Old 25-03-2008, 12:32 PM   #1
BEN189
Default EL Fairmont Headlight Replacements
Hi All
I am sure that this has been discussed before.
I need to get new headlights for my EL badly. I rang Ford up and they told me they cost $398 each! On ebay, I can buy "copy" ones for around 110 but I have heard they are no good.
There is no way I am going to spend $800 for new head lights when I can get some for a quarter of the price.
Who on here has used the ebay headlights? Are they ok?
FG F6 in Ego, dark argents, Leather, reverse camera
350rwkw with Rapid cooler, Herrod CAI, Deka 80lb injectors, full xforce 3.5" exhaust, actuator.
BEN189 is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2008, 01:08 PM   #2
Gohan
hey
try the wreckers they will have some. EF Falcon, EF Fairmont and EL fairmont headlights are the same only differance is the EL Falcon headlights which were differant molding for the differant front end. PS i heard bad stuff about the copied headlights like they melt under the heat of the headlight globes
hope this helps u out
Driven Lan Evo 9, Ex Cop AWD Magna, Ralliart Colt
Normal Driver Smashed UP! and GONE!
Gohan is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2008, 01:08 PM   #3
fairmont1998
fairmont1998's Avatar
They are rubbish. Honestly, stay away from them.
Speak to The Dok, he is a headlight specialist.
Current Rides:
2012 KK Jeep Cherokee Limited CRD - Still going strong
2019 MG ZS Essence
1988 RD Mitsubishi Colt GL - 59kW of Fury
2022 Kia Stinger GT
fairmont1998 is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2008, 01:10 PM   #4
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
As above
see this thread:- http://www.fordforums.com.au/showthread.php?t=113911
http://www.theheadlighthospital.com.au/
There is a reason why the "copy" ones are around $110 each, cheap plastic which melts under heat, cheap wiring which again melts under heat, cheap reflectors, they may last you 6 months but then you will be back to where you are now and need to replace them again.........................
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2008, 01:29 PM   #5
JC
JC's Avatar
Do they need replacing because they are broken, or because they are yellow? If yellow, then clean them following the procedure outlined in DrHemi's first link. It works a treat.
Ford Performance Club ACT
Old 25-03-2008, 03:24 PM   #6
BEN189
My headlights are pretty bad though, maybe beyond repair.
Old 25-03-2008, 04:13 PM   #7
Sorted
Sorted's Avatar
If in doubt just to change over with The Dok from The Headlight Hospital - he is highly recommended by many forum members
I couldnt be stuffed trying to clean them so i did the easy option
Here are pics of mine:-
Tuned by DYNOMOTIVE
Old 27-03-2008, 12:57 AM   #8
[Tonko]
What's green is gold
[Tonko]'s Avatar
When you do decide, get some headlight covers, my EL Ghia had them from new and they looked brand spankin'
That car was outside 24-7 aswell.
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU -
1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps-
[Tonko] is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2008, 01:44 PM   #9
AHMD6T
Has anyone ever even tried these? I've been using aftermarket ones on my EL Fairmont for over 1 year now and haven't had a problem. I've seen some examples that don't fit correctly but other than that, there doesn't seem to be a problem with aftermarket lights.
A mate of mine has been running aftermarket units in his EL Futura for over 2 years after smashing in to a fence and breaking all the tabs off the originals which were yellowed. They still look and work fantastic after so long.
From reading a lot in here recently I think some of you may be playing chinese whispers with a lot of this kind of stuff.
As for The Dok, I have no doubt in his ability but a panel beater mate of mine showed me a way to turn filthy yellowed lights to brand new spec with in 1 hour and without a lot of effort. You need a proper buffer, some sandpaper and a strong compound. I forget the name.
AHMD6T is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2008, 02:16 PM   #10
Sorted
Sorted's Avatar
There is always the good storys and the bad storys with anything but from personal experience I asked a couple of eBay sellers of these headlights to put it in writing to me that they wont melt and will fit perfectly and all i got was a silent responce.......... silence says alot ALSO no gaurantee says more...... :evil3:
One of them in his add stated his repo lights are better than other ones listed on eBay, I asked him why and he didnt know the answer - what a tool !
And in regards to repairing them, I did the repair job, spent 3 hours on my old headlights and they were no way near as clear as what the Dok can do them as he actually cleans the inside of the lense, the reflector and the housing so at the end of the day when they faded again(in 3 months) I said stuff it and I can't be bothered so I will take it to the expert............
Tuned by DYNOMOTIVE
Old 03-04-2008, 08:53 PM   #11
tapeworm
tapeworm's Avatar
Rub cut and polish into them with a sponge, they come up like new.
tapeworm is offline   Reply With Quote Multi-Quote with this Post
