Old 09-05-2008, 10:24 PM   #1
ford man xf
Default Any acceleration figures with the LS3 6.2 litre?
Anybody know the acceleration figures in the HSV range with the new LS3 6.2 litre that went on sale in April?
ford man xf is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2008, 01:48 AM   #2
GTP370
2005 BA II GTP
GTP370's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Excellent breakdown of costs associated with importing a pre-89 car from the U.S.  Very helpful to others and at least two other guys will use the provided info to make their dreams reality..
I took a 6.0 auto and a 6.2 manual for a test drive the other week. Didn't notice too much difference when accelerating onto free way and both hit the same sort of speed. Sorry don't know actual times though.
GTP370 is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2008, 04:02 AM   #3
Steffo
LPG > You
Steffo's Avatar
Probably not much. They're torque restricted because HSV use wimpy gearboxes. The 10kW won't do as much as if the full 575Nm were allowed to play would...
Though looking at the Corvette's, LS2 (400hp 400ftlb or 299kW 542Nm) vs LS3 (430hp 424ftlb or 321kW 575Nm)...
The LS2 C6 pulls 0-60 mph in 4.4 seconds and does the quarter in 12.6.
The LS3 C6 pulls 0-60 mph in 4.1 seconds and does the quarter in 12.5.
Old 10-05-2008, 09:53 AM   #4
bangm001
Mopar! But Own F6's..
Not bad, them C5s are sweet..
F6 TYPHOON
FPV 335 GT
bangm001 is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2008, 11:45 AM   #5
Bossxr8
Peter Car
Bossxr8's Avatar
Probably not even a tenth of a second in it.
Old 10-05-2008, 09:45 PM   #6
ford man xf
Will be interesting to see how they go with a full weight VE, will probably still beat the FG GT-P though, I hope the GT-P can beat it 0-100km though, the LS3 can have the 1/4.
Old 10-05-2008, 10:13 PM   #7
Falc'man
You dig, we stick!
Falc'man's Avatar
No acceleration figures here but a dyno result (231.5rwkw) off ls1.com.au
http://www.ls1.com.au/forum/showthread.php?t=96739
Originally Posted by Street_Tuna View Post
We spent some time going over a new LS3 powered HSV yesterday and as part of the process we dynoed the car to find out what all the fuss is about. The LS1 certainly 'looks' very similar to the old headed engine, but the big question remained....does it make anymore grunt? Using the advanced OBDII logging feature of the Mainline dyno we were able to take a 'window' into the factory management system and plot Wide Open Throttle ignition timing as well as measure the Air Fuel Ratio to see exactly how 'in the slot' HSV had got this thing....
There certainly wont be massive gains in tuning these cars as the air fuel ratios are what most tuners would consider to be 'spot on perfect' and as can be seen from the timing curve there is some thought that has been putting into maximising both power and torque while minimising the chances of midrange detonation
Overall.....interesting. The car certainbly drives well, but its not as though you would notice the extra 10kw over the previous LS2 engine when hidden in 1800kg plus worth of motor car. While the LS3 certainly has plenty of poke it still isnt a match for top line European performance V8 of the same capacity. Tuning and particularly twin turbocharging results for this engine should be interesting
"....You don't put the car through engineering" - Rod Barrett.
Falc'man is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2008, 12:22 AM   #8
CAT600
I miss my wheelbarrow
CAT600's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always willing to help out fellow AFF members... Technical Contributor: For members who share their technical expertise. - Issue reason: Daniels knowledge of modular engines and superchargers is extremely valuable to the AFF community. I have learnt quite a bit just reading his build threads. His contributions are often utilised by other members.
Maybe the FG GT dyno result will trickle out soon too?
This gaffa tape is killing me!
Daniel
CAT600 is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2008, 12:36 AM   #9
ford man xf
The FG F6 is going to blow this thing away.
I think also that the FG XR6 Turbo will still be quicker than the LS3 just like it is of the 6.0 HSV. You would be a very happy FG XR6 Turbo owner knowing that your car is a "bread and butter" sedan and it beats a "premium" performance car that cost 20 grand more and has 47 more kilowatts! :-)
Old 11-05-2008, 12:48 AM   #10
Bent8
Long live the GT !
Bent8's Avatar
It's the torque that makes all the difference, the XR6T's have 533Nm@2000rpm, that's more than what a VE SS 6 Litre V8 makes at 4400rpm!
The F6 has 565Nm@1950rpm, the in-gear acceleration will be like having rockets strapped to you car!!
2018 Ford Mustang GT - Oxford White | Auto | Herrod Tune | K&N Filter | StreetFighter Oil Separators | H&R Springs | Whiteline Vertical Links | Ceramic Protection | Tint
"Whatya think of me car, XR Falcon, 351 Blown Cleveland running Motec injection and runnin' on methanol... goes pretty hard too, got heaps of torque for chucking burnouts, IT'S UNREAL !!" - Poida
Bent8 is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2008, 12:55 AM   #11
ford man xf
All comes down to torque and when it comes on does it?
How can the F6 hit that much torque so low down? Must have virtually no lag at all???
Old 11-05-2008, 01:03 AM   #12
Falc'man
You dig, we stick!
Falc'man's Avatar
That's why Ford downsized the turbo.
Old 11-05-2008, 01:07 AM   #13
ford man xf
Yeh I know they downsized it, but can it make that much difference with lag? I know a bigger hairdryer will have more lag than a smaller hairdryer, but the turbo on the FG isn't that much smaller is it?
Old 11-05-2008, 01:09 AM   #14
351@GT
351@GT's Avatar
also upped the compression a bit, so even b4 the turbo comes on the motor by itself is already making more
351@GT is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2008, 02:01 PM   #15
M&Ms
M&Ms's Avatar
And here's to hoping the F6 puts it to the $170K LS7 commie too! :
M&Ms is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2008, 03:34 PM   #16
Bossxr8
Peter Car
Bossxr8's Avatar
They also reduced the piping length by more than 70cm, which results in less lag.
Old 11-05-2008, 03:57 PM   #17
Whitey-AMG
AWD Assassin
Whitey-AMG's Avatar
Always amazes me how the GM powerplants always make much less RWKW than the FORD units. The new LS3 barely makes more than the B series 290 Boss...........????
The TORQUE and HP under the curve however is V good..........I guess this is where the difference in the stock motors is. The B series BOSS is peakier and combined with that joke of a rear end 2.7 gearing in the auto....... :
Hopefully the new 315 will spread the TORQUE and HP more evenly to finally overtake the LS powerplant for acceleration and in gear driveability.........from stock.
Whitey-AMG is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2008, 05:50 PM   #18
rapom1
To attempt to answer the question. Youde think a 6.2 would have to be able to run a 13.0 or 13.1 Surely, perhaps even 12.99.
I suppose we'll find out very soon when Wheels and Motor get their hands on them.
rapom1 is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2008, 09:13 PM   #19
Falc'man
You dig, we stick!
Falc'man's Avatar
http://www.drive.com.au/Editorial/Ar...rticleID=52466
Originally Posted by Drivel
Flat out, the latest HSVs don’t feel radically quicker than the ones they replace. We’d really need to back-to-back new and old to distinguish the shades of grey in the outright acceleration.
That 0-100km/h claim is the same as the 4.96 seconds claimed for the outgoing 6.0-litre V8 (codenamed LS2) that no media outlet could ever match. HSV says the automatic is now just as quick in acceleration as the manual.
Drive.com.au couldn’t match the sub-five-second acceleration claim during our own independent testing using a satellite-based timing computer called a Driftbox. The best Drive managed in an HSV Senator with an automatic transmission on a warm-ish day was 5.6 seconds for the 0-100km/h sprint.
Maybe a manual on a cold night would be more to Toby Hagon's liking? The twit sure didn't help the XR8's cause by shifting correctly did he?
Old 13-05-2008, 11:01 PM   #20
loltastic
Mid 5's sounds about right for a big heavy HSV.
loltastic is offline   Reply With Quote Multi-Quote with this Post
