Old 20-01-2008, 11:43 PM   #1
fourl6
AU Falcon Man
fourl6's Avatar
Default Help Fitting Tickford Suspension Kit (AU3)
so fitted the back ones today sitting maybe a 2cms lower but will settle down i think... had a knocking in the back right so tightened up the bolt on the top an bottom of the shocker and that fixed it up...
just after some advise with the front ones... oh and in the suspension kit i got one bracket with a rubber bit on the end.. anyone know where this goes... had a look around when i didnt see anything... its about 10x10x10cms with two holes to be bolted onto something...
just after some instructions like this (found in another thread) but for the front would be good..
changing rear shocks would have to be one of the easiest jobs u can do
jack up car and remove rear wheels and place stands under rear axles
lay down rear seat and remove plastic corner covers to gain access to top of shocker
remove top shocker nut - hold top of shocker shaft with a small shifter or mole grips and undo nut
undo bottom shocker bolt and remove
lower the shocker out thru the spring
installation is reversal of above - with note - make sure bottom bolt is very tight else you will have a knocking niose that will drive you nuts and it is not a bad idea to retension in a couple of weeks time with the full weight of the car on it.
cheers..
2015 SZ MkII Ford Territory TS
Aero Blue, RWD Petrol, Standard Sat Nav.
2013 TF Ford Kuga Ambiente
Panther Black, AWD, 6 Speed Auto, 1.6lt ecoBoost Turbo Petrol.
Was
2012 FG Mk2 Ford Falcon XR6
Swift Green,6 Speed Auto, Stock...
2001 AUIII Ford Falcon Forte
Genuine T2 TS50 bodykit, 18" BF Cobras, Boge and Eibach Suspension and Complete AU2 Fairmont Ghia Interior
1994 EF Ford Fairmont
Gun Metal Grey, Lumpy Straight 6
fourl6 is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2008, 12:41 AM   #2
GK
Walking with God
GK's Avatar
cheers..
Have a read through here, it may help a bit.
Changing Front Coil Springs
http://www.fordforums.com.au/showpos...1&postcount=27
Cheers,
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 21-01-2008, 01:14 AM   #3
JC
JC's Avatar
Cheers,
GK
A bit. Lol, you're funny GK. Your How To's are as good as having you there giving a hand!
Ford Performance Club ACT
Old 21-01-2008, 10:46 AM   #4
GK
Walking with God
GK's Avatar
JC coming from you, that is indeed a great compliment. Many thanks!
GK
Now gone!
On LPG
Old 21-01-2008, 01:57 PM   #5
fourl6
AU Falcon Man
fourl6's Avatar
thanks thats going to make it a lot easier...
Was
Old 21-01-2008, 02:23 PM   #6
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
Yeah gotta agree, that guide helped me out big time! had the laptop sitting nearby. Although i gotta say it was a bit hard keeping my hands clean so i could scroll down the page ;)
DoreSlamR is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2008, 05:36 PM   #7
fourl6
AU Falcon Man
fourl6's Avatar
so what is this thing and should i have two...?(i only got one...)
Was
Old 21-01-2008, 07:23 PM   #8
JC
JC's Avatar
That's your bump stop. I assume it was at the back? If it goes over the centre of the diff, then only one is required. If it sits above the axles, then yes, you should have 2. Should be able to get one from a wreckers easily enough.
Old 21-01-2008, 08:54 PM   #9
fourl6
AU Falcon Man
fourl6's Avatar
um it was supplied with the kit... so it would it be a replacement or a addition?
Was
Old 21-01-2008, 09:48 PM   #10
JC
JC's Avatar
Probably replacement for the one over the diff.
Old 21-01-2008, 11:13 PM   #11
FTe342
FTe342's Avatar
In GK's link about the front shocks, at point 8, you don't need to lever the lower arm etc down if you do both sides at the same time and release both top ball joints.
Without doing this it is nearly impossible to do the job on you own
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust.
AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl
OWN THE ROAD
FTe342 is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2008, 08:12 PM   #12
fourl6
AU Falcon Man
fourl6's Avatar
Now lowered with Genuine a New Tickford Lowering Kit...
Full Sized Images:
http://www.myfoto.com.au/Photo/kerry...8/DSC00141.JPG
http://www.myfoto.com.au/Photo/kerry...8/DSC00140.JPG
Was
Old 24-01-2008, 12:10 AM   #13
JC
JC's Avatar
Looks great. Rewarding doing that stuff yourself, isn't it!
Old 24-01-2008, 06:06 PM   #14
GK
Walking with God
GK's Avatar
Thumbs up
Well done!
GK
Now gone!
On LPG
Old 08-03-2009, 09:01 PM   #15
cookin
trust me take the sway bar off the front when changing front shocks dead easy
cookin is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2009, 09:31 PM   #16
aye you
The Origional, The Best
aye you's Avatar
psssssttttttt this is over 12 months old mate
Current Mods
2.5" Red Back Exhaust | C2R Grill | Brumby Front Bar & Driving Lights | 18" Optic Blacks | Tickford Intake | Blue Momo Shifter Knob & Wheel | BA Scuff Plates with Ford Metal Inserts
Future Mods
Lowerage on KingSprings Lows | Engine...Period | Sounds System
I Use And Recommend F1 Tyres And Wheels On The Gold Coast
Proud Supporter of Beat The Heat (NT)
aye you is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2009, 10:58 PM   #17
fourl6
AU Falcon Man
fourl6's Avatar
when i put the ssl spring in (a month ago now) i got some stands and had both front wheels off at the same time... did make it alot easier...
Was
