Former BTIKD
![]() Join Date: Mar 2005
As the subject line says. Where is the coolant level sensor on my AUII barge.
I thought it was supposed to be on the header (supply?) tank but there's nothing there.
Falcon Unbelievable!
from memory there should be a like a bottle opening on the side of the coolant tank, if it has coolant sensor it will have the bits inside here if not then it doesn't have one. Mine had a fault come up where the ecu thought it had one when it didn't it was a false reading because nothing was there.
Former BTIKD
Thats what I thought, and where it was on my last 'lane.
This one has the round plug/bottle opening shape but, not sensor or wires are anywhere on the actual tank!!
are we talking tempreture sender ?
AULTD
Should have one on the side of the header tank.
Somebody must have put a new tank in without the sensor as they are a lot cheaper without the sensor. I wonder why the low coolant light is not showing and the car is not beeping at you?? Have a look for the plug that plugs into the sensor ( when it is there ), they may have shorted out the connection to stop it. Here is a link to one on e-bay http://cgi.ebay.com.au/FORD-AU-HEADE...QQcmdZViewItem You can buy the sensor seperate from Bayford for around $45 but I am not sure if you can just drill out the hole of the Header tank you have now. |
Former BTIKD
Nooo, like the subject line says coolant LEVEL sensor.
The one that tells you that you don' got no coolant left an' if you dont stop right now it's gunna blow'.
#7 | |||
Former BTIKD
![]() It's just whilst looking under the bonnet today I noticed there was'nt one on the tank where there was on old 'Lane...I'll go check out the radiator
the AU 6 has no coolant sensor from series 2 on as it just starts shuting cylinders down to prevent overheating. the cluster does not even have the function enabled only th V8 has the level sensor
Former BTIKD
Oh good, thanks au3xr6. I was starting to think it might have been me having an Alzheimer's moment.
I'd still prefer a coolant level sensor though, it'd be much easier to tell if a hose has gone instead of thinking the cars running a bit rough!
My XR6 AUI has a sensor, most Fairmont Ghia 6cyls do and Fairlanes.
#11 | |||
BOSS Pilot
My sensor is shagged so I unplugged it hoping to make the dash light go away but it just flashes at me constantly. Im not paying whatever they are worth $100 or something for a new one so does anyone know how I can make the dash light go away
Black BAII XR8 Ute Blue SY Territory Ghia Quote:
#12 | ||
The sensor doesn't cost $100.00 part Number is EA10K888A, more like about 40.00
#13 | ||||
Former BTIKD
#14 | |||
#15 | ||||
BOSS Pilot
#16 | ||
IIRC a 220 ohm resistor will do the trick
#17 | ||||
BOSS Pilot
#18 | ||
just put a 220 ohm resistor accross the terminals you can get one from dickies
#19 | ||
The only AU that may not have had a coolant low level sensor was the forte
all others had them.Come on guys get with the game aren't we Ford people. ![]()
FORD will be no1 again as the rest suck! |
#20 | |||
Former BTIKD
Come and find mine then please ![]()
#21 | ||
Former BTIKD
One tank sans sensor...yeah I know, the engine bay needs cleaning.
#22 | |||
I can see from your massive 10 posts you know it all. from series 2 on there is no sensor on any 6Cyl Falcons that includes LWB variants The series one had the sensor with the eception of the Povo pack (forte) the sensor was deemed redundant due to the cylinder shutdown feature as it was designed to prevent you cooking the engine. so " get with the game aren't you a ford person"
#23 | ||||
Back to Le Frenchy
You are right though, no sensor on AU from series two except for V8.
#24 | ||||
that was basically because of his air of superiority more than anything else
#25 | |||
AULTD
Just bought a new tank + sensor as it has gone a little bit brown. |
#26 | |||
not here much anymore
The fail safe cooling method that you describe of cylinders shutting down was present on all models regardless of series, it was not implemented to cut out the sensor. Rog yours being a Fairlane I thought it would have had one, its not hard to put one in, you just need the sensor and a new header tank.
2024 F150 XLT
#27 | ||
THE Fairmont Ghia 75th
now i know...i also didn't know that only series 1 had them, i thought it was weird but now its all sweet.lucky someone here knows what they're talkin about.lol
#28 | |||
Former BTIKD
I saw your ute in town today. How come you've put Hillis Ford Spare Parts signs all over it ![]()
#29 | |||
Hillis ute, bah!
2024 F150 XLT
#30 | ||
so if you have the sensor it must be a warning light only?
