Old 20-04-2008, 06:26 PM   #1
whitexr
roughneck
whitexr's Avatar
Default CAI Upgrade for an AU 1
Hi Guys,
Tried having a look through and doing a search but not having much luck on the technical side so need some specific advise from you AU experts.
I've bought my son a AU1 Classic. It's in really good nick and I wanted to do a couple of cheap basic bolt on mods to it for for better breathing. (He can pay for anything else after this, ha ha)
I'll be sorting the exhaust out but I'm confused about the CAI mods. I've seen where some guys have fitted the BA air box, intake pipe and XRT snorkle . Do they just bolt straight into the AU1?
Ego XR6 BF MK 2 NA, 6 spd Auto. Eng mods - Plazmaman air pipe and airbox w/pod filter & xr8 upp snkl, undrdrv, xtrctrs+2.5 hiflo cat & zorst, K & N fltr, BPT Custm tune. 175rwkw. Hndlng mods-1" lwrd Kings sprngs, Whiteline sway bars.
Bling - lwr grill, 19x8 Dark Ardent rims w/ 245 Maxxis, custm tail lites, XR scff plts, XR mats, Shift-i, pod gages, Fairmon chrm boot trim, chrm mirrors, boot de-bdge, red au xr6 side bdges, alloy fuse & comp covers.
To do: Hndlng mods - brake upgrade
whitexr is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2008, 07:15 PM   #2
JC
JC's Avatar
Originally Posted by whitexr
Hi Guys,
Not quite. But with a little modification (purchase of a section of 3" pipe, with a 30 degree bend in it, and a 3" to 3.5" silicon joiner), you can use a BA XR8 Pod setup, and it fits quite nicely and does a fantastic job. Here's a pic of the setup in my old AU wagon:
Ford Performance Club ACT
Old 20-04-2008, 07:28 PM   #3
JoesAu
JoesAu's Avatar
a forum memeber fitted a ba box and lost power on back to back dyno runs, just throw a tickford snorkel on, and a k&n flat panel in will breath alot better. also changing the inlet on the lid from 50mm to the ef one which is 80mm...
JoesAu is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2008, 07:34 PM   #4
StealthAu
more then one person on here lost power after changing to a 3" pipe.
I lost 3rwks from one run to the next (30 seconds apart) without changing anything.
Old 21-04-2008, 06:28 PM   #5
whitexr
roughneck
whitexr's Avatar
Thanks guys. Can you still get the tickford snorkle from ford?
Will the ba/bf XR6T snorkle bolt straight into the AU and mate up to the AU air box?
Old 21-04-2008, 06:57 PM   #6
ayeyew
Teh Baest
ayeyew's Avatar
XR6T Snorkel is exactly the same as the tickford snorkle, just without the wings
Tickford snorkels cannot be purchased from ford anymore, but they can be found on ebay every now and then (usually go for $100+), which is silly when the XR6T one is around $30.
Yes, the XR6T snorkle will bolt straight on. Will take a whole 30 seconds to do
Just get that plus a K&N Panel Filter and you will notice a little bit of a difference, mostly in throttle response. Plus a nice whirring noise
1999 Liquid Silver AU
Show: XR6 Kit, Low, RDA Slotted's F&B, Fully Tabouli Sound System, Altezza Tailights (Good ones!)
Go: K&N Pod w/ 3" intake, XR6T Snorkel, Pacie Comp 4480's, 2.5" Cat Back, CMS Stg2 Cam, Custom Tune, Tranny Cooler
Coming..CMS Stg2A Cam, 68mm TB
Later.. 4.5L w/ BOOOOOOOOOOST or XR6T or AUIII XR8 220
Currently:
151kW (165 on other dynos )
ayeyew is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2008, 09:28 AM   #7
GS608
Would a F6 box and both intakes fit into an AU 6?
Old 18-11-2008, 11:32 AM   #8
NYTEYZ
I threw on a BA XR8 snorkle on mine, goes straight on
NYTEYZ is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2008, 05:24 PM   #9
broken_suave
broken_suave's Avatar
Old thread is old. But ebay always has widemouth snorkels for around $45-50.
05 BF XR6 ZF 6spd - Stock for now
Previously:
98 AU Futura 4.0 - Wildcat Extractors, 200cpsi Stainless Cat, Custom 2.5" Mandrel Bent Exhaust, Tickford Snorkel, Fram 'Airhog' Panel Filter - Daily
79 P6 LTD Silver Monarch - Project
broken_suave is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2008, 03:35 PM   #10
Ride
Stay Classy ™
Ride's Avatar
To a Fairmont no, only an XR would be able to just squeeze in due to the headlight design.
Ride is offline   Reply With Quote Multi-Quote with this Post
