Old 17-03-2008, 09:42 PM   #1
nikos
mezzo forte
Default Temp gauge phenomenon
Ok today I was doing a lot of stop-start driving in my au1 forte 4.0 with 153k on the clock, 35degC+ with aircon on full and a coupla passengers worth of weight. Temp gauge was consistently on the 'O' of NORMAL. I stopped the engine, went into a shop and come out 2 mins later. When I started up again the needle flicked straight to max 'H' and the warning light/beep came on. After 5sec of idle it fell back to 'O' again, and all was well. This happened after all stops.
Has this happened to anyone else in the heat? I was told that it is the water ceasing flow that imediately heats up in the engine when turned off, and when engine is turned on again it flows out replaced by the cool radiator water.
I'm assuming there is no real problem, just curious as it has never happened before. Also the car seemed a little gutless and tranny was a little whinier than usual, but I'm just assuming that was the heat and high load on the car.
Discuss
nikos is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2008, 09:44 PM   #2
bodes-sh
i haven't heard of this problem on an au before, but on a patrol forum i am a member of people have had similar issues with patrols, turn off when hot, then turn back on shortly after and the temp gauge goes straight to hot, then back to normal.....i would think it is just caused by the hot coolant sitting there with no way to cool it down, then as you said, when it's flowing again it goes back to normal
Old 17-03-2008, 09:45 PM   #3
andrewts
White Car Driver
andrewts's Avatar
Yeah my car does it, heat soak I think it's called, it is normal.
OzECruisers - The Ford EA-EL, NA-NL, DA-DL & XG-XH Owners Club
andrewts is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2008, 09:52 PM   #4
amisupposed2b
yup happens right here on a constant basis.
I have no clue what it is, but I got used to it. Because I do alot of stop start driving too.
amisupposed2b is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2008, 10:02 PM   #5
nikos
mezzo forte
Sweet, thought so. Ta fellas.
Old 17-03-2008, 10:24 PM   #6
mik
mik's Avatar
never had that problem, when its stone cold have a look and see if the water level has moved from normal position, if it has it might be time for cooling system check.
Old 18-03-2008, 08:10 AM   #7
InfernoSR
Sales Representative
InfernoSR's Avatar
Not an issue mate... unless it stay's at that higher temp...
Old 19-03-2008, 12:27 PM   #8
Mechan1k
Mechan1k's Avatar
Yeah I get it on the odd occasion after stopping (after loaded up driving in the heat in traffic) ... just a case of heat soak. The water pump stops when engine is off ... and the temperature sensor in the back of head just reads the heat from the back of head which is the hottest part of the engine bay literally.
Once the car starts and coolant flows is comes back down to normal.
A Blueprint said though ... if it stays up in the H range ... you have problems.
Old 19-03-2008, 11:23 PM   #9
EvilChief
Boost Addict
two areas i would look at:
faulty WTS or bad earth (temp gauge is earths through resistance in sensor)
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
