Old 23-02-2008, 11:14 AM   #1
b2tf
not here much anymore
b2tf's Avatar
Default Removing A Pillar Covers
Hi all
Going to give installing these new speakers a shot today, can anybody tell me how you remove the A pillar covers to get to the tweeters?
Ta
2024 F150 XLT
Old 23-02-2008, 11:30 AM   #2
JMO
JMO's Avatar
Grab the top of the plastic and pull it away from the pillar. There are two little guide tabs at the bottom, so don't pull too hard so you don't bend them. Then just tilt it away from the pillar and lift it out.
JMO is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2008, 11:46 AM   #3
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
Pull away the door rubber first, then do as JMO said.
DoreSlamR is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2008, 11:51 AM   #4
RUKIDN
Missing the boost :(
Im going to be removing mine also so i can install some gauges so this info is gonna help. Last time i took one off in my EB i broke one of the clips or something lol so im more cautious this time..
BA XR6 Turbo
301rwkw mild tune
Modified by XR6Turbo Developments
RUKIDN is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2008, 12:54 PM   #5
StealthAu
It is pretty hard to break them, just start at the top.
Old 23-02-2008, 01:13 PM   #6
blackers10
blackers10's Avatar
if you put your head above it so you can see down the gap as your pulling you can adjust the angle of pull to help the guide pin/clips pull out straight rather than sideways hence reduced risk of snapping
the good thing about AU's is they arnt that old so the plastic isnt like fine china and doesnt shatter lol
