Old 27-02-2008, 01:20 PM   #1
fernsantos
Default Power steering pump for au2 i6
Hi
I have a fairmont ghia au2 i6 and the power steering pump is leaking onto the alternator so i have to replace it.Does anyone got any ideas of someone in the sydney area that specializes in power steering pumps.
Is it better to get a new one or a reco one.
I rang Ford and they want about $500 to supply and install.
Another place i rang said $160 supply and install a reco one and 1 year warranty or $240 for a new one supply and install.
Any help will be much appreciated.
Regards
Fernando
fernsantos is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2008, 01:24 PM   #2
blueoval
Critical Thinker
blueoval's Avatar
If i were you, Id forget getting ford to do anything unless you have big wads of cash to throw away.
Those other prices you mention sound reasonable. But for the sake of an extra $80 get a brand new one supplied and fitted. they usually have a better warranty than a reco one.
I cant help with any good locations as Im in SA, but ringing around prior to making a choice is always a good start.
"the greatest trick the devil pulled, is convincing the world he doesn't exist"
2022 Mazda CX5 GTSP Turbo
1967 XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2008, 01:31 PM   #3
tickford90
Mine had the same problem and I had to get a brand new alternator. But to fix the power steering pump I bought a sealer chemical which you put into the pump oil. It has fixed it for about 8 months. There's idea to think about.
tickford90 is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2008, 04:38 PM   #4
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Fernando ,
Are you sure its the Unit itself or is it just the Hose where it comes out of the back .. Ill have a ask at the wreckers tommorow for you !
Daniel
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2008, 08:19 PM   #5
b2tf
not here much anymore
b2tf's Avatar
The pumps are the same from EF right through to AU3 if that helps and as has been mentioned it is commonly the hose at the back of the resevoir that buggers up.
2024 F150 XLT
Old 28-02-2008, 02:43 AM   #6
cgglasson
G'day
Mine too is leaking from the power steering pump, but as AU2PWR had stated it seems to be the hose at the back (high pressure hose according to my mechanic).
About $200 from ford, or good'ol ebay has them for about $70.
I know where I'm getting mine
cgglasson is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2008, 10:10 AM   #7
fernsantos
Hi
Is it easy to check if it is the hose at the back how will i be able to tell.
Thanks
Old 28-02-2008, 04:07 PM   #8
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
There is a Metal Connection from the Pump to the hose .. if its leaking .. its your Problem
AU2PWR
Old 28-02-2008, 04:24 PM   #9
Mechan1k
Mechan1k's Avatar
Also if getting the HP hose replaced ... get the teflon o-ring that is meant to go with it as well.
As for a mechanic in Sydney ... I use and recommend Crescent Motorsport in Liverpool for my work ute (and now Territory as it is out of warranty).
Old 29-02-2008, 02:32 PM   #10
fernsantos
Hi
Thanks for everyones input.It was the high presure hose i got it done at a place in Auburn Sydney called CV JOINT they sell their staff on ebay as well.
It cost me $60 for the hose and $50 for install with 12 months warranty.
Old 29-02-2008, 02:43 PM   #11
blueoval
Critical Thinker
blueoval's Avatar
Originally Posted by fernsantos
Hi
Thats great to hear. sounds like u got away with it fairly cheap. Keep an eye on the leak though incase it could be something else.
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
