 EF2 Futura I6 Auto :evil3:
EL XR Front, 16 inch Tickford's, Superlow's Front/Rear with Monroe GT Sport's : , XR6T Snorkle/Fram Filter, 4499's/Hi Flow Cat/2.5 inch Redback, 4.11's/LSD, 5% Tint, Sony Head Unit/ 6 1/2 Inch 190w Speaker's
: 14.915 @ 151 kph 60' 2.254 :
EF Futura 07 is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2007, 11:47 PM   #3
OED666
OED666's Avatar
the first four ratios in the box are nearly identical to what i previously had (T5Z Close ratio gearbox). 2nd is a little taller, 3rd is by a bee''s skrotum. I cant notice any difference between them though. 5th and 6th are awesome. I finally have something in between the highway gear, and now an even better cruising rpm. Its doing 1880rpm at 100 k's.
Turbo Barra ED 4L
Old 09-12-2007, 12:02 AM   #4
Dezza
Parts bin special
Dezza's Avatar
That's awesome! Hope you're times on the drag strip continue to improve.
Old 09-12-2007, 01:11 AM   #5
wicksy
Just a bogan VF SS driver
wicksy's Avatar
how much did that set ya back? or retail...
Just your typical Holden Driver
wicksy is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2007, 08:17 AM   #6
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
I suspect 11ty billion dollars...........lol
At least some one knows how to do it right, mod your engine, mod your gearbox............
What a beast of a transmission, I guess MAL WOOD has doen a few fo these or did you have a dumy box?
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2007, 09:01 AM   #7
Stav
Smile
Stav's Avatar
Hmm.With my auto slipping to buggery and this happenning.. are you selling the old box as I may be tempted to chuck it in.
Old 09-12-2007, 10:10 AM   #8
OED666
OED666's Avatar
Mal Wood have a 6 speed in their AU ute, so thats pretty much been their test dummy before mine. Everything went in perfectly, and without a hitch. They hadn't put in a BA master cylinder in an E-Series before. It looks like a factory setup.
Box is already sold for $1700. Including clutch and BA Turbo Mk1 flywheel. My old clutch had only done a few thousand k's, and is rated to 240rwkw.
Turbo Barra ED 4L
Old 09-12-2007, 11:45 PM   #9
DEVL-XR
EBII XR6
DEVL-XR's Avatar
Awesome work!! Got any pics of the gear stick and how it all sits inside?
DEVLXR
DEVL-XR is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2007, 10:27 AM   #10
OED666
OED666's Avatar
i am getting a ba knob today. i will take a pic tonight
Turbo Barra ED 4L
Old 11-12-2007, 02:11 PM   #11
HOON69
HOON69's Avatar
nice work paul
HOON69 is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2007, 03:06 PM   #12
OED666
OED666's Avatar
pic of the shifter.
pic of the fluid reservior.
Turbo Barra ED 4L
Old 11-12-2007, 03:26 PM   #13
ClassicAU
wow, thats fantastic work! It looks like Ben really knows what he is doing. I actually spoke to him myself before I put the 5 speed in my car. I would have liked to do this aswell, but I just couldn't justify the costs. I am never going to have the amount of power you have, so it just wasnt worth it.
What are the benifits of going to a T56, other than strength? Is it just having an extra gear for freeway driving, or is it quicker through all the other gears?
Looks great, you must be stoked!
Evan
ClassicAU is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2007, 03:32 PM   #14
DEVL-XR
EBII XR6
DEVL-XR's Avatar
Sweet as, have you got a BA shortened gear stick yet?
I got mine of ebay and you can see how short it is here:
It's also straight which makes gear changes feel alot better!
DEVLXR
Old 11-12-2007, 03:34 PM   #15
gozza
gozza's Avatar
Hahah - I have a straight cut stick too and everyone hates it
gozza is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2007, 08:32 PM   #16
jlef5
jlef5's Avatar
So how much did this set you back mate i would love to do this to my car.
jlef5 is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2007, 09:30 PM   #17
OED666
OED666's Avatar
havent got the final bill yet... the starting kit is around 7k, but I had hydraulics fitted as well.
Turbo Barra ED 4L
