Old 20-02-2008, 03:03 PM   #1
mr302xd
Formerly MR BAXR6t
mr302xd's Avatar
Default Another cracked firewall!!
Does anyone know where i can get my firewall fixed in sydney in the western suburbs??
I have a cracked firewall where the clutch cable goes through yay! And it pretty major.
Any ideas wat ill b up 4??
Current car
94 ED Fairmont 5L in Burgundy
Fords ive owned-
2010 FG XR6 5 speed auto in Mystic
81 XD S-Pac 302c 4sp manual
78 Yellow TE Cortina Wagon 4.1L
92 Green EB Fairmont GT replica
01 Black AU XR8 II Manual
04 Rapid BAII XR6T 220rwkw
04 Mandarin BA XR6T 247rwkw
07 BF II XR6T 385rwkw
1980 ZJ Fairlane 302c
mr302xd is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2008, 05:15 PM   #2
howesy
howesy's Avatar
Any panel beater can do it but to get it done properly be prepared to pay a decent job will set you back around the 400 to 600 mark which should leave it looking pretty good.
Can't beat a Windsor for sound and low down torque.
Liquid Silver Pursuit250
Custom gear and diff ratios
ECU
Exhaust
Crow Comp. Valve springs
Adjust. Rollers
Cold air
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2008, 05:23 PM   #3
GXR
Power & Torque
Yeah sounds about right.
I live in Victoria, same problem cost me $550. I went to my mechanic who recommended a panel beater he has used before who has experience in this area. Very happy with the job.
Also, I did have water leaking into the car. When driving I would get water dropping on my right ankle. I took it to my panel beater who found that 3 out of the 4 spot welds had cracked. This occurs where the pedal box attaches to the plenum chamber. I had this repaired under warranty. The Ford Dealer had never seen this before. I said it is a common problem. No dramas, the clutch is as smooth as. Good Luck
GXR is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2008, 05:30 PM   #4
mr302xd
Formerly MR BAXR6t
mr302xd's Avatar
i got quoted bout 1000 buks!!! All the panel beater around here are still dealing wwith the hail damage cars and are backloged for bout 3 weeks!!
Current car
Fords ive owned-
Old 20-02-2008, 07:22 PM   #5
mr302xd
Formerly MR BAXR6t
mr302xd's Avatar
heres a pic of my fire wall
Current car
Fords ive owned-
Old 20-02-2008, 07:28 PM   #6
HLC
Audi S3
my car is nowhere near close going to the panel beaters yet lol its crazy!
Old 20-02-2008, 08:04 PM   #7
rob_liss_lms10
rob_liss_lms10's Avatar
I had a cracked firewall and was quoted about $500. not wanting to pay this amount, I set about fixing it my self, the repair I'm about to tell you was done about 1 month ago and is still holding strong with no evidence of movement or cracking. Remember this is how I fixed it, it may not be the best,but is working and cost $15...so here goes.
1st..remove clutch cable from pedal and pull cable back into the engine bay out of the way.
2nd..using long socket extension bar or similar gently tap from the inside of car the broken edge of the firewall until it is back level with the rest of the firewall.
3rd...using 2 part stronger than metal epoxy, apply to both inside and outside of firewall and allow to harden...and don't skimp on it.
4th...I used the metal holdy down thingy for the spare wheel ...(the bit that actually pushes down on the wheel...I used 1 from an EB..only because I had 1) as a brace so the firewall doesn't push back in. You have to drill the hole a bit bigger so the clutch cable fits.I also painted it black so you can't see it easy.
5th...fit brace over threaded clutch cable and insert back through firewall. The brace has just the right amount of natural bend to be off the firewall and clear the sticky out knobby bit the cable goes through, dont drill the hole to big or the brace will go over the sticky out knobby and it wont be a brace any more.remember...the brace is now replacing the knobby bit as the tension point...the knobby bit is now only a guide so the cable stays straight.
6th...put clutch cable back onto the pedal, adjust nut on clutch cable (against the brace)until you have correct pedal and take for a test drive.
7th...go to the pub, get some beer and enjoy knowing you have saved $500 so deserve that icy cold beer...every one happy except for the panel beaters.
excuse my high tech naming of various parts..eg sticky out knobby bit..as I have no idea what they are actually called. As I said before, this may not be the best fix, but it worked for me.
Rob
Red bull gives you wings?: nahhh.... we got our wings from TICKFORD
rob_liss_lms10 is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2008, 08:08 PM   #8
atec77
if you know someone who can weld (mig is best) then do the job your self . I did one recently in a couple of hours with stripping and welding 1mm stainless plate onto the f/w...
dril lots of small holes and weld each like a small spot weld.. it will NEVER break again just remember to make it large as you can to spread the load//
Old 20-02-2008, 08:11 PM   #9
stiddy
stiddy's Avatar
Speak to Mark from It's Performance, mine was one of the worst if not the worst he had ever seen 1 day and 300 bucks later it will never crack again..
He's out Campbelltown..
Old 20-02-2008, 08:29 PM   #10
VCT_XR6_UTE
VCT_XR6_UTE's Avatar
I picked my ute up on monday from having the job done, straightened and welded up, was a really bad mess before, now is straight and feeling awesome, cost me $390
VCT_XR6_UTE is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2008, 09:01 PM   #11
mr302xd
Formerly MR BAXR6t
mr302xd's Avatar
y have i got quoted soo much!! Theyve told me the have to take half the dash out and all this??
Current car
Fords ive owned-
Old 20-02-2008, 09:49 PM   #12
philstoj
philstoj's Avatar
Because yours is a V8 and there is less room to work in the engine bay, these other guys have 6cyls, more room there to work from engine bay.
Old 20-02-2008, 09:52 PM   #13
mr302xd
Formerly MR BAXR6t
mr302xd's Avatar
AHHH. Thanks didnt even think of that!
Current car
Fords ive owned-
Old 21-02-2008, 02:46 PM   #14
loxxr6
XB in parts...
loxxr6's Avatar
Is he still around these days???
Give Joe @ Crescent Motors Liverpool a call.
Mark from ITS Performance did part of mine and Joe had a look at the rest.
Old 22-02-2008, 05:54 PM   #15
Mechan1k
Mechan1k's Avatar
Joe has just done a few of these in both AU and E-series vehicles in recent weeks .... the V8s have less rom as stated. At least t's easier to fix and A firewall compared to an EF/EL ... they can be a right pain.
Old 22-02-2008, 06:28 PM   #16
mr302xd
Formerly MR BAXR6t
mr302xd's Avatar
Yea booked mine in to get done at Cresent Motorsports, Joes gunna have a crack at it.
Just got no car till then which sux! Dont want to risk drivin it and causin more damage
Current car
Fords ive owned-
Old 22-02-2008, 08:16 PM   #17
XH5LWEPN
Boost is here!!
XH5LWEPN's Avatar
Rob
Got ay pics of how that looked in the end???
STREETBUILT RACING
'99 XHII XR8, 363w, GT4508R on 16psi, E85, C4, 910rwhp - ET coming soon!
'78 XC Falcon 500, Desert Gold, 351w, V2 on 16psi, E85, C4, 9" - 10.15@132mph!
XH5LWEPN is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2008, 11:26 PM   #18
blue terra
au=gold
blue terra's Avatar
Dont worry mate i paid well over 1000 for mine to get fixed. Thats what happens when ford fixes it. But it wont pull through again got 3mm plates either side bolted and welded.
blue terra is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2008, 02:39 PM   #19
rob_liss_lms10
I still have to either paint the fire protection or recover, but this is how it ended.
Old 25-02-2008, 06:39 PM   #20
Rebel
Rebel's Avatar
Is this common to a particular series in AU's?
2008 FG GT 315 EGO #460
1968 Falcon Sports Coupe **2012 PCOTY winner**
https://www.fordforums.com.au/showthread.php?t=11325000
1990 XF Falcon Panelvan
Rebel is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2008, 07:19 PM   #21
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Seems to me , all of a Sudden all the AU"s are Producing Similar Problems ..
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2008, 08:11 PM   #22
mr302xd
Formerly MR BAXR6t
mr302xd's Avatar
Got my fire wall fixed today!! I strongly recommend Joe from cresent motorsport at liverpool, if anyone in sydney has the same problem!!! only $350, which is cheap considering some other quotes ive seen. Its not a bodgey job either good srong weld with a plate made!!
Fantastic work
Frank
Current car
Fords ive owned-
Old 26-02-2008, 08:57 PM   #23
LPGUTE
LPGUTE's Avatar
Hi dose your clutch cable move around?
Many Thanks
2001 AUII Factory LPG Manual XL Styleside Box
High series bonnet
Clear Side Indicator
K&N Air Filter
BAXR6T Snorkle
Low Fronts, Super Low Leafs
LPGUTE is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2008, 09:29 PM   #24
mr302xd
Formerly MR BAXR6t
mr302xd's Avatar
Im not to sure... dont think so? its all workin perfectly
Current car
Fords ive owned-
