Old 23-04-2008, 09:47 PM   #1
JoeM
Default Fuel Economy on Gas for AU3 Marlin XLS Ute
Was wondering what is the typical fuel economy for LPG on this model. This was an after market conversion. Currently I get about 5 km per litre LPG around town and about 7 on a highway run
JoeM is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2008, 10:32 PM   #2
1LOUDXFUTE
1LOUDXFUTE's Avatar
i think youve posted this in the wrong forum buddy, try the au section
1LOUDXFUTE is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2008, 07:04 AM   #3
FADI75
Sponsor
mmmmmmmmmmmmmm
cheers
fadi75
AUTHORISED FORD REPAIR CENTRE
email: info@aslautomedia.com
FADI75 is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2008, 03:49 PM   #4
b2tf
not here much anymore
b2tf's Avatar
moved here as it may get a better response than in the ASL forum!
2024 F150 XLT
Old 24-04-2008, 05:29 PM   #5
schuldiner
there is a fuel economy thread in the AU section somewhere i believe, a search should find the thread and you can compare with others.
Everything always works out when you just do whatever you want and don't worry about the consequences.
see my ute here
AU parts for sale
schuldiner is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2008, 09:26 AM   #6
Mechan1k
Mechan1k's Avatar
OK ... 5km/L equates to ... ummm ... pretty much 20L/100km.
It is a bit much I guess ... it depends what you drive like around town.
The factory EGAS models were around 15L/100km combined from memory ... I have seen 20L/100km in the city with heavy load in the back ... no problems.
On highways ... i drop to about 11-12L/100km ... depending on right foot.
When was the last time you had the gas side of things serviced????
What LPG system is installed???
When was the O2 sensor replaced???? (I just replaced mine as it was using a bit more LPG ... it uses a heap less now since I changed this out)
How many kays has the ute done???
Old 27-04-2008, 12:11 AM   #7
teabags2
Bob
5 is a bit poor for an AU 6. If you are only doing very short trips or stop start then that possibly OK. 6 is more whatb it should be with a gas ring style. Country can be as high as 9 at 110kph for a long trip. This is for a 4Lt auto sedan which has a diff ratio of 3.08.
I don't know the Marlin but utes are 3.3? something (XR's are 3.55) This would reduce the economy somewhat.
Bob
teabags2 is offline   Reply With Quote Multi-Quote with this Post
Old 27-04-2008, 07:12 AM   #8
Mechan1k
Mechan1k's Avatar
Just to add to Bob's post above,
In Auto form:
Base utes ran a 3.23:1 diff.
XR utes ran a 3.45:1 diff.
