Old 20-02-2008, 02:43 PM   #1
poolkeeper
Its Resonating!
poolkeeper's Avatar
Default AU2 Brakes on AU1
Hey guys I have got some AU2 calipers (all 4) disc's, pads, braided lines.
I want to put these on my ute which is AU1.
Ba to au brake thread has way to much info to understand.
So whats needed?
poolkeeper is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2008, 02:52 PM   #2
sly
Sly like a G6
sly's Avatar
Try this search http://www.fordforums.com.au/showthr...r+control+arms it will bring up a list of threads containing the words "lower control arms", some of which are brake-related. Near the top of the list is a thread about "Brake Upgrade for the Mechanically Challenged". It's a lot smaller and more digestible than the huge BA upgrade thread, and should tell you everything you need to know about changing the front brakes.
As for the rears, are the AU2 discs & calipers from a ute/wagon, live axle sedan or IRS sedan? Some have found that the AU2 on rear calipers need 3mm spacers to line up with the discs on some AU1 sedans. I fitted BA ute/wagon rears to my AU1 wagon and they bolted straight on without mods.
Sleeper, anyone?
Old 20-02-2008, 05:50 PM   #3
HLC
Audi S3
i bolted BA2 ute brakes to my AU2 sedan. and they all work.
not that that helps much.
Old 20-02-2008, 06:27 PM   #4
sly
Sly like a G6
sly's Avatar
I think the issue might be with IRS AU's... not sure and probably not relevant. I just wanted him to know that if he went to bolt on the rears and the calipers didn't line up with the discs, that others had solved the problem before.
Ooops, just re-read your post, see what you mean (not v. well today). Trying to get every last skerrick of brake performance then? Do you have a fairly wide unswept band around the hub? The inner ends of my slots are outside the pads.
Sleeper, anyone?
Old 21-02-2008, 12:57 PM   #5
poolkeeper
Its Resonating!
poolkeeper's Avatar
It all came off a ute guys, Ill check out that link now.
