#1 | |||
You can't stop the signal
There have been a few instances within these forums of what seams to be either a leaking windscreen, or a leaking firewall from a crack, that allows water into the cabin and onto the feet of the driver. This actually turns out to be a faulty spot weld under the wiper cowling. This how to shows you how to inspect and fix this issue.
Cost For me it cost nothing as I already had the tools required at home, but it could be done for under $20 if you didn't have any silicon, or $40 if you had no tools, or couldn't borrow any Tools required Small flat headed screw driver Medium Philip head screw driver (stumpy version is better) Ratchet with 10mm socket, 13mm socket and extension bars Silicon of any colour + Gun (or another type of sealant) Step 1 Using the small screwdriver, remove the bolt covers on the wiper arms, and using your hands remove the weather seal that is in between the cowling and the engine bay ![]() Step 2 Using the 13mm socket and ratchet undo both bolts holding the wiper arms to the motor. With draw the arms from vehicle. Using the Phillips headed screw driver, undo the 5 scrivet's across the front of the cowling cover (2 in drivers side cover, 3 in the other) ![]() Wiper arm Bolts ![]() Scrivit location Step 3 Maneuver cowling covers from the vehicle. This is very fiddle because of the tabs that are on each cover. Begin with the drivers side cover first. There are tabs that locate it to the windscreen (not Clips) and to each quarter panel. You may need to push down slightly on the cowling at the quarter panel to assist in removing it ![]() Cowling removed Step 4 Disconnect the wiper motor wiring and push out the grommet that the wiring enters the cowling through. Pull the harness and plug through the hole. Using the 10mm socket and ratchet, undo the 5 bolts/nuts (3 bolts, 2 nuts) that hold the wiper motor assembly to the vehicle and withdraw from the vehicle (fiddly again) ![]() Wiring harnes and gromet ![]() Bolt location ![]() Nut location Step 5 Inspect the weld. If you think this is the cause, silicon it up, if not reverse the steps and put your car back together. Or you may want to silicon it just in case ![]() ![]() ![]() Silicon in place. I didn't like the look of either weld so i did both Step 6 Put you car back together in the reverse of the steps provided, taking care to line your windscreen wipers when you re-install them. This is a case of put them on in the approximate position, test them, and re-position if necessary. You should be able to see on your windscreen to approximate place where the wipers wipe. Step 7 Clean up and enjoy a beer while marveling at your car modding abilities. Cheers
11 users like this post: |
www.TUFFCARPARTS.com
Fantastic write up mate! Thanks for taking the time to share this with everyone.
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
BA GT-P Owner
Great write up superroo. You beat me to it I was about to do this myself as my car has this problem too. Will weld mine up when I when I weld up the front of the car.
DAILY DRIVER/TRACK CAR BUILD NUMBER 006 299.5 rwkw's 12.74 @108mph ON MT's ON MAXXIS MAV1's 275/45/17 13.27 @ 106mph
Cat be Still !!!
Your a LEGEND superroo.
Had this drama with mine, followed your step by step instuctions. Problem solvered !!! |
Hey...
is this only happening to manuals or automatics as well ? Thanks... The Moose |
#6 | |||
Not sure actually.
The cars that I Know have had this problem are all manuals, but since it seams to be the spot welds, i'd say both types of cars could have it. Cheers
Walking with God
Nice work Roo.
GK
And if you don't fix it, this is what can happen to the computer when the water runs down the loom and onto the computer.
FPV GS Ute #370/Brembo brakes Last edited by DW260; 10-10-2009 at 07:42 PM. |
#9 | |||
Walking with God
GK
Awesome! I had been (unsuccessfully) trying to solve the "leaking windscreen" problem on my AU1 XR8 (manual incidently) and came across this article.
Job was easy - not to mention cheap - and fixed the problem a ripper. Now I can drive in the rain without waiting for that inevitable drip, drip drip... Thanks superroo |
pursuit ute baby
shall be doing this VERY shortly.. ive had a few wet shoes since owner ship and that fried ECU looks MIGHTY nasty. do not want.
my ride : AU xr8 pursuit ute ![]() |
#12 | ||
![]() Join Date: Jan 2005
Anyone got any idea what to do about doors (both front) the fill up when it rains? I know it's not a leaking windscreen, but is kind of connected.
#13 | |||
There are drain holes in the bottom of the doors.
Either they are blocked or have been covered up. Solution - Pull off the door trims, and that foam sheet as well and inspect. Cheers
#14 | |||
#15 | ||
Critical Thinker
excellent write up. Rep points added
"Everybody was KungFu fighting..." 2022 Mazda CX5 GTSP Turbo 2024 Ford Everest Trend 1967 Ford XR FALCON 500 Cars previously owned: 2018 Hyundai Santa Fe Highlander 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
#16 | ||
Those spot welds support the brackets under the dash for the pedal box and they only seem to be more prevelant on manuals because of the strain put on them when using the clutch but I suppose they still could be a problen eventually for an auto.
I will be pulling out the dash on mine soon as i have had this problem for a long time now and have just put body tape over them. You know if this is your problem if you feet get wet when cornering or in very heavy downpours as the water goes over the raised part of the panel instead of going around it. If anyone is interseted I could take pics and show how to fix this permanately as those spot welds will eventually break and you may lose some support for your pedal box. i will be doing this on my AU1 XR8 manual. I've taken the dash out of my EB2 XR8 to repair the pedal box ,so I can't see the AU being that much different to do. Just a bugger of a job to remove the dash and half of the interior for about 20mins worth of welding (max).
We salute those brave souls that enter the DARK side |
#17 | ||
Just another mock-up..
Great write up mate!!!!
rep a comin!!
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
#18 | ||
did mine last year from this write up and it fixed mine too. i couldn't beleive how much water came through a spot weld that you couldn't even see a hole in. thanks again superroo.
#19 | |||
FPV GS Ute #370/Brembo brakes |
#20 | ||
I now have dry feet thanks to you - you are a god :P
AUI Ford Fairmont | Lowered with Kings | XR8 Leather Interior | XR6 Tickford Engine and Gear box| |
#21 | ||
This is why this forum is fantastic, was suffering from wet feet when ever I parked my Manual XR8 facing up hill, found the link and am now in the shed about to apply a bit of the right kind of Silicone to the two top spot welds that have a slight rust circle around them, hard to belive that these slight cracks would allow so much water to enter, congrats on a fantastic write up!!!!!!!!!!!!
2000 AU11 XR8 UTE 5 Speed - play/day 1992 80series Landcrusier Turbo - play 2009 Hilux - work |
#22 | ||
Many thanks.........
That drip has been driving me insane! All fixed today Thanks again |
#23 | ||
AFF Whore
I checked this the other day just to see if it was stuffed, luckily my car was owned by a complete tight **** and the welds still had original paint on them
#24 | ||
66 Mustang
Will give this a go and hopefully will fix my water dripping problem.
#25 | ||
yeah this tutorial worked a treat on my auto AU Futura Wagon, however I didn't have the water dripping on my feet like others on this thread have mentioned, but my carpet and underlay was soaked badly.... once i lifted up the carpet there was at least equivalent to an icecream container full of water i took out lol... but after following this... no more wet carpet. thanks for sharing!
#26 | ||
Maaate, I reckon you nailed it..
I've had the same issue for some time now, always after rain I'd back out the drive way and/or go around the first left hand corner and get a wet right foot. I did exactly as you suggested, found one of the spot welds was cracked and looking a little rusty so I cleaned it up and pushed silicon into it and all around. Tested it by giving the car a good drenching with the hose and took her out the driveway and round a few bends, no leaks. Great write up with helpful pix. Thank you for sharing. Cheers Steve |
#27 | ||
yeah good thread my ute had a crack under the wiper motor had the windscreen replaced with no luck till I took it to a mate who owns a smash shop and he found it by elimination!
#28 | ||
Good thread, as I replaced my windscreen yet I still get water leaking through the footwell where the clutch pedal is. Sure enough there was a broken spot weld.
2015 MK7 VW GOLF GTI __________________
Previous Cars 2002 AUIII XR6 1995 EF Falcon XR6 2003 LR Focus Zetec 1989 KE Laser TX3 |
#29 | ||
I washed my AU for the first time since I bought it the other day and water leaked from the top of the windscreen in the middle right onto the shifter etc. It has caused the roof lining material to depart from the foam lining.
It appears the screen has been replaced at some stage and the fitment is very poor. Not a happy camper! |
#30 | ||
This fix is a good short term solution but eventually nearly all the spot welds break and you will have no support for the pedal box at the top and only from the bolts around the brake booster.
I have started diong some work on my AU1 XR8 which is manual and I had put some body tape over the spot welds a fair while ago but unfortunately more have cracked.Out of the 5/6 spot welds 3 have broken away and most probably the others are starting to crack. If anyone is interested I can put up some pics of the problem and hopefully a solution so this will not happen again as it's very time consuming to fix. Just a bad design fault to spot weld this bracket to the body. At least the EB's have 4 bolts to hold the top of the pedal box in place which is a far better way. I know this as I had to repair the pedal box on my manual EB XR8 a while ago. Still had to remove the dash but at least the pedal box was bolted on at the top!!
